Author Topic: converting hex code to assembly  (Read 1463 times)
I'm interesting in converting the Hex code which is produced when I compile a program into assembly, I've heared that you need some kind of disassembly for the exact microcontroller that is being programmed. in my arduino i have atmega168. anyone knows where i can find a disassembly program for this chip?
Thanks.
London
Have fun!
If you are looking to view the assembler produced by the arduino compiler, see this thread: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1207951658
I think i got a problem:
C:\Documents and Settings\Dragonuv\Desktop\arduino-0010\hardware\tools\avr\bin>avr-objdump.exe -S c:\Blink.hex > test.txt
avr-objdump.exe: Can't disassemble for architecture UNKNOWN!
Why does this happen ?
Will the output file be seen as cpp? Can I make it be seen as assembly?
Thanks smiley
London
Have fun!
Its the .elf file that you dump, not the hex file. The elf file contains lots of information that avr-objdump uses to mix assembly with the C source code.
« Last Edit: April 25, 2009, 06:13:53 am by mem » Logged
Works great, thanks.
But it still leads me to the question: what does the .hex file include?
London
Have fun!
The hex file contains the runtime machine code, it's what Arduino will get when you upload a sketch. But the hex file has all of the high level information stripped out so even if you had a dissassembler you would find the output much more difficult to interpret than the output from avr-objdump.
« Last Edit: April 25, 2009, 08:28:05 am by mem » Logged
someone of you can tell me why when I apply the avr-objdump. exe to the .elf file it generates an empty txt file? :-?
any suggestion?
London
Have fun!
try running it from the command line to see if you get the exptected output:
  avr-objdump.exe -S  mysketch.elf
I follow your instructions in the post linked above. that's what you're suggesting me I presume, but the result is a blank txt file
