Loading...
Pages: [1] 2   Go Down
Author Topic: Software PWM using daisy chained 74HC595s / SPI  (Read 8065 times)
Florida
Offline Offline
Sr. Member
hookedup!
View Profile
WWW
It took quite some doing to get easy to use PWM control working with the 595 shift registers.  I figured I'd pass along a slimmed down version of the application that just implements the PWM control via a timer1 process.
The idea is to add "pwm pins" using daisy chained 595s and then to be able to use them just like normal pwm pins, not having to deal with the low level actions.  To this end I use a srPins array to hold the value and a pwmWrite function to write a 0 to 255 value for that pin.
This code should be easily reused / modified to run a number of shift registers.
Using SPI allow for many more shift registers to be used with PWM control without flickering than a standard shiftOut mechansim.
Here is the code.
Code:
 * Name    : 74HC595 PWM SPI
 * By      : Joseph Francis
 * Open Source
 * Date    : 04 Jul, 2010
 * Version : 1.3
 * Notes   : Software PWM using daisy chained 74HC595 shift registers via SPI
 * I wrote this code in a way that uses a srPins array to hold the byte pwm value for each pin.
 * Similar to doing an analogWrite, you can do a pwmWrite call to a "virtual" SR pin or just set srPins[x].
 * A timer process runs in the background to do PWM control, so the loop can concentrate on the process.
 * Using this technique I have pwm controlled over 40 rgb leds with plenty of room for patterns, etc.
 * While I would suggest using another chip to drive LEDs, the 595s provide an economical way to get started.
#include <TimerOne.h>
//--- Update TICKER_PWM_LEVELS to control how many levels you want
//     usually 32 levels of brightess is good (32K colors)
#define TICKER_PWM_LEVELS 32
#define TICKER_STEP 256/TICKER_PWM_LEVELS
//--- Update TIMER_DELAY to control how fast this runs.
//    As long as you don't see flicker ... a higher number (slower) is better to assure
//    the loop has room to do stuff
#define TIMER_DELAY 280
#define SR_COUNT 6
//--- Used in iProcess to control the software PWM cycle
int ticker = 0;
//--- Pin connected to ST_CP of 74HC595
int latchPin = 10;
//--- Pin connected to SH_CP of 74HC595
int clockPin = 13;
//--- Pin connected to DS of 74HC595
int dataPin = 11;
//--- Used for faster latching
int latchPinPORTB = latchPin - 8;
//--- Holds a 0 to 255 PWM value used to set the value of each SR pin
byte srPins[SR_COUNT*8];
//--- Function used to set a shift register pin with a PWM value
//    can also just set srPins .. using this function allows you to map to pins if you need
//    a virtual mapping
void pwmWrite(int port, byte val){
  srPins[port] = val;
//--- This process is run by the timer and does the PWM control
void iProcess(){
  //--- Create a temporary array of bytes to hold shift register values in
  byte srVals[SR_COUNT];
  //--- increment our ticker
  ticker++;
  //--- if our ticker level cycles, restart
  if( ticker > TICKER_PWM_LEVELS )
    ticker = 0;
  //--- get ticker as a 0 to 255 value, so we can always use the same data regardless of actual PWM levels
  int myPos = ticker * TICKER_STEP;
  //--- Loop through all bits in the shift register (8 pin for the 595's)
  for (int i = 0 ; i < 8; i++ ){
    int myLev = 0;
    //--- Loop through all shift registers and set the bit on or off
    for (int iSR = 0 ; iSR < SR_COUNT ; iSR++){
      //--- Start with the bit off
      myLev = 0;
      //--- If the value in the sr pin related to this SR/Byte is over the current pwm value
      //     then turn the bit on
      if (srPins[i+(iSR*8)] > myPos)
        myLev = 1;
      //--- Write the bit into the SR byte array
      bitWrite(srVals[iSR],i,myLev );
  //--- Run through all the temporary shift register values and send them (last one first)
