Topic: Relay and LCD Issue (Read 7429 times) previous topic - next topic
retrolefty
Quote
[/quoLefty, what do you mean by "CAP to true Ground"?
te]
To the negative side of the external power supply you are using to power the relay coils.
Lefty
mikericeTGA
The data sheets unfortunate choice of label for ULN pin 9 seems to be causing confusion.
Pin 9 is where all the diode anodes are connected together... thus the label 'diode common'.
Pin 9 should be connected to +5 volts of the relay board, not to ground.
Peri
I have wired the pin 9 to +5 and pin 8 to GND. Is that correct?
