Topic: Any tips to keep memory usage as low as possible? (Read 8439 times) previous topic - next topic
Pferdesalamie
Are there any tips or good practices for keeping the memory usage as low as possible?
I'm using 2 libraries plus my own classes right now and kinda hit the limit of the Unos ram  ::)
So are there any advanced memory-saving tips?
PaulS
In general, keep arrays as small as possible. Store constant strings in PROGMEM to reduce SRAM usage.
To help you with your specific problem, we'd need to see your code.
Pferdesalamie
Tanks very much.
I will try to use progmem and see if it works for my sketch!
But I discovered something else i hope anyone here can explain to me:
My Sketch has a rather large collection of classes i use to control LED Displays, IR Emitter,...
So i made an "System.h" header file where I store some options, as well as static objects from my classes (since I will only need one instance from each anyway)
It looks like this:
#ifndef SYSTEM_H
#define SYSTEM_H
#define OPTION 1
#define SOMEOTHEROPTION 2
static StupidClass foo;
#endif
The point of this was, that I am able to reach my options and objects from anywhere in my Code by including the System.h. And to modify my options in one single place.
The problem is, I discovered that including my Header file consumes about 100 bytes every time!
Coding Badly
Quote
[glow]static [/glow]StupidClass foo;
By making foo static, an instance is created for each module (source file).  If you want only one foo (a singleton) declare it extern in the header file...
Code: [Select]
[glow]extern [/glow]StupidClass foo;
And define a single instance in one module (source file)...
Code: [Select]
StupidClass foo;
frank26080115
#4
Jan 16, 2011, 05:31 am Last Edit: Jan 16, 2011, 05:34 am by frank26080115 Reason: 1
alex.c includes system.h
mike.c includes system.h
compile alex.c into alex.o, alex.o now contains one StupidClass
compile mike.c into mike.o, mike.o now contains one StupidClass
link alex.o and mike.o together, now you have two StupidClass, hence why the memory increased
the correct way is probably to use "extern" in system.h, and actually declare it in a source file (c, cpp, etc)
system.h has "extern StupidClass foo;"
josh.c has "static StupidClass foo;"
alex.c includes system.h, mike.c includes system.h
compile josh.c into josh.o, josh.o contains foo
compile alex.c into alex.o, alex.o knows that it's supposed to use a StupidClass called "foo", but doesn't have it
compile mike.c into mike.o, mike.o knows that it's supposed to use a StupidClass called "foo", but doesn't have it
link josh.o with alex.o and mike.o, now alex.o and mike.o knows where foo is
edit: coding badly beat me by 28 seconds
Freelance engineer, consultant, contractor. Graduated from UW in 2013.
Pferdesalamie
Pferdesalamie
I tried using PROGMEM to store my strings, but I get "multiple definition of" error messages.
I've put
Code: [Select]
prog_char SOUND_TEST_P[] PROGMEM = "Test.wav"; in my "System.h" header file wich is included in many other classes. I presume the later is causing the problem.
But how can I use PROGMEM to store my strings and still be able to use it globally in my Sketch?
Mark S
you can use strcpy_P, to copy from FLASH to ram. I also wrote my on print functions that print directly from program memory.
void MYprint_P(prog_char *flashMemStr)
char      theChar;
int            ii;
     ii            =      0;
#if (FLASHEND > 0x10000)
     while (theChar      =      pgm_read_byte_far(flashMemStr + ii++))
#else
     while (theChar      =      pgm_read_byte_near(flashMemStr + ii++))
#endif
           print(theChar);
Pferdesalamie
Tanks, but i don't understand your code  ;D
What I tried now:
I put
extern prog_char SOUND_P[];
in my often included System.h header file, and put
prog_char SOUND_P[] PROGMEM = "Sound.wav";
In one source file.
So it compiles fine, but when I call
char buffer[13];
strcpy_P(buffer, (char *)pgm_read_word(&SOUND_P));
My Arduino just restarts  :(
Coding Badly
Give this a try...
http://arduiniana.org/libraries/flash/
westfw
In general, you should try to avoid putting commands that actually generate code (or data) in common .h files (for exactly the reasons that you are seeing.)
Put all your error messages in some .c or .cpp or .pde file, and put "extern" declarations in your .h files.
Pferdesalamie
Tanks, I tried the lib Coding Badly suggested and it Works flawless!
Need to test out how much memory I saved this way, though.
bubulindo
This... is a hobby.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
