Topic: Timer on a KS0108 display (Read 812 times) previous topic - next topic
HULK
Just wanted to share a timer code that will display in the right lower corner.
Good to have if you want to keep track of the time passed from start up in a application.
Will show, hh:mm:ss
I did found that it only will count up to 27 hours something before it goes from 00:00:00 again, hopefully 27 hours timers will be good enough for people.
And yes, the code is far from perfect but it works.
The time code was found on the forum, thanks to the man that created that.
To get more informtion on the used ks0108 library and set up check:
http://www.arduino.cc/playground/Code/GLCDks0108
Code for clock math to be added before void setup
unsigned long current_millis_value = 0;
unsigned long previous_millis_value = 0;
unsigned long m = 0;
unsigned int seconds = 0;
unsigned int minutes = 0;
unsigned int hours = 0;
Code for clock math to be added in void loop
 current_millis_value = millis();
 m += current_millis_value - previous_millis_value;
 seconds += m / 1000;
 m = m % 1000;
 minutes += seconds / 60;
 seconds = seconds % 60;
 hours += minutes / 60;
 minutes = minutes % 60;
 hours = hours % 24;
 previous_millis_value = current_millis_value;
Code for displaying clock to be added in the void loop
GLCD.FillRect(110, 47, 14, 10, WHITE);
 if (seconds < 10){
 GLCD.GotoXY(117, 47);
 GLCD.PrintNumber(seconds);
 GLCD.GotoXY(110, 47);
 GLCD.Puts("0");
 else {
 GLCD.GotoXY(108, 46);
 GLCD.Puts(":");
 GLCD.FillRect(94, 47, 13, 10, WHITE);
 if (minutes < 10){
 GLCD.GotoXY(101, 47);
 GLCD.PrintNumber(minutes);
 GLCD.GotoXY(94, 47);
 GLCD.Puts("0");
 else {
 GLCD.GotoXY(92, 46);
 GLCD.Puts(":");
 GLCD.FillRect(78, 47, 13, 10, WHITE);
 if (hours < 10){
 GLCD.GotoXY(85, 47);
 GLCD.PrintNumber(hours);
 GLCD.GotoXY(78, 47);
 GLCD.Puts("0");
 else {