  // latching in the process
  latchOff();
  for (int iSR = SR_COUNT-1 ; iSR >= 0 ; iSR--){
    spi_transfer(srVals[iSR]);
  latchOn();
//--- Direct port access latching
void latchOn(){
  bitSet(PORTB,latchPinPORTB);
void latchOff(){
  bitClear(PORTB,latchPinPORTB);
//--- Used to setup SPI based on current pin setup
//    this is called in the setup routine;
void setupSPI(){
  byte clr;
  SPCR |= ( (1<<SPE) | (1<<MSTR) ); // enable SPI as master
  SPCR &= ~( (1<<SPR1) | (1<<SPR0) ); // clear prescaler bits
  clr=SPSR; // clear SPI status reg
  clr=SPDR; // clear SPI data reg
  SPSR |= (1<<SPI2X); // set prescaler bits
  delay(10);
//--- The really fast SPI version of shiftOut
byte spi_transfer(byte data)
  SPDR = data;                    // Start the transmission
  loop_until_bit_is_set(SPSR, SPIF);
  return SPDR;                    // return the received byte, we don't need that
//---- ignore (used for multiplexing but disabled for example)
#define GROUND_1 6
#define GROUND_2 7
//-- end ig
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(GROUND_1, OUTPUT);
  pinMode(GROUND_2, OUTPUT);
  digitalWrite(GROUND_1,LOW);
  digitalWrite(GROUND_2,HIGH);
  //-- end ig
  digitalWrite(latchPin,LOW);
  digitalWrite(dataPin,LOW);
  digitalWrite(clockPin,LOW);
  //--- Setup to run SPI
  setupSPI();
  //--- Activate the PWM timer
  Timer1.initialize(TIMER_DELAY); // Timer for updating pwm pins
  Timer1.attachInterrupt(iProcess);
//--- Sets all the pins to the PWM value passed
void allTo(byte theVal){
  for( int i = 0 ; i < (SR_COUNT*8) ; i++ ){
    srPins[i] = theVal;
//--- Blinks all pins full on and then off.  Total time for blink passed as the duration
void allBlink(int theDuration){
    srPins[i] = 255;
    delay(theDuration/2);
    srPins[i] = 0;
//--- Very simple demo loop
void loop(){
  //--- fade all the pins up
  for( int i = 0 ; i < 256 ; i++ ){
    allTo(i);
    delay(10);
  //--- all off then blink them all quickly
  allTo(0);
  allBlink(150);
  //Note: The below code assumes a common cathode RGB is on the first 595 with R,G,B pins hookedup respectively
  //--- Manually run the first RGB led through a color wheel
  //- Red to Yellow
    srPins[0] = 255;
    srPins[1] = i;
    srPins[2] = 0;
    delay(10);
  //- Yellow to Green
  for( int i = 255 ; i >= 0 ; i-- ){
    srPins[0] = i;
    srPins[1] = 255;
    srPins[2] = 0;
    delay(10);
  //- Green to Cyan
    srPins[0] = 0;
    srPins[1] = 255;
    srPins[2] = i;
    delay(10);
  //- Cyan to Blue
    srPins[0] = 0;
    srPins[1] = i;
    srPins[2] = 255;
    delay(10);
  //- Blue to Majenta
    srPins[0] = i;
    srPins[1] = 0;
    srPins[2] = 255;
    delay(10);
  //- Majenta back to Red
    srPins[0] = 255;
    srPins[1] = 0;
    srPins[2] = i;
    delay(10);
Here is a low quality video showing the code running on 16 RGBs.
Hope this help, let me know if you see any errors or room for improvements.
« Last Edit: July 04, 2010, 08:45:34 am by marklar » Logged
Norway
Offline Offline
Sr. Member
microscopic quantum convulsions of space-time
View Profile
WWW
Nice work!
It might be helpful to link to the library used too? http://www.arduino.cc/playground/Code/Timer1
I haven't tested this, but at least it compiles now smiley
Logged
Florida
Offline Offline
Sr. Member
hookedup!
View Profile
WWW
It will not let me update the original post.
Thanks for pointing to the needed library:
In the future I'll remember to include details about dependent libraries.
Regards
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Excellent, thanks for sharing this. I'm going to be getting some STP04CM05 4-bit shift-register/high current LED drivers in the mail soon, and will try to adapt this code for that application. They also feature cascading so I'm guessing the only trick will be changing any 8-bit references in the code to 4-bits instead.
If this works I will be saving a lot of $ on hardware and a lot of head-banging on circuit design! Before I found the STP04CM05 the only cost-effective solution was a slew of TI PWM multiplexers, hex converters, transistors, and current regulators.
I will definitely buy you a beer in that case.  8-)
Logged
Florida
Offline Offline
Sr. Member
hookedup!
View Profile
WWW
Actually I think you may get away with using this with no modification to the 8 bit vs 4 bit.  The cheep and easy route may be to just cut the number you use in the SR_COUNT variable in 1/2.  So in your case if you have 8 shift registers cascaded, you would set SR_COUNT to 4 to equal the same number of pins.
Try that first and see if everything else just works for you (it may).
The reason is because you will most likely end up wanting to combine 4 bits of data together in pairs to equal a byte, but having a even number of 4 bit SRs makes it work just like an 8 bit SR.
Someone chime in here if I am bass ackward on this one please.
Cheers
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks for the suggestion, halving the SR_COUNT worked perfectly. So far I haven't had to make any other adjustments to the code for it to work with the STP04CM05.
Logged
Florida
Offline Offline
Sr. Member
hookedup!
View Profile
WWW
That is great to know.  I am interested in seeing your final project if it is something you can show.
Always nice to see another way to make these LEDs go smiley
« Last Edit: August 05, 2010, 07:20:30 pm by marklar » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Definitely, a partner and I are working on using an Arduino to control a series of these ICs which are driving 12 high power 3W RGB LEDs mounted in polycarbonate tubes, and a series of RGB strobes in addition. We should have MIDI sync with Ableton Live and full manual control as well. We're trying to get it finished for a music festival in Raleigh next month, I'll be sure to post some videos when it's completed.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
So we completed our project in time for its debut at Hopscotch Music Festival, which was Raleigh's first major music festival. We provided the stage lighting for Motor Skills, whose performance was well-received.
I don't have any HD video yet, but here's some taken from an iPhone:
Edit - better video in HD:
The system is as described above; a Processing sketch handles MIDI input and generates the pattern data, which is communicated over serial to the Arduino. Using the SoftPWM code we control a custom PCB with 12 of the STP04CM05 ICs and all the other requisite circuit components. These are connected to the light bars via CAT5 cables through a 12-port patch panel. Finally the light bars consist of a high-power 3W RGB LED, some optics, and other various parts for optimum beam spreading and heat management.
This software PWM implementation worked excellently for the job, so thanks again. I probably wouldn't have attempted soft PWM if you hadn't posted this. Using your code on an Arduino with an Atmega328, we were able to get 128 brightness levels per channel before seeing noticeable flicker, which works well except for the lowest brightness levels. I think a resolution of at least 8x higher is necessary for better dimming, logarithmic brightness, and good color mixing at low brightness. I doubt that could ever be squeezed out of the Atmega328, however.
Perhaps you could formalize your code into a library for better accessibility to people getting started? It seems fairly optimized already what with all the bitwise operations.
« Last Edit: October 04, 2010, 12:13:19 pm by PostOfficeBuddy » Logged
Florida
Offline Offline
Sr. Member
hookedup!
View Profile
WWW
Thank you very much for letting me know the code helped and for posting your video.  Nice work!
I was thinking of using a library when I created the code but was not sure what to put into "library form".  Most of my libraries are class based and it seemed to over complicate the implementation / usage to create a class for this operation.   Maybe I'll just post the code in the playground so it won't get lost in forum land.
I currently do not use this type of process anymore so I figured I put up the cleaner code before it went into the big box with all my shift registers and raw LEDs.  Now that I see it is useful, posting it on the playground is a good idea.
I'll have to re-look at that chip you are using after seeing your results.  I may need similar caps to run the SMD strips since the TLCs are giving me a headache.
Thanks again for responding with your results and for posting the video of your nice light show.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hello,
I am woking on a similar thing and found your code very helpful. The problem i encountered was that Arduino could not do more than a few 595s with 256 levels an decent 90hz refresh rate.
i implemented bit angle modulation and precalculation of the 595 data to save even more time. It uses SPI and Timer3.
All feedback and improvements are wellcome. I think we could make this thing into a library and call it "LED595" or something.
