Loading...
Pages: 1 [2]   Go Down
Author Topic: Library for Accelerometer MMA7361  (Read 9170 times)
Barcelona
Offline Offline
Newbie
Arduino hurts my brain... but i like it
View Profile
WWW
thanks,
it's this way i want to use it (no sleep mode),
so can't make directly a bridge between VCC (3,3v) and SL pin....  :'(
i will have to find a small SMD resistor on an old board and try to sold it...
My project need to be light and small!  smiley-grin
regards
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Currently working on the AREF version. The 1.5G mode will come later. I expect it to be fully mature half of januari.
Logged
Denver
Offline Offline
God Member
Inactive - PM
View Profile
WWW
@lebenj
Quote
I'm not saying that you "can't" directly connect SL to VCC, but I can't suggest it either. It is very possible that the chip would be OK with that, but since I haven't tried it, I can't suggest it. I do know that if you directly connect it, you will never be able to put it in sleep mode.
Again, if you can spare a pin, you could avoid the resistor and have the option of using sleep mode.
@studioj - look forward to your next version.
 :-X
Logged
"Data is not information, information is not knowledge, knowledge is not understanding, understanding is not wisdom."
~ Clifford Stoll
0
Offline Offline
Newbie
Arduino rocks
View Profile
@lebenj
I connected the sparkfun GSEL pin directly to the 3.3V which gave no problem. When your application is only for testing I dont think you need your resistor. But when your finishing your prototype I bet it's better to be on the safe side and use the resistor.
So i don't recommend doing it (it's comparable to short circuiting a fuse in your household, as long as everthing is fine it works but when something screws up, it screws up bad)
@BroHogan: at the moment I'm adding a simple callibrate function and a setpolarity function, also reworking the offsets so they have effect on the raw data instead of the G's
Logged
Barcelona
Offline Offline
Newbie
View Profile
WWW
thanks...
i will manage to find a resistor to be sure.... will be a nice soldering exercise, as i need a CMD one to keep it small and light
regards
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
@BroHogan -- thanks, this really helped me get a jumpstart! smiley
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
