Topic: Commented Code has Adverse Effects (Read 1 time) previous topic - next topic
Iowaska
I think you need to make up your mind.
The point here is that debug statements and comments shouldn't effect code. If a system is that brittle, it's for the birds.
What is this sensor you are using? Link please.
I mean, the sensor doesn't seem to be the issue. I have tried a button, PIR, break sensor, and straight +. All work as desired with statements enabled. Commented, nothing works.
who said it isn't right or it's wrong?
who said caching a variable was harmful?
So much for:
Post was edited prior to your comment...
larryd
If you disconnect the sensor and use:
pinMode(SENSOR_PIN_1, INPUT_PULLUP);
What happens?
No technical PMs.
The last thing you did is where you should start looking.
OldSteve
Well as far as I can see from my testing of your code, the debug statements don't affect the code or it's execution at all, except in the way you intended. Everything works fine for both cattledog's tests and mine, with or without the serial print lines and regardless of the state of the sensor input pin.
I don't know what more to say, so I'll leave it to you and others to hopefully sort out.
Please do not PM me for help. I am not a personal consultant.
And others will benefit as well if you post your question publicly on the forums.
larryd
Assumption, is your sensor is wired similar to S3
No technical PMs.
Iowaska
What happens?
No LED with either statements en/disabled. And also tried with DigitalWrite(SENSOR_PIN_1, INPUT_PULLUP);
S3 is exactly how I have it wired, yes.
Iowaska
I appreciate y'all giving it a whirl. I'm just lost for words...
larryd
Will you show us a good quality image of your wiring?
No technical PMs.
OldSteve
I'll keep watching. I'll be most interested to see if the cause can be found.
Iowaska
My phone isn't giving a good picture. However, I believe I have found the cause. I was toying with the preference and after unchecking "verify code after load" everything works peachy-king. IDE bug? 1.6.8.0?
:mystery:
larryd
#24
Mar 26, 2016, 03:33 am Last Edit: Mar 26, 2016, 03:34 am by LarryD
Don't you just love it when things do that  >:(
I use IDE  1.06  ;)
No technical PMs.
Iowaska
I use IDE  1.06  ;)
I just started on a new machine so just downloaded it. But yes, things like this are the bane of my existence. Just like the damn Unity Mono compiler at one point in time caused huge heartache when somehow true == false. -.\
OldSteve
#26
Mar 26, 2016, 03:37 am Last Edit: Mar 26, 2016, 03:38 am by OldSteve
:mystery:
Yet another reminder of why I stuck with V1.6.5. It's the most reliable of all the recent releases. (I think 1.6.8 is the worst one so far.)
Anyway, I'm glad you solved it. :)
Edit: If I were you, I'd get rid of 1.6.8 and install 1.6.5. (That's just me though.)
Iowaska
Yup, seems to work no problem...what a waste of a Friday night. hehe
cattledog
Works as expected with 1.6.6, which I am using, so the problem is in 1.6.7 or 1.6.8.
