Topic: Is there a way to save data inputed into Arduino? (Read 13835 times) previous topic - next topic
CMStrawn
I have a barometer hooked up and running. The issue I am having is that every time you turn it on or hit reset you need to recalibrate it. Is there any way to save data onto the board so that after reset or turn on it runs up the program and then grabs the saved data as well?
I'm using the Duemilanove board and the data I need to save is in the form of a double.
Any help would be appreciated, it's for a class project.
Thanks.
Coding Badly
#1
Jan 24, 2011, 04:30 am Last Edit: Jan 24, 2011, 04:31 am by bcook Reason: 1
EEPROM...
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1234477290/3#3
CMStrawn
Thanks. I'll go through all that code and see if I can figure it out. It looks really complicated. lol
CMStrawn
Is there any way to get some comments? Or explanation on what's going on? I thought I had it but can not figure it out.
Code: [Select]
#include <EEPROM.h>
template <class T> int EEPROM_writeAnything(int ee, const T& value)
   const byte* p = (const byte*)(const void*)&value;
   int i;
   for (i = 0; i < sizeof(value); i++)
       EEPROM.write(ee++, *p++);
   return i;
template <class T> int EEPROM_readAnything(int ee, T& value)
   byte* p = (byte*)(void*)&value;
   int i;
       *p++ = EEPROM.read(ee++);
   return i;
Code: [Select]
// include the above EEPROM functions
struct st_t { long lo; byte by; double db; };
   int n = 0;
   byte by = 0x33;
   Serial.println(by, HEX);
   n = EEPROM_writeAnything(0, by);
   Serial.print("Wrote bytes: ");
   Serial.println(n);
   by = 0xFF;
   n = EEPROM_readAnything(0, by);
   Serial.print("Read bytes: ");
   Serial.println(n);
   Serial.println("-------");
   long lo = 0xDEADBEEF;
   Serial.println(lo);
   n = EEPROM_writeAnything(23, lo);
   Serial.println(n);
   lo = 0xFFFFFFFF;
   Serial.println(lo);
   n = EEPROM_readAnything(23, lo);
   Serial.println(n);
   Serial.println(lo);
   double pi = 3.1415926538;
   struct st_t st;
   st.lo = 0xABADF00D;
   st.by = 0x22;
   st.db = pi;
   Serial.println(st.lo);
   Serial.println(st.by, HEX);
   Serial.println(st.db == pi);
   n = EEPROM_writeAnything(221, st);
   Serial.println(n);
   st.lo = 0xFFFFFFFF;
   st.by = 0x11;
   st.db = 0.0;
   n = EEPROM_readAnything(221, st);
   Serial.println(n);
Coding Badly
CMStrawn
Thanks so much!! I'm still not sure what's going on there in the code, but I have it working in my code! Thanks so much for that. Now I just need to understand that code. lol
