Author Topic: Decimal number on a 4x20 Hitachi LCD  (Read 451 times)
Sweden, Malmö
Rooky
So i need to display a decimal value on a Hitachi LCD in 4 bit mode.
Have been reading true some old posts using the search function but can not find a complete and proper code example. Or at least not one i can understand, sorry...
So i am reading a value from a analog port from 0-1023 and want convert and display that in volts with at least two decimals such as example 4,54 volts.
Well, never mind the converting part, just need to understand what is needed to print the decimal form of value.
Is it possible to do with allready existin library such as the neillzero library?
I did manage to do that with serial communication, see code example below.
int analogPin = 0;
double z;
void printDouble( double val, unsigned int precision){
    Serial.print (int(val));  //prints the int part
    Serial.print("."); // print the decimal point
    unsigned int frac;
    if(val >= 0)
      frac = (val - int(val)) * precision;
       frac = (int(val)- val ) * precision;
    int frac1 = frac;
    while( frac1 /= 10 )
        precision /= 10;
    precision /= 10;
    while(  precision /= 10)
        Serial.print("0");
    Serial.println(frac,DEC) ;
void  setup(){
 void loop(){
     z = analogRead(analogPin) * 0.00491;
     printDouble(z,100);  // two decimal places
     delay(100);
By the way, not my code for the decimal handling, thank you who ever it was i stole it from  smiley-grin.
« Last Edit: August 07, 2008, 01:20:13 pm by HULK » Logged
Sweden, Malmö
Rooky
I can see that it is possible and that it is done in the code below, but can not understand the logic in it
/* Analog in to LCD 4 bits
 * Adapted from the "analog_read_send" and "lcd_8bits" tutorials.
 * This example uses 4 less pins on the Arduino than the 8 bit example.
 * It will take a reading from a 'K' Type thermocouple ice point reference chip
 * on Analog Input 2 and display the temperature in degrees Centigrade on the LCD.
 * One can also set a target temperature for turning a relay off, say for a heater,
 * at a given setpoint temperature. This is done on digital pin 4.
 * These are the pins used on the LCD:
 * - DI(register select), RW, DB4..DB7, Enable (7 in total)
 * the pinout for LCD displays is standard and there is plenty
 * of documentation to be found on the internet.
 * 2006, Dave Sopchak  glasspusher at outofoptions dot net
int DI = 12; // register select
int RW = 11;
int DB[] = {7, 8, 9, 10};
int Enable = 6;
int temperaturePin = 2;    // select the input pin for the temperature
int ledPin = 13;           // pin for the LED
void tickleEnable()
 // send a pulse to enable
 digitalWrite(Enable,HIGH);
 delayMicroseconds(1);  // pause 1 ms according to datasheet
 digitalWrite(Enable,LOW);
void cmdWriteSet()
  digitalWrite(DI,0);
  digitalWrite(RW,0);
void LcdCommandWrite(int value)
 int i = 0;
  for (i=DB[3]; i >= DB[0]; i--) // high nybble first
    digitalWrite(i, value & 128);
    value <<= 1;
    cmdWriteSet();
    tickleEnable();
  for (i=DB[3]; i >= DB[0]; i--) // low nybble next
    value <<= 1;
    cmdWriteSet();
    tickleEnable();
void LcdDataWrite(int value)
 int i = 0;
 digitalWrite(DI, HIGH);
 digitalWrite(RW, LOW);
    value <<= 1;
    tickleEnable();
    value <<= 1;
    tickleEnable();
void setup (void)
 int i;
 for (i=Enable; i <= DI; i++)
   pinMode(i,OUTPUT);
 delay(100);
 // initiatize lcd after a short pause
 // needed by the LCDs controller
 LcdCommandWrite(0x28);  // function set:
  delay(64);             // 4-bit interface, 2 display lines, 5x7 font
                        // other interaces:
                        // 0x20 = 4 bit, 1 display line
  LcdCommandWrite(0x06);  // entry mode set:
                        // increment automatically, no display shift
 delay(20);
 LcdCommandWrite(0x0E);  // display control:
                        // turn display on, cursor on, no blinking
 delay(20);
 LcdCommandWrite(0x01);  // clear display, set cursor position to zero
 delay(100);
 LcdCommandWrite(0x80);  // display control:
 delay(20);
void loop (void)
  int i, val = 0;
  for(i = 0; i < 20; ++i)
       val += analogRead(temperaturePin);    // read the value from the sensor
       delay(50);
  val /= 4.06;      // conversion value to millivolts
  digitalWrite(ledPin, HIGH);  // turn the ledPin on
  delay(500);                  // stop the program for some time
  digitalWrite(ledPin, LOW);   // turn the ledPin off
  if(val > 175 * 10)   // temperature in deg C times 10, since we're measuring to tenths of a degree
     digitalWrite(4,LOW);
     digitalWrite(4,HIGH);
    LcdCommandWrite(0x02);  // set cursor position to zero
  delay(10);
  firstDisplay(val);
void firstDisplay(int value)
  int first,second, third, fourth;
  first = value / 1000;    //
  second = (value - 1000 * first)/ 100;
  third = (value - 1000 * first - 100 * second)/ 10;
  fourth = (value - 1000 * first - 100 * second - 10 * third);
     LcdDataWrite('T');
     LcdDataWrite('e');
     LcdDataWrite('m');
     LcdDataWrite('p');
     LcdDataWrite(' ');
     LcdDataWrite('=');
     LcdDataWrite(' ');
     LcdDataWrite(value > 999 ? first + 48 :  ' ');  // begin onscreen
     LcdDataWrite(value > 99 ? second + 48 : ' ');
     LcdDataWrite(third + 48);
     LcdDataWrite('.');
     LcdDataWrite(fourth + 48);
     LcdDataWrite(' ');
     LcdDataWrite('C');
     LcdDataWrite(' ');
     LcdDataWrite(' ');
Have also found the command "itoa()" but can it be used with decimals?
