Topic: add new function to wiring_digital.c (Read 9842 times) previous topic - next topic
BKNio
Hello!
I am trying to add new function "MydigitalWrite" to wiring_digital.c () (\arduino-0017\hardware\cores\arduino)
When I try to compile:
In function 'void loop()':
error: 'MydigitalWrite' was not declared in this scope
How to win this problem?
retrolefty
#1
Jan 22, 2011, 08:03 pm Last Edit: Jan 22, 2011, 08:06 pm by retrolefty Reason: 1
Hello!
Quote
There should be no reason to modify the core function in the wiring library.
Just write your new function directly following the loop() function in your sketch:
void MydigitalWrite( int argument1, int argument2, etc.)
  //your new code
  // more code
Then you can use your new function anywhere in the setup or loop function of your sketch.
Lefty
BKNio
there is one reason
standart digitalwrite spends a lot of time to switch on or switch of massive of pins
i think i can do it, if i modify standart digitalWrite
Coding Badly
Why do you want to modify digitalWrite?  To make it faster?
BKNio
No. i want create new to switch on or off massive of pins
i cant use like this
Code: [Select]
for(int i=0;i<10;i++)
digitalWrite(i,HIGH);
because it spend a lot of time
BKNio
i only need add new function to \arduino-0017\hardware\cores\arduinowiring_digital.c
Coding Badly
Quote
Have you considered direct port access?
BKNio
Yes but i found nothing
How i can do it? there is special function?
BKNio
i want to do it like this
Code: [Select]
out = portOutputRegister(port);
if (val == LOW) *out &= ~bit;
     else *out |= bit;
that is why i need to add new function
Coding Badly
Quote
http://www.google.com/search?q=arduino+port
Quote
http://www.arduino.cc/en/Reference/PortManipulation
