Topic: arduino input in my C++ tutorial (Read 966 times) previous topic - next topic
agashka
I am somewhat fluent in STD C++ coding, but I have little experience with the windows.h library.
I am currently working on a project that involve using my arduino as an input device, and I would need to get serial input in my program.
I've been messing with that almost all day long, and I can't get anything to work. So i figured out, maybe someone else areally figured this stuff out before me, and could give me a hand on some examples script? I found some on google, but I'm not much expert with Windows C++ & serial communication.
Could anyone give me a hand here?
Thank You,
-Vincent
aspartame
This is a simple little library i put together to talk to my arduino.
It's C, so you can use it w/ C++, or make it into a class or whatever.
Code: [Select]
#include <windows.h>
#include <stdio.h>
#include <stdlib.h>
HANDLE hSerial;
int serialOpen(char *name);
BOOL serialRead(unsigned char *byte);
int serialWrite(unsigned char *data, int size);
//open Serial port; pass "COM1"/"COM2"/... for file name
     DCB dSerial;
     hSerial = CreateFile(name, GENERIC_READ | GENERIC_WRITE, 0, 0, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, 0);
     if(hSerial == INVALID_HANDLE_VALUE)
           return -1;
   if(!GetCommState(hSerial, &dSerial))
           return -2;
   dSerial.BaudRate=CBR_9600;
   dSerial.ByteSize=8;
   dSerial.StopBits=ONESTOPBIT;
   dSerial.Parity=NOPARITY;
   if(!SetCommState(hSerial, &dSerial))
           return -3;
     return 0;
//read a single byte from the serial port
     int readSize;
     if(ReadFile(hSerial, byte, 1, &readSize, NULL))
           if(readSize)
                 return TRUE;
     return FALSE;
//write size bytes from data array
     unsigned int wrote;
     WriteFile(hSerial, data, size, &wrote, NULL);
     return wrote;
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