-------------------------PART1------------------------------------
Code:
 This code drives leds using daisy chained 595 shiftregisters.
 Two different drive methods:
 PWM - just workks with 32 PWM levels, 6 registers and 90 HZ
 BAM - works for lot more with 256 PWM levels
 Todo:
 1) Precalculate the data for 595 always when PWM levels are changed. This should speed
 up the interrupt.
 2) Change the interrupt so that it is called only when needed by changing the interrupt time
    on every call. Dunno if this is necessary, the interrupt exists just after a few ifs if nothing
    need to be updated.
    Tomas Martinsen 29 Sep 2010
 Lot of code from:
 Created 22 May 2009
 Created 23 Mar 2010
 by Tom Igoe
#include <SPI.h>
#include <TimerThree.h>
// Pins on arduino mega
//Pin connected to latch pin (ST_CP) of 74HC595
const int latchPin = 53;
//Pin connected to clock pin (SH_CP) of 74HC595
const int clockPin = 52;
////Pin connected to Data in (DS) of 74HC595
const int dataPin = 51;
// constants
#define PWM_FREQ 100 // hz
#define PWM_STEPS 256 // PWM resolution - set to 256 when using bam
#define BAM_STEPS 8 // how many times BAM updates are done each cycle
#define TICKER_STEP 256/PWM_STEPS
#define NUM_SHIFT_REGS 6
#define NUM_CHANNELS NUM_SHIFT_REGS*8
// Global variables
// holds the current pwm values of pins to be sent by interrupt
volatile unsigned char pwmValues[NUM_CHANNELS];
volatile byte bamLookup[BAM_STEPS*NUM_SHIFT_REGS]; // precalculate the bytes to send every time the PWM values change
volatile byte pwmLookup[PWM_STEPS*NUM_SHIFT_REGS];// precalculate the bytes to send to 595 for pwm
  Precalculate the bytes to send for every PWM cycle. Note that this is not fast either!
void precalcPwmBytes() {
  byte bytesToSend[NUM_SHIFT_REGS];
  for(int ticker = 0;ticker<PWM_STEPS;ticker++){
    byte myPos = ticker * TICKER_STEP;
    // generate one byte per register
    for(byte regNo = 0 ;regNo<NUM_SHIFT_REGS;regNo++) {
      bytesToSend[regNo]  = 0;
      // loop bits of each register
      for(byte ch = 0;ch<8;ch++){
        if(myPos <= pwmValues[regNo*8+ch]) {
          // turn on channel 0-7
          bytesToSend[regNo] |= (1 << ch);
      pwmLookup[ticker*NUM_SHIFT_REGS + regNo] = bytesToSend[regNo];
  Precalculate the bytes to send for each time slice. Call everytime you update or change
  pwmvalues.
void precalcBamBytes() {
  for(int slice=0;slice<BAM_STEPS;slice++) {
    unsigned char sliceMask = (1 << slice);
    for(unsigned char regNo = 0 ;regNo<NUM_SHIFT_REGS;regNo++) {
      for(unsigned char ch = 0;ch<8;ch++){
        // test if the pwm value has the current slicebit 1
        if( (pwmValues[regNo*8+ch] & sliceMask) == sliceMask) {
      bamLookup[slice*NUM_SHIFT_REGS + regNo] = bytesToSend[regNo];
// the current data that has last been sent to shift registers
//byte *shiftRegValues;
// interrupt counter
volatile byte ticker = 0;
  //set pins to output because they are addressed in the main loop
  // serial communication to 595s
  SPI.begin();
  SPI.setClockDivider(SPI_CLOCK_DIV2);
  // Activate the interrupt
  // calculate how many times per sec the ISR ISR is called
  // to get the requested pwm frequency
  Timer3.initialize(1000000/PWM_FREQ/PWM_STEPS); // Timer for updating pwm pins
  Timer3.attachInterrupt(iUpdateBAM3);
  // for debugging
  // signal the setup is done
  for(int i=0;i<NUM_CHANNELS;i++){
    setChannel(i,255);
    delay(50);
  for(int i=NUM_CHANNELS-1;i>0;i--){
    setChannel(i,0);
    delay(50);
  setAllChannelsTo(0);
  // test dimming
  int from = 0;
  int to = 255;
  int d = 10;
  for(int i = from;i<to;i++) {
    setAllChannelsTo(i);
    delay(d);
  Sends a byte array using SPI to 595 shift registers
void sendSPI(volatile byte *valuesToSend, int from, int to) {
  // latch off
  digitalWrite(latchPin, LOW);
  // send bytes the last register first
  for(int i = to-1; i>=from;i--) {
    SPI.transfer(valuesToSend[i]);
   // latch on
  digitalWrite(latchPin, HIGH);
void setAllChannelsTo(byte duty) {
  for(int i = 0;i<NUM_CHANNELS;i++) {
    pwmValues[i] = duty;
  precalcBamBytes();
  //precalcPwmBytes();
void setChannel(int ch,byte duty) {
  pwmValues[ch] = duty;
  precalcBamBytes();
 Pulse Width modulation. Pretty slow. The limit is about 6 shift registers, 32 steps and 90hz. Not Good!
