Topic: Arduino dll? (Read 6856 times) previous topic - next topic
kersny
I thought that a good project that could benefit the community would be to create a dll(VC#?) that would allow an arduino running the serialio firmware to act as a k8055 board. The K8055 is a usb board with 5 digital inputs, 8 digital outputs, 2 analog inputs, and 2 analog outputs. The Arduino board fists most of these specifications, and is much less expensive. If I am correct, all it would require would be making a class in VC# with the same functions as the dll(Found on velleman's site), only converting the commands to serial commands and sending them to the arduino.
Links:http://www.velleman.be/ot/en/product/view/?id=351346 K8055 board
       http://userwww.sfsu.edu/~infoarts/technical/arduino/wilson.arduinoresources.html Arduino Firmware
       http://www.vellemanusa.com/us/enu/download/files/ vellman dll and examples
I've started working on it, and I was wondering if anyone had any experience in making DLL files.
tvdbon
This looks pretty interesting. I can help you with the dll. But do you really want to make it act exactly like the k8055 board ? I mean is the point to create a drop in replacement ?
MikMo
I think it would be a nice ida to make a DLL / class / component for general .net interfacing Arduino.
I have toyed with the thought for a while, but i simply do not have the time to throw at it for the moment.
coleoptero
#3
Jun 11, 2008, 02:38 am Last Edit: Jun 11, 2008, 02:39 am by coleoptero Reason: 1
Do you know the project MyOpenLab?
MyOpenLab uses dll to k8055 of Velleman.
The author has also integrated Arduino (and Arduclema) libraries using serial communication.
It may be interesting to create a dll to be used by MyOpenLab. You can also comment on the forums of the project MyOpenLab.
We also want to program graphically Arduino (and Arduclemas;)) from MyOpenLab through Java.
Greetings.
cOLe.
Consejos para hacer un correcto uso de los foros.
http://arduino.cc/playground/Es/Consejos
tvdbon
Greetings.
cOLe.
Pretty interesting. I think I'll have alook into creating a dll this weekend.
