Topic: New library: RGB GLCD (LDS183 Controller) (Read 17071 times) previous topic - next topic
doc_norway
Hello.
I have made a library for RGB GLCD's based on the LDS183 controller.
This is the display that is used on the RGB LCD Shield by NKC Electronics.
You can download the library from my website: http://www.henningkarlsen.com/electronics/a_l_rgb_glcd.php
Please bear in mind that this is my first go at making a library for the Arduino, so it might not be as good as it can be.
Any feedback would be appreciated.
Regards
Henning
PaulS
How about a link to the display that the library is for. I'm lazy.
nkcelectronics
The display is featured in the RGB LCD shield for Arduino http://www.nkcelectronics.com/rgb-lcd-shield-for-arduino-65k-color-k65.html
but can be purchased alone: http://www.nkcelectronics.com/rgb-lcd-65k-color-module-philips-pcf8833-comp658833.html
It is PCF8833 compatible, similar to the one sold by Sparkfun but with 65K colors!
I uploaded a video (running doc_norway's library) and embedded it in the product page.
Garry
Hi
Great library works well with the RGB LCD shield
doc_norway
Just a quick update: v1.2 is now released with two new functions.
/Henning
doc_norway
Another quick update: v1.3 is released with support for Arduino Mega.
/Henning
Dobe
Nice library,i wanted to ask,is there any pre-function to read pixel,whether on o not?and any pre-function to fill an area and not only the circle or rettangle but an area... :-[
doc_norway
Hi Dobe
As far as I know there is way to read the state of a pixel.
The only way I can think of to make a flood-fill function is to keep a "screen-buffer" in memory, but as the buffer alone would require 32KB of ram this is not an option.
/Henning
doc_norway
RGB_GLCD v1.4 is released.
  • Added drawBitmap() with its associated tool
/Henning
scoobydrvr
Does this make use of all the analog pins? I'd like to use this for a project, but I need to make use of at least 2 analog pins and all of the other GLDs use 5 of the 6 available.
doc_norway
@scoobydrvr
The shield uses Digital 2-6, so all the analog pins are free for you to use :)
/Henning
scoobydrvr
That's great! Less pins than any of the others I've seen; I'm getting one!
doc_norway
RGB_GLCD v1.5 is released.
  • Added support for the Arduino Mega 2560
  • Added function to rotate bitmaps
/Henning
Jim F.
I just got mine working. (The fine soldering work was almost too much for me.)  Yay!
I'd like to download your library, but don't have an RAR extractor.  Can you publish a ZIP as well?
Also, do you have plans to implement a Netduino library for this shield too?
Thanks!
Jim
doc_norway
Rar usually get better compression, but if you PM me with your email-address or send me a message through my contact-form, I will email a zip-file to you.
I havent got a Netduino, so dont hold your breath. Maybe you would like to donate one... :)
/Henning