void iUpdatePWM() {
  byte valuesTmp[NUM_SHIFT_REGS];
  // update ticker and reset if rolls over
  ticker++;
  if(ticker > PWM_STEPS) {
    ticker = 0;
    valuesTmp[regNo]  = 0;
        valuesTmp[regNo] = valuesTmp[regNo] | (1 << ch);
  // update registers
  sendSPI(valuesTmp,0,NUM_SHIFT_REGS);
 Pulse Width modulation. This one uses precalculated values.
 This one can do 6 registers, 256 levels and 100 hz.
void iUpdatePWM2() {
  ticker++;
    ticker = 0;
  // update registers. The lookup table is recalculated always when setting pwm values.
  sendSPI(pwmLookup,ticker*NUM_SHIFT_REGS,ticker*NUM_SHIFT_REGS + NUM_SHIFT_REGS);
  Bit Angle modulation. This version has a problem:
  When the slice hits and we do send data, the function takes too long to execute.
  The result is that all ticks are not of equal length and the brightness depends also on
  how many bits are 1. The result is that 7 is brighter than 9 and 15 brighter than 16.
  Not good for dimming!
void iUpdateBAM() {
  ticker++;
    ticker = 0;
  // find out timeslice startpoint we are at
  unsigned char slice;
  if(ticker == 0) {
    slice = 0;
  else if(ticker == 1) {
    slice = 1;
  else if(ticker == 3) {
    slice = 2;
  else if(ticker == 7) {
    // B3 - 8 long
    slice = 3;
  else if(ticker == 15) {
    slice = 4;
  else if(ticker == 31) {
    // B4 - 16 long
    slice = 5;
  else if(ticker == 63) {
    // B6A - 32 long
    slice = 6;
  else if(ticker == 127) {
    // B7a - 32 long
    slice = 7;
  else {
    // no actions required
    return;
  // update registers
  sendSPI(bytesToSend,0,NUM_SHIFT_REGS);
  Bit Angle modulation. Faster version that uses precalculated data for each slice.
  Mighty fast compared to the other version.
  TODO:
  Split slice 6 to 2 parts slice 7 to 4 parts and interleave to avoid flicker.
void iUpdateBAM2() {
  ticker++;
    ticker = 0;
  if(ticker == 0) {
    slice = 0;
    slice = 1;
    slice = 2;
    // B3 - 8 long
    slice = 3;
    slice = 4;
    // B4 - 16 long
    slice = 5;
    // B6A - 32 long
    slice = 6;
    // B7B - 32 long
    slice = 7;
  else {
    return;
  sendSPI(bamLookup,slice*NUM_SHIFT_REGS,slice*NUM_SHIFT_REGS + NUM_SHIFT_REGS);
---------------------------   TO BE CONTINUED -------------------------
« Last Edit: October 03, 2010, 08:28:16 pm by tmartins » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
And the rest of the code:
Code:
  This fersion also divideds
  the bits 6 and 7 to 32 tick slices to smoothen the transitions over 126->127
void iUpdateBAM3() {
  ticker++;
    ticker = 0;
  if(ticker == 0) {
    slice = 0;
    slice = 1;
    slice = 2;
    // B3 - 8 long
    slice = 3;
    // B5 - 32 long
    slice = 5;
  else if(ticker == 47) {
    // B4 - 16
    slice = 4;
    // B7A - 32 long
    slice = 7;
  else if(ticker == 95) {
    // B6A - 32 long
    slice = 6;
    // B7B - 32 long
    slice = 7;
  } else if(ticker == 159) {
    // B6B - 32 long
    slice = 6;
  }else if(ticker == 191) {
    // B7C - 32 long
    slice = 7;
  } else if(ticker == 223) {
    // B7D - 32 long
    slice = 7;
  else {
    return;
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Tomppu, this is great. The speed limitations were the biggest difficulty with the previous version of the code.
I was controlling 30 channels, with their values being updated over serial at about 50hz. So I would still be calling precalcBamBytes() around 1500 times per second. Is it possible to only call precalcBamBytes() once after updating all 30 channels with setChannel()? That would reduce it to about 50 calls per second.
Also, what is the difference between the iUpdateBam 1, 2, and 3 functions? It seems that version 3 is the superior version. Is there any reason to leave the other two in the code, possibly just to provide an example?
Finally, is it possible to increase the PWM resolution above 256 levels? Possibly 1024 levels, or higher? This would make something like brightness calibration with a logarithmic curve (gamma correction) possible.
I will give your code a try, if I don't see any bugs then it will go into production. If you know of or notice any bugs please let us know in this thread, I would also be willing to help finalize the code and make this into a library like ShiftOut so that more people can take advantage of it. That is, after I wrap my head around bit angle manipulation...
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks for the compliments smiley. I did a lot of digging on the internet about Bit Angle Modulation and i found something but nothing ready for Arduino. You had nice working code base where to start experimenting.
The code there is work in progress and i suggest we play with it a bit and then pack it as a library for others to use and improve. A lot of people seem to like driving leds with Arduino.
I even tried the propeller chip that packs a nice punch with 8 cores but found learning the spin language too akward and "specialised" compared to standard c++.
I also tried TLC5940 but they cost money, and cannot drive hight currents so real room lighting is out of question. I got them working and burned quite few of them smiley-grin.
The best was to use cheap 595 and try to run them with software. This is also simple and easily understandable. But PWM is too processor intensive. Even BAM took too much processor without the precalculation of the bits.
I also think that there should be at least 256 levels. Otherwise the steps are noticable with low intensities. 10 bits would be nice.
Feel free to try addning more levels, just speed up the interrupt 4 times and count to 1024 and do the same stuff. Should still work.
I also found a working solution for driving the high power leds with 2 resistors, a transistor and a fet. A simple circuit that limits the current for the led. It can handle huge currents, several A, no problem. Only downside is that the fet costs about 0.5-1eur / piece. If somebody could come up with something that does not need the FET.
Then the functions:
1st try: BAM1 without precalculation. My version is too slow, it does not get out of the interrupt fast enough.
2nd try: BAM2 preconstruct the bytes to be sent. Recalculate only when dutys change. Nice but still some flicker when fading. You can find the reason from google.
3rd Try. BAM3 precalculate AND reorder and split the bits 7 and 8 to smaller 32 tick pieces to make transition form say 127 to 128 smoother. Still needs some improvement. Have to think a bit smiley
4th: PWM2 interrupt works fine but the precalculation is too slow for my taste. About 8000 iterations with 48 channels and 256 levels. Optimise?
TODO:
-get rid of the flicker in BAM3 when fading.
-Maybe optimise the precaculation loops. Ideas?
-include a gammacorrection lookup table the make fades smooth.
-improve the interrupt in BAM so that the interrupt is not entered regularly but only when needeed. I think though that it gets out of there fast enought when nothing needs to be done.
-some animation and pattern stuff
--frame playing
--timed transitions
Just keep your ideas coming and i'll keep mine smiley-grin
Happy hacking!
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
And sure the precalculation can be optimised. So that it is only done when you have set all the new channel values you are going to set at one time.
Idea:
make so that you call many setChannels functions and whatever and AFTER you are ready. Call a function that does the precalculation only once.
Post back if get working code!
Logged
Pages: [1] 2   Go Up
Print
Jump to:
