Loading...
Pages: [1]   Go Down
Author Topic: PS2Keyboard on Arduino Mega  (Read 207 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I've been trying to understand how to get this working, I'm new to the Arduino and micro programming, but learning.
I'm confused which pins I should be connecting my keyboard to. In the example the pins are defined as
Code:
#define KBD_CLK_PIN  3
#define KBD_DATA_PIN 4
but from a schematic of the Mega I'm understanding that pin 3 is actually INT5 and the
Code:
attachInterrupt(1, ps2interrupt, FALLING);
which is found in the PS2Keyboard.ccp file should be 5 instead of 1.
Although I must still be doing something wrong as it dosn't yet work.
Any suggestions ?
Also the description at http://arduino.cc/en/Reference/AttachInterrupt
Quote
"Most Arduino boards have two external interrupts: numbers 0 (on digital pin 2) and 1 (on digital pin 3). The Arduino Mega has an additional four: numbers 2 (pin 21), 3 (pin 20), 4 (pin 19), and 5 (pin 18)."
seems to contradict the schematic ftp://http://arduino.cc/en/uploads/Main/arduino-mega-schematic.pdf ?
I must be confusing things and not understanding quite right.
« Last Edit: October 08, 2009, 05:49:40 pm by ndudman » Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
""Most Arduino boards have two external interrupts: numbers 0 (on digital pin 2) and 1 (on digital pin 3). The Arduino Mega has an additional four: numbers 2 (pin 21), 3 (pin 20), 4 (pin 19), and 5 (pin 18)."
The pin mapping is different for the mega processor but the pin assignments Vs user interrupt number is accounted for in the mega mapping and the above quoted pin numbers are the ones to use, I'm pretty sure.
So interrupt 0 wires to Arduino pin 2, interrupt 1 to pin 3, for both normal and Mega boards. So don't change the PS2Keyboard.ccp file. There is probably some other reason you are having trouble.
At least that is my read on it.  smiley-wink
Lefty
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
thanks retrolefty
That gave me the confidence to persist with those pins... and check/double check connections etc and make sure I had everything round the right way with the scope etc... It works now it was a bad connection or wires around the wrong way.  smiley-grin
nduddy
Logged
Pages: [1]   Go Up
Print
Jump to:
