Loading...
Pages: [1]   Go Down
Author Topic: send byte array via com  (Read 3304 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I want to send via com from PC(C# application) array of byte (100 elements in array), what is the best method for do this ?
I tray do it in loop, but something is wrong becuse when i read message from arduni i take result that when I send example arrayExampe[30]=220, i receive from arduino message that he has 3 elements 2,2,0.
here is code in PC:
Code:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.IO.Ports;
namespace WindowsFormsApplication1
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void button1_Click(object sender, EventArgs e)
            byte[] arrByte= new byte[96]{1, 1, 1, 1, 1, 1, 1, 1,1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,  1, 1, 1, 1, 1, 1, 1, 1,1, 16, 32, 55, 80, 110, 140, 190,190, 190, 190, 190, 190, 190, 190, 190,190, 190, 190, 190, 190, 190, 190, 190,190, 190, 190, 190, 190, 190, 190, 190,190, 190, 190, 190, 190, 190, 190, 190,190, 190, 190, 190, 190, 190, 190, 190, 190, 110, 90, 70, 55, 32, 16, 1, 1, 1, 1, 1, 1, 1, 1, 1};
            SerialPort port = new SerialPort("COM5", 9600, Parity.None, 8, StopBits.One);
            port.ReadBufferSize = 128;
            port.Open();
            string read;
            for (int i = 0; i < arrByte.Length; i++)
                port.Write(arrByte[i].ToString());
                read = port.ReadLine();
                textBox1.Text = textBox1.Text + read+", " + "\r\n";
                port.Write(",");
           port.Close();
Here us Arduino simple program:
Code:
byte incomingByte = 0;      // for incoming serial data
      Serial.begin(9600);      // opens serial port, sets data rate to 9600 bps
      // send data only when you receive data:
      if (Serial.available() > 0) {
            // read the incoming byte:
            incomingByte = Serial.read();
            // say what you got:
            Serial.print("I received: ");
            Serial.println(incomingByte);
Thanks for answers.
best regards
malin
Logged
Pages: [1]   Go Up
Print
Jump to:
