Topic: Make Arduino execute commands on computer? (Read 12212 times) previous topic - next topic
computer_freak_8
Hello,
I was wondering if there is some way that I can have my Arduino Duemilanove execute commands on my computer (which is running Ubuntu 8.04.1 amd64).
I think I've got down the parts dealing with how to handle input, so I don't think I need help there. I was just wondering if there is some way to have the Arduino, for example, run a command when a button attached to it is pressed, but have the command execute on the computer.
Anachrocomputer
The Arduino's processor cannot directly invoke commands on the host (whether it's Linux, Windows or MacOS).  But, a program running on the host can accept characters over the serial connection (via USB), which can then trigger actions on the host such as, running commands.
This kind of program on the host is sometimes called a proxy.
computer_freak_8
Thanks for the response. I looked around after I saw your post, and I can't seem to find any clear tutorials for this.
I downloaded the proxy software for Linux from the Arduino website, but I don't know how to use it to execute commands on my computer. If I could even get enough information to run one command when a button connected to the Arduino is pressed, I think I'd be set.
Any links to good tutorials for this?
Thanks,
computer_freak_8
kg4wsv
A quick and very dirty method would be to redirect bash's input from the Arduino's serial port, e.g.
bash$ bash -v  </dev/tty.USB0
the -v option will make bash echo the commands being executed.
-j
that_chap
Quote
Can't help much on the Linux specifics, but one preliminary is to sort out exactly what commands you want to issue. That is independent of getting that command triggered somehow.
If you can't do what you want from the Ubuntu command line, then I can't see how you can get it done from an external trigger.
Then you need a program running on your Ubuntu machine that can
a - get stuff from the serial port (ie the Arduino)
b - if needed, interpret that stuff
and c - issue the appropriate command
This means a bit of programming in a some sort of 'proper' language.
For all I know, you might even be able to achieve what you want entirely with a shell script...
But it seems PERL might be a better choice than PHP -
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1208451736/6#6
The Mac has AppleScript, which allows messages to be passed to running programs -- as well as starting or quitting programs.
Massimo Banzi himself has released a miniature Mac app that takes individual characters from a serial port (ie an Arduino) and uses them to trigger whichever of the AppleScripts written by the user
http://tinker.it/now/2007/04/26/control-your-mac-from-arduino-the-easy-way/
More generally for Mac, SerialPort X makes serial ports (like the one hooked up to the Arduino) fully available to AppleScript.
http://mysite.verizon.net/vzenuoqe/MacSoft.html
And I'm sure there are lots of other tools available!
Does Ubuntu have an analogue of AppleScript? Sorry, I don't know of one.
Naturally, you also need to have an Arduino setup to send the expected data or commands up the wire to the computer. (Beware the unexpected!)
Like I said, sorry I can't help with the Linux detail, but hopefully I've outlined the sort of thing you need to be aiming for!
gnu_linux
#5
Jan 12, 2009, 01:25 am Last Edit: Jan 12, 2009, 01:34 am by gnu_linux Reason: 1
I would echo what Anachrocomputer and kg4wsv suggested :)
You can use Perl and Device::SerialPort to communicate with your arduino and then system("$command"); based on what the arduino sends on the serial port
You can do the same thing with Python and a variety of other languages
Code: [Select]
#!/usr/bin/perl
use Device::SerialPort;
my $port = Device::SerialPort->new("/dev/ttyUSB0");
$port->databits(8);
$port->baudrate(9600);
$port->parity("none");
$port->stopbits(1);
$number_of_chars_to_read=1;
$command0="mplayer video.ogv";
$command1="mplayer aud.mp3";
$time="1";
while(my $code=$port->read($number_of_chars_to_read))
print "$code";
system("$command0") if($code eq "a");
system("$command1") if($code eq "b");
Code: [Select]
// logic
int char = 97;
Serial.print(char);
// prints the ASCII string "97" which is a lowercase "a".
// logic
This is pseudocode you have to modify it a little
dcb
I like kg4wsvs suggestion, just do it in bash if you don't mind being linux specific.  It is very powerful once you get the hang of it, you could even:
1. create a file that lists the commands you expect from the arduino and the linux commands to execute when receiving them.
2. read a command from the arduino, and execute the corresponding linux command. (grep & cut).
And you can do the command processing all on like one line after you create the command map file :)
http://www.arachnoid.com/linux/shell_programming.html
gnu_linux
Shell is very powerful and a great tool but when you have an ATmega168 with 14k usable flash and 1K RAM you are limited in what you can do
Having the arduino put together potentially long complex command lines and send them back to the computer is going to require some fairly complex C code and potentially a very big and complex command table
I think it would be much simpler and much less error prone to send a single ASCII character ( alpha or digit ) to indicate which button was pressed and then your higher level script, be it Perl, Python, Shell, PHP or what have you can take that input and execute the appropriate command on the Linux PC itself
Besides it is a lot easier to work with the command mapping on the Linux PC itself, rather than having to reprogram the arduino every single time you want to change the command
Would you prefer vi my_script.$ext or gedit my_script.$ext or arduino, edit, compile, upload, edit, compile, upload, edit, compile, upload, edit, compile, upload, edit, compile, upload... ?
Having been a Linux person for a long time I can easily imagine a situation where one of my command lines could be much bigger than 1024 characters which would overflow the RAM on the ATmega168
My advice, keep it simple on the Arduino side and move all the complexity to the Host PC side
Perl, Python and PHP are cross platform so your script would work on any host system ( Linux, Unix, BSD, MacOS X, win*****, etc ) with some changes to the commands of course
gnu_linux
#8
Jan 12, 2009, 05:57 am Last Edit: Jan 12, 2009, 05:58 am by gnu_linux Reason: 1
This is how I envision this working
Code: [Select]
Button        char        lang               Linux_or_Unix_cmd         action
Button0 -> '0' -> high_level_lang -> system("$command0"); -> play video0
Button1 -> '1' -> high_level_lang -> system("$command1"); -> play song0
Button2 -> '2' -> high_level_lang -> system("$command2"); -> play song1
Button3 -> '3' -> high_level_lang -> system("$command3"); -> play video1
Button4 -> '4' -> high_level_lang -> system("$command4"); -> launch app0
gnu_linux
There's no doubt that what kg4wsv suggested in indeed very clever, powerful and cool :)
However it is more flexible to have the arduino signal which button was pressed and nothing else, that way you can move the arduino from a Linux PC to a Solaris box or BSD system or a Mac or even a win****** PC without having to make any modifications to the arduino itself, each host system would have its own version of the scripting language with its command mapping
If you use a cross platform language your code would be 99% + identical on all Unix systems, even on win****** the code changes would be fairly minor
In response to that_chap about AppleScript, I am not familiar with it, but Linux has bash which is the default shell on most distributions, in addition to the command line shell Linux also has a variety of scripting languages such as the ones mentioned earlier ( Perl, Python, PHP, Ruby, etc )
Other shells like ksh, tcsh, csh are also available
These shells are also available on BSD and most Unix systems
Since MacOS X is based on BSD it has inherited some of this functionality as well
Linux and Unix shells can also run on win****** via cygwin
that_chap
Agree that if you can do it in a Linux/UNIX shell (or PHP/Python/Ruby/whatever) then you should have something that would run with minimal modification on Mac.
There were two points about AppleScript
1/ its relatively easy
2/ its capable of finer interaction than most of the application command line options I've come across. Its even two-way. Mac apps can reply to (hence control) your script, perhaps even passing calculated parameters back to the Arduino.
http://www.apple.com/applescript/firsttutorial/18.html
And with (commercial) additions, AppleScript has simplified access to all elements of most apps' GUI - from a script! (Apple does provide a similar free, but for once less easy, access.) See http://prefabsoftware.com/uibrowser/
This would allow the Arduino to, for example, 'click' any specified button in any dialog box within the application.
Regarding another recent thread, sadly OpenOffice doesn't (not yet anyway) talk AppleScript.
gnu_linux
Perl has an interface to the GTK API so it can interact with the GUI :)
Other languages do as well
I cannot comment on how that compares to AppleScript since I haven't used it
computer_freak_8
Wow, I've gotten a lot of responses since yesterday! Thank you all for all the good ideas. I'm going to play around a little bit with what you all have given me, and then report back later.
Thanks again,
computer_freak_8
computer_freak_8
Well, I don't think I've gotten very far yet...
@gnu_linux:
I know that you said I will need to edit it, but I figured that was just in reference to the commands I wanted it to run.
After a bit of investigation, (using Perl's debugger and commenting various things out,) I realized I have the following errors coming up with the code:
Code: [Select]
$port->databits(8);
$port->stopbits(1);
all yeild an error in the form of:
Quote
Can't call method "xxxx" on an undefined value at ./trial001.pl line xx.
where xx is the line number, and xxxx is one of the following: databits, baudrate, parity, stopbits.
Oh, and I had another issue which was resolved by running:
Code: [Select]
sudo apt-get install libdevice-serialport-perl
(Which installed the serial device support for Perl.)
Any ideas on how to fix this?
@that_chap:
Quote
[...] one preliminary is to sort out exactly what commands you want to issue. That is independent of getting that command triggered somehow.
I get what you're saying. I can run them from the command line, and I'm confident I can get the triggering worked out (that is, waiting for a button press, or something similar). For discussion's sake, lets say the commands I want to use are:
Code: [Select]
vlc /home/username/file1.wav
fah6
init 6
/home/username/turn-on-wifi-hotspot.sh
@kg4wsv:
Thanks for that, and it will probably make a good temporary fix. I'll have to try it.
@dcb:
I'm working on reading that page you linked to.
Thanks again, all!
gnu_linux
Did you call Device::SerialPort->new first?
Code: [Select]
The "my" is optional
You'll need to replace /dev/ttyUSB0 with the serial port your arduino is attached to, dmesg will show the port used by the arduino shortly after you plug it in
Code: [Select]
$command0="/usr/bin/vlc /home/username/file1.wav";
$command1="/dir/fah6";
$command2="/sbin/init 6";
$command3="/home/username/turn-on-wifi-hotspot.sh";
system("$command0") if($button eq "a");
system("$command1") if($button eq "b");
Some minor modifications may be required
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
