Topic: int values with serial.print (Read 19586 times) previous topic - next topic
soulid
I am working on my first project submitting two temperatures to Processing. I first tried that with "byte" variables and it went fine. But I can't submit int files...
This is the arduino code
//declare variables
int tempC;
int tempD;
int tempPin = 0;
Serial.begin(9600); //opens serial port, sets data rate to 9600 bps
//Mit Sicherheitsbit
//Serial.print((byte)255);    //send the header
tempC = 254;  //convert the analog data to temperature
//Serial.print((byte)tempC);             //send the byte data to the computer- works
Serial.print((int)tempC);             //send the int data to the computer- does not work
tempD = 65;
//Serial.print((byte)tempD);
Serial.print((int)tempD);
delay(300);
And here if the Processing code
//import Serial communication library
import processing.serial.*;
//init variables
Serial commPort;
int tempC;
int tempD;
PFont font24;
 //setup fonts for use throughout the application
 font24 = loadFont("serif.vlw");
 size(210, 200);
 //init serial communication port
 commPort = new Serial(this, "COM7", 9600);
void draw()
 //get the temp from the serial port
//Hier mit Orientierungsbit
if (commPort.available() > 2) // don't do anything until you get 3 characters (header plus the two data bytes
if(commPort.read() == 255) // only proceed if you get your header
  tempD = commPort.read();
  tempC = commPort.read();
}   background(123);
   fill(0,0,0);
   textFont(font24);
   textAlign(LEFT);
   text(tempC, 115, 45);
   text(str(int(tempC)) + " C", 115, 65);
   text(str(int(tempD)) + " D", 115, 80);
Can someone help me?
PaulS
The Serial.print method has several overloads. The single argument method takes whatever value it receives and sends it as a character.
The two argument method allows you to define how the value is sent.
You want to use the two argument method like this:
Serial.print(tempC, DEC);
This will send the value as an int rather than as a char.
On the receiving end, you are expecting some known value as input, but you are no longer sending it. That code is commented out.
soulid
Hi PaulS,
I did what you proposed and do receive data...but wrong values.
This the arduino code:
//declare variables
int tempC;
int tempD;
int tempPin = 0;
tempC = 54;  //convert the analog data to temperature
//Serial.print((int)tempC);             //send the int data to the computer- does not work
tempD = 65;
Serial.print(tempD, DEC);
//Serial.print((int)tempD);
delay(300);
The processing code remained unchanged. The shown values are 53 and 52 instead of 54 and 65.
May I did not understand the possible code change in Processing described by you with
What did you mean?
PaulS
I modified your program a bit. The arduino code looks like this:
int tempC;
int tempD;
 Serial.print("C:");    //send the header
 Serial.print(tempC);
 Serial.print("D:");    //send the header
 tempD = 65;
 Serial.print(tempD);
 delay(10000);
The processing code looks like this:
//init variables
Serial commPort;
int tempC;
int tempD;
int val;
int byteCount;
PFont font24;
 String[] fontList = PFont.list();
 font24 = createFont(PFont.list()[156], 12);
 size(210, 200);
 commPort = new Serial(this, "COM4", 9600);
void draw()
 byteCount = commPort.available();
 if (byteCount > 5) // don't do anything until you get 3 characters (header plus the two data bytes
   print("byteCount = ");
   println(byteCount);
   for(int b=0; b<byteCount; b++)
     print(b);
     print(") ");
     val = commPort.read();
     print("val = ");
     println((char)val);
 background(123);
 fill(0,0,0);
 textFont(font24);
 textAlign(LEFT);
When I upload the code to the arduino, and start the processing program, I get this output:
byteCount = 8
0) val = C
1) val = :
2) val = 5
3) val = 4
4) val = D
5) val = :
6) val = 6
7) val = 5
The Serial.print on the arduino is converting the byte to a string, and sending the string one character at a time.
If you put some delimiter between the values you send, like this:
Serial.print("Temps:");
Serial.print(";");
Serial.println("!");
The processing program would then receive the characters:
T e m p s : 5 4 ; 6 5 !
The processing program would need to look for the : as the marker for the start of the 1st temperature, the ; as the marker for the end of the first temperature and the start of the second temperature, and the ! as the marker for the end of the second temperature.
