Author Topic: add new function to wiring_digital.c  (Read 3100 times)
Hello!
I am trying to add new function "MydigitalWrite" to wiring_digital.c () (\arduino-0017\hardware\cores\arduino)
When I try to compile:
In function 'void loop()':
error: 'MydigitalWrite' was not declared in this scope
How to win this problem?
Left Coast, CA (USA)
Measurement changes behavior
Hello!
There should be no reason to modify the core function in the wiring library.
Just write your new function directly following the loop() function in your sketch:
void MydigitalWrite( int argument1, int argument2, etc.)
   //your new code
   // more code
Then you can use your new function anywhere in the setup or loop function of your sketch.
Lefty
« Last Edit: January 22, 2011, 02:06:42 pm by retrolefty » Logged
there is one reason
standart digitalwrite spends a lot of time to switch on or switch of massive of pins
i think i can do it, if i modify standart digitalWrite
Dallas
Shannon Member
Why do you want to modify digitalWrite?  To make it faster?
No. i want create new to switch on or off massive of pins
i cant use like this
for(int i=0;i<10;i++)
digitalWrite(i,HIGH);
because it spend a lot of time
i only need add new function to \arduino-0017\hardware\cores\arduinowiring_digital.c
Dallas
Shannon Member
Have you considered direct port access?
Yes but i found nothing
How i can do it? there is special function?
i want to do it like this
out = portOutputRegister(port);
if (val == LOW) *out &= ~bit;
      else *out |= bit;
that is why i need to add new function
Dallas
Shannon Member
http://www.google.com/search?q=arduino+port
http://www.arduino.cc/en/Reference/PortManipulation
thank you