London
Have fun!
Here is my version.
I used a later version of the printDouble code, note that the second argument is a little different. No problems borrowing it, that's what I posted it for  smiley-wink
void printInt(long n){
   byte buf[10];  // prints up to 10 digits
   byte i=0;
   if(n==0)
         lcd.print('0');
   else{
       if(n < 0){
        lcd.print('-');
            n = -n;
     while(n>0 && i <= 10){
         buf[i++] = n % 10;  // n % base
         n /= 10;   // n/= base
       for(; i >0; i--)
             lcd.print((char) (buf[i-1] < 10 ? '0' + buf[i-1] : 'A' + buf[i-1] - 10));
void printDouble( double val, byte precision){
  // prints val with number of decimal places determine by precision
  // precision is a number from 0 to 6 indicating the desired decimial places
  // example: printDouble( 3.1415, 2); // prints 3.14 (two decimal places)
  printInt( (long)val);  //prints the int part
  if( precision > 0) {
    lcd.print('.'); // print the decimal point
    unsigned long frac;
    unsigned long mult = 1;
    byte padding = precision -1;
    while(precision--)
       mult *=10;
    if(val >= 0)
      frac = (val - int(val)) * mult;
      frac = (int(val)- val ) * mult;
    unsigned long frac1 = frac;
      padding--;
    while(  padding--)
      lcd.print('0');
    printInt(frac) ;
« Last Edit: August 07, 2008, 01:38:16 pm by mem » Logged
London
Have fun!
void firstDisplay(int value)   // gets a floating point of form xxx.y as xxxy
     LcdDataWrite('T');
     LcdDataWrite('e');
     LcdDataWrite('m');
     LcdDataWrite('p');
     LcdDataWrite(' ');
     LcdDataWrite('=');
     LcdDataWrite(' ');
     LcdDataWrite('.');
     LcdDataWrite(' ');
     LcdDataWrite('C');
     LcdDataWrite(' ');
     LcdDataWrite(' ');
That code works by multiplying the floating point value by ten, printing all but the last digit, printing a decimal point, and then printing the last digit (which was the value in tenths before it got multiplied.
The code in my previous post is a little more flexable
« Last Edit: August 07, 2008, 01:36:56 pm by mem » Logged
Sweden, Malmö
Rooky
Mem,
I am trying to run your code but can not really get what command i should use in the void loop() area to print a value?
This value will not be constant by the way.
London
Have fun!
try:
 void loop(){
     float z = analogRead(analogPin) * 0.00491;
     printDouble(z,4);  // four decimal places
     delay(100);
« Last Edit: August 07, 2008, 02:33:28 pm by mem » Logged
Sweden, Malmö
Rooky
Your code works fine, but i am finding it hard to tun it with the If comando.
Listed code below will allways print the c value when executing the if comando. It will never see p as greater then c.
Something i am missing ?
  float c = analogRead(analogPin0) * 0.00491;
  lcd.cursorTo(1,6);
  printDouble(c,2);
if (c > p){
  lcd.cursorTo(1,16);
  printDouble(c,2);
  float p = c;
« Last Edit: August 09, 2008, 11:15:52 am by HULK » Logged
London
Have fun!
You need to move the  float p = c outside the if statement
either outside the loop function (its then a global variable) or if declared just after the start of the loop function, make it static:
static float p;
  (existing code here...)
  p = c;
Sweden, Malmö
Rooky
Yes, finally i sorted that out thanks to your help Mem.
But i had to do it with p=c inside the statement, otherwise it would after two seconds again not see p as greater then c. So my code ended up like this and works great now.
  static float p;
  lcd.cursorTo(1,6);
  printDouble(c,2);
  if (c > p){
  lcd.cursorTo(1,16);
  printDouble(c,2);
  p= c;
London
Have fun!
The code you posted is what I was suggesting, Good to hear you have it working now.
Denmark
 Hey HULK..
Tack for linket til denne side, men jeg fatter intet af hvor den kode skal ind for at få mit til at virke, som jeg skrev i den anden tråd har jeg ingen programmeringserfaring !?!
Hvad bruger du denne kode til, jeg skal bruge den til en akvariecomputer..
Sweden, Malmö
Rooky
Solow,
Let us do this in English so more people will get a way of reading and also correcting there code if needed.
Remember that this code was created by Mem and i only adapted it to my code so that i could print the turbo presure decimal number on a LCD.
So try to enter this code in the setup area or just before so the doublePrint function will work, this will print a number in a decimal form.
   byte i=0;
   if(n==0)
         lcd.print('0');
   else{
       if(n < 0){
        lcd.print('-');
            n = -n;
       for(; i >0; i--)
    unsigned long frac;
    while(precision--)
       mult *=10;
    if(val >= 0)
      padding--;
    while(  padding--)
      lcd.print('0');
    printInt(frac) ;
Then use printDouble command in the loop area.
  float c = analogRead(analogPin0) ; //reading the value from a analog pin
  lcd.cursorTo(1,6); //adjust it to your position
  printDouble(c,2);
Try it out, remember that i also am a rooky on this and that i did a lot of try and error before geting it right.
Hope it works.
If not Post your code and maybe we can get right in the end.
