Topic: USB Host controller (Read 23792 times) previous topic - next topic
Camille29
#45
Sep 25, 2010, 08:26 pm Last Edit: Sep 25, 2010, 08:41 pm by Camille29 Reason: 1
Thanks to quick reply Felis:
Can you explain me how :"Set callback to parser function to NULL" ?
I test :Eos.EventCheck(NULL); and NAK again
I'd like to test...
Can you explain that?How in bulk mode whe can know the end of data send (not packet end):
          I used function usb_bulk_read(usb_dev_handle *dev, int ep, char *bytes, int size, int timeout)
          size fixed to 130000 octets (very larger than the packet response data), and timeout=4000 (longer than embedded code)
          This function automatically return at the end of GetEvent READ OPERATION Data
          Even thought Last Step is a usb_bulk_read too (WRITE OPERATION CODE/READ DATA/READ RESPONSE)
          usb_bulk_read never catch the data packet and the response packet in the same time
          How usb_bulk_read done to know the send data packet is finish? Is there a USB Marker to flag end transmission?
nkostop
I would like to ask how to change the apperture and speed of the camera with felis code and usb shield.
Thanks.
Camille29
Use this Function ;
SetProperty(uint16_t prop, uint32_t val)
this define
#define      PTP_DPC_CANON_EOS_Aperture                        0xD101
#define      PTP_DPC_CANON_EOS_ShutterSpeed                 0xD102
#define PTP_DPC_Key_CANON_EOS_Aperture_auto         0xffff
#define PTP_DPC_Key_CANON_EOS_Aperture_1            0x08
#define PTP_DPC_Key_CANON_EOS_Aperture_1_1          0x0b
#define PTP_DPC_Key_CANON_EOS_Aperture_1_2          0x0c
#define PTP_DPC_Key_CANON_EOS_Aperture_1_2_BIS      0x0d
#define PTP_DPC_Key_CANON_EOS_Aperture_1_4          0x10
#define PTP_DPC_Key_CANON_EOS_Aperture_1_6          0x13
#define PTP_DPC_Key_CANON_EOS_Aperture_1_8          0x14
#define PTP_DPC_Key_CANON_EOS_Aperture_1_8_BIS      0x15
#define PTP_DPC_Key_CANON_EOS_Aperture_2            0x18
#define PTP_DPC_Key_CANON_EOS_Aperture_2_2          0x1b
#define PTP_DPC_Key_CANON_EOS_Aperture_2_5          0x1c
#define PTP_DPC_Key_CANON_EOS_Aperture_2_5_BIS      0x1d
#define PTP_DPC_Key_CANON_EOS_Aperture_2_8          0x20
#define PTP_DPC_Key_CANON_EOS_Aperture_3_2          0x23
#define PTP_DPC_Key_CANON_EOS_Aperture_3_5          0x24
#define PTP_DPC_Key_CANON_EOS_Aperture_3_5_BIS      0x25
#define PTP_DPC_Key_CANON_EOS_Aperture_4            0x28
#define PTP_DPC_Key_CANON_EOS_Aperture_4_5          0x2b
#define PTP_DPC_Key_CANON_EOS_Aperture_4_5_BIS      0x2c
#define PTP_DPC_Key_CANON_EOS_Aperture_5            0x2d
#define PTP_DPC_Key_CANON_EOS_Aperture_5_6          0x30
#define PTP_DPC_Key_CANON_EOS_Aperture_6_3          0x33
#define PTP_DPC_Key_CANON_EOS_Aperture_6_7          0x34
#define PTP_DPC_Key_CANON_EOS_Aperture_7_1          0x35
#define PTP_DPC_Key_CANON_EOS_Aperture_8            0x38
#define PTP_DPC_Key_CANON_EOS_Aperture_9            0x3b
#define PTP_DPC_Key_CANON_EOS_Aperture_9_5          0x3c
#define PTP_DPC_Key_CANON_EOS_Aperture_10           0x3d
#define PTP_DPC_Key_CANON_EOS_Aperture_11           0x40
#define PTP_DPC_Key_CANON_EOS_Aperture_13           0x43
#define PTP_DPC_Key_CANON_EOS_Aperture_13_BIS       0x44
#define PTP_DPC_Key_CANON_EOS_Aperture_14           0x45
#define PTP_DPC_Key_CANON_EOS_Aperture_16           0x48
#define PTP_DPC_Key_CANON_EOS_Aperture_18           0x4b
#define PTP_DPC_Key_CANON_EOS_Aperture_19           0x4c
#define PTP_DPC_Key_CANON_EOS_Aperture_20           0x4d
#define PTP_DPC_Key_CANON_EOS_Aperture_22           0x50
#define PTP_DPC_Key_CANON_EOS_Aperture_25           0x53
#define PTP_DPC_Key_CANON_EOS_Aperture_27           0x54
#define PTP_DPC_Key_CANON_EOS_Aperture_29           0x55
#define PTP_DPC_Key_CANON_EOS_Aperture_32           0x58
#define PTP_DPC_Key_CANON_EOS_Aperture_36           0x5b
#define PTP_DPC_Key_CANON_EOS_Aperture_38           0x5c
#define PTP_DPC_Key_CANON_EOS_Aperture_40           0x5d
#define PTP_DPC_Key_CANON_EOS_Aperture_45           0x60
#define PTP_DPC_Key_CANON_EOS_Aperture_51           0x63
#define PTP_DPC_Key_CANON_EOS_Aperture_54           0x64
#define PTP_DPC_Key_CANON_EOS_Aperture_57           0x65
#define PTP_DPC_Key_CANON_EOS_Aperture_64           0x68
#define PTP_DPC_Key_CANON_EOS_Aperture_72           0x6b
#define PTP_DPC_Key_CANON_EOS_Aperture_76           0x6c
#define PTP_DPC_Key_CANON_EOS_Aperture_81           0x6d
#define PTP_DPC_Key_CANON_EOS_Aperture_91           0x70
ex:Aperture 9.5
SetProperty(
PTP_DPC_CANON_EOS_Aperture,
nkostop
#48
Sep 26, 2010, 01:17 pm Last Edit: Sep 26, 2010, 01:34 pm by nkostop Reason: 1
Thank you very much!
Anyone knows why digital zoom doesn't work on the new library?
I tried to remove the commented lines from the cpp file but still i get errors.
I would also be grateful if you could tell me where did you find these define statements.
Thanks
Camille29
#49
Sep 26, 2010, 03:24 pm Last Edit: Sep 26, 2010, 03:29 pm by Camille29 Reason: 1
you can find the DPC_Key in the lib Gphoto2:
libgphoto2-2.4.9\camlibs\ptp2\ptp.c
and DPC in
libgphoto2-2.4.9\camlibs\ptp2\ptp.h
and with the getevent function but for me it's bugging and you?
I don't test all the ElectronicViewFinder EVF function don't know for Zoom
nkostop
I haven't try getevent. I can't find the define statements at the file you told me. Please check if this is the correct file.
Thanks.
Camille29
#51
Sep 26, 2010, 04:05 pm Last Edit: Sep 26, 2010, 04:21 pm by Camille29 Reason: 1
Yes you must make yourself your define DPC_Key with the
{PTP_DPC_CANON_ISOSpeed, PTP_VENDOR_CANON, 0x00,  N_("Auto")},
           {PTP_DPC_CANON_ISOSpeed, PTP_VENDOR_CANON, 0x28,  "6"},
           {PTP_DPC_CANON_ISOSpeed, PTP_VENDOR_CANON, 0x30,  "12"},
           {PTP_DPC_CANON_ISOSpeed, PTP_VENDOR_CANON, 0x38,  "25"},
           {PTP_DPC_CANON_ISOSpeed, PTP_VENDOR_CANON, 0x40,  "50"},
           {PTP_DPC_CANON_ISOSpeed, PTP_VENDOR_CANON, 0x43,  "64"},
           {PTP_DPC_CANON_ISOSpeed, PTP_VENDOR_CANON, 0x48,  "100"},
           {PTP_DPC_CANON_ISOSpeed, PTP_VENDOR_CANON, 0x50,  "200"},
           {PTP_DPC_CANON_ISOSpeed, PTP_VENDOR_CANON, 0x58,  "400"},
           {PTP_DPC_CANON_ISOSpeed, PTP_VENDOR_CANON, 0x60,  "800"},
           {PTP_DPC_CANON_ISOSpeed, PTP_VENDOR_CANON, 0x68,  "1600"},
           {PTP_DPC_CANON_ISOSpeed, PTP_VENDOR_CANON, 0x70,  "3200"},
           {PTP_DPC_CANON_ISOSpeed, PTP_VENDOR_CANON, 0x78,  "6400"},
and there is else typedef enum ( there
libgphoto2-2.4.9\camlibs\canon\canon.h
ex:
typedef enum {
     SHUTTER_SPEED_BULB = 0x04,
     SHUTTER_SPEED_30_SEC = 0x10,
     SHUTTER_SPEED_25_SEC = 0x13,
     SHUTTER_SPEED_20_SEC = 0x15,
     SHUTTER_SPEED_15_SEC = 0x18,
please try getevent ;)
nkostop
OK i want to try getevent but i do not know the exact way.If you have an idea please help.
Sorry but i am new to all this.
thanks again!
nkostop
#54
Sep 30, 2010, 02:03 am Last Edit: Sep 30, 2010, 02:07 am by nkostop Reason: 1
OK it works for me...That is great news!
Camille29
You haven't got any NAK??Lucky man! ;)
felis
Bluetooth communication over HCI -> http://www.circuitsathome.com/mcu/bluetooth-code-for-arduino-usb-host
ewanuno
felis,
great work on the digital camera interface.
are you thinking about porting this to arduino uno?
felis
It should work almost as-is with UNO - you will need to replace stock SPI library to one from 0018 or the playground.
DeFex
I just bought the USB host shield. I am hoping i will be able to use a 3dconnexion 6DOF Input device with it.
Is there a way to look at the input data from unknown devices?
