Montréal, Qc
Practice safe hex!
« Reply #15 on: September 13, 2007, 06:59:48 pm » |
So after some more testing I was pretty sure the spi voltage had something to do with it. Even just dumping the registers (slower than I can click on a key) and the data would become inconsistent. And so the SPI input voltage problem has been solved. Using a SN74LS08 series AND gate running at 5v. two inputs are tied to the MISO of the ENC and tied to a pull down resistor. The output end up being ~4.5v, which is higher enough than the 2/3Vcc ratio the I/Os require (making 3.3v on the edge). Register readings now seem 100% consistant. I have also replace the 2.7k resistor on RBIAS by a 2.3k as noted in the Rev B5 errata. I definitely can read icmp, udp and tcp packets. More to come  Time Eth Address IP Address --------------------------------------- 0:0:0:0:0:0 0.0.0.0 0:0:0:0:0:0 0.0.0.0 0:0:0:0:0:0 0.0.0.0 0:0:0:0:0:0 0.0.0.0 0:0:0:0:0:0 0.0.0.0 0:0:0:0:0:0 0.0.0.0 0:0:0:0:0:0 0.0.0.0 0:0:0:0:0:0 0.0.0.0 Received ARP Request ARP Packet: Operation : REQUEST SrcHwAddr : 0:16:CB:8B:1:EC SrcProtoAddr: 192.168.0.12 DstHwAddr : 0:0:0:0:0:0 DstProtoAddr: 192.168.0.126 Sending ARP Reply ARP Packet: Operation : REPLY SrcHwAddr : CC:0:FF:FF:EE:EE SrcProtoAddr: 192.168.0.126 DstHwAddr : 0:16:CB:8B:1:EC DstProtoAddr: 192.168.0.12
NET Rx: IP packet Time Eth Address IP Address --------------------------------------- d ::[ch65533]:[ch65533]::[ch65533] [ch65533].[ch65533].. ::::: ... ::::: ... ::::: ... ::::: ... ::::: ... ::::: ... ::::: ... entering netstackIPProcess NET Rx: UDP/IP packet -1012UDP packet, len: 50 C1
NET Rx: IP packet Time Eth Address IP Address --------------------------------------- d ::[ch65533]:[ch65533]::[ch65533] [ch65533].[ch65533].. ::::: ... ::::: ... ::::: ... ::::: ... ::::: ... ::::: ... ::::: ... entering netstackIPProcess NET Rx: TCP/IP packet Rvd tcp Packet: len=68 NET Rx: IP packet Time Eth Address IP Address --------------------------------------- d ::[ch65533]:[ch65533]::[ch65533] [ch65533].[ch65533].. ::::: ... ::::: ... ::::: ... ::::: ... ::::: ... ::::: ... ::::: ... entering netstackIPProcess NET Rx: TCP/IP packet Rvd tcp Packet: len=68
(the packets were sent using ping, nc and nc -u)
« Last Edit: September 13, 2007, 07:07:32 pm by xSmurf »
"Pilots believe in a clean living... they never drink wisky from a dirty glass."
Forum Administrator
Cambridge, MA
« Reply #16 on: September 13, 2007, 09:58:52 pm » |
Awesome. Keep us posted.
Montréal, Qc
Practice safe hex!
« Reply #17 on: September 13, 2007, 10:52:45 pm » |
More fooling around the registers (and I might have removed my way off specs ferrite bead meanwhile) and... this happened http://pastie.textmate.org/private/qrg8ojxbtjsjqyh1bmc8fa. And then it happened again! The transmitted packets, I never received anything though. Snooping with wireshark reveals that both packets failed CRC which might be why nc/ping didn't pick them up. But the Arduino did and it definitely sent!
« Last Edit: September 14, 2007, 12:18:47 am by xSmurf »
Montréal, Qc
Practice safe hex!
« Reply #18 on: September 14, 2007, 12:31:33 am » |
The latest code can be obtained here. Have fun
Montréal, Qc
Practice safe hex!
« Reply #19 on: September 14, 2007, 03:51:44 pm » |
I'm in the process of seeing what I can do with µIP, it seems to have better checksum handling at least. And I wouldn't mind switching as µIP has a much better stack and properly support tcp.
EDIT: Doesn't seem like such a good idea. uIP is a little too feature complete for a mega168. And I won't even talk about OpenTCP. Looks like I'm going to stick with AVRLib.
« Last Edit: September 14, 2007, 07:31:11 pm by xSmurf »
Montréal, Qc
Practice safe hex!
« Reply #20 on: September 16, 2007, 04:51:53 pm » |
The code is now under version control using SVN. You can checkout a copy at svn+http://svn.mlalonde.net/Ethduino or browse the repository on the Trac site. Packets are still not getting received by applications, but they are getting sent (i can tcpdump them). As far as I can see, the checksum is definitely to blame. If anyone has an idea about this I'd really like to ear. As for running on the Mega168, so far so good... there's a good 6~8k free without all the debugging stuff which laves enough room for some business logic. (there's still definitely more things that could be done to reduce code size even further)
« Last Edit: September 16, 2007, 04:54:53 pm by xSmurf »
Montréal, Qc
Practice safe hex!
« Reply #21 on: September 17, 2007, 02:38:16 am » |
I sorry if this post is rather dry when it should be rather high, but I don't have anything to show (I don't have LCD at hand to do the ethernet LCD or something). But here it is... I have the honour to present you the very first ping replies! PING 192.168.0.126 (192.168.0.126) from 192.168.0.12: 56 data bytes 64 bytes from 192.168.0.126: icmp_seq=0 ttl=64 time=1.341 ms [...] 64 bytes from 192.168.0.126: icmp_seq=4 ttl=64 time=1.245 ms
--- 192.168.0.126 ping statistics --- 5 packets transmitted, 5 packets received, 0% packet loss round-trip min/avg/max/stddev = 1.235/1.283/1.341/0.039 ms
I've written functions to allow using the ENC's internal checksum functions. And it worked! This is an issue however because as noted in the errata #15, use of the DMA for checksuming can cause drop packets. I guess for some this would be fine; it has the added advantage of having a zero footprint in the stack! Either ways this is a huge step as it confirms that the hardware is up and running and that most of the software runs fine! There are no words to explain my joy! ;D ;D ;D
berlin
« Reply #22 on: September 17, 2007, 05:22:58 am » |
now that's sounding nice. this is the beginning of a new chapter in arduino's history congratulations, i hope it will not take too long for a little http functionality. best, kuk_
« Reply #23 on: September 17, 2007, 06:19:10 am » |
Congratulations! I hope you plan to share your hard work and success with the rest of us by posting a schematic and some code.  I don't recall what your final application is? You're probably quite close to a working serial proxy app right now; a TCP connection (to allow HTTP) may be a bit more work... -j
Montréal, Qc
Practice safe hex!
« Reply #24 on: September 17, 2007, 01:56:27 pm » |
Kuk: at this stage there is no plan for TCP support. The mega168 is small and TCP processing is heavy. I'm not saying it won't come but there are other priorities. Just like kg4wsv was saying were closer from an EthProxy than anything... I will post details (schematic, doc, etc) very soon. Meanwhile, the code is available above.
Montréal, Qc
Practice safe hex!
« Reply #25 on: September 17, 2007, 09:09:24 pm » |
And finally, in pictures ^-^ (Click for full flickr experience)There's a lot more info, access to code and bug listing on the trac site. There's still a lot of documentation work to be done, but it'll come!
Wuppertal/Germany
« Reply #26 on: September 18, 2007, 08:20:25 am » |
Hi, after reading along, I'd like to try the Ethuino, too. Do you think I could start with this module here : http://www.olimex.com/dev/enc28j60-h.htmlEberhard
Torino, Italy
Arduino really rocks
« Reply #27 on: September 18, 2007, 04:41:36 pm » |
Great ! I just saw there were someone playing with an Ethduino... Seems that I know this guy ! I can't wait to try this at home. http://www.makezine.com/blog/archive/2007/09/ethduino.html
Montréal, Qc
Practice safe hex!
« Reply #28 on: September 18, 2007, 05:15:12 pm » |
It does look like you do  How does a shield sounds like? I'm trying to see if it'd be worth setting up a kit... let me know what you guys think!
« Reply #29 on: September 19, 2007, 07:25:52 am » |
A shield sounds good, but IMO it would need to be "stackable" or otherwise expandable. An ethernet Arduino is cool and all, but what will you do with it? I'd interface sensors or buttons or an LCD or something, and that something needs a place to be attached.
It would be nice to be able to get a little kit that had the "magnetics" in it.
This does sound a lot like the device from Olimex that was mentioned previously (although their price of US$34 sounds a bit steep to me).
just my $0.02.
-j
