Pages: 1 [2]   Go Down
Author Topic: Problem saving data to SD  (Read 1215 times)
Seattle, WA USA
Online Online
Seattle, WA USA
The format part of the sprintf argument list is the part between the "". If you want the message array to contain a CR\LF, add \n at the end:
sprintf(message,"%ld,%ld\n", temp, Vcc);
If you want to write more data into message, message must be longer.
As for the format "magic", see this:
http://www.cppreference.com/wiki/c/io/printf
Thanks so much PaulS,
It works perfectly now.
The link is great and looks very useful to learn more about C.
Now i post here the final code as i have it working. May be it could be useful to somebody else in the future.
#include <FileLogger.h>
#define MEM_PW 8
long readTemp() {
  long result;
  // Read temperature sensor against 1.1V reference
  ADMUX = _BV(REFS1) | _BV(REFS0) | _BV(MUX3);
  delay(20); // Wait for Vref to settle
  ADCSRA |= _BV(ADSC); // Convert
  while (bit_is_set(ADCSRA,ADSC));
  result = ADCL;
  result |= ADCH<<8;
  result = (result - 125) * 1075;
  return result;
long readVcc() {
  long result;
  // Read 1.1V reference against AVcc
  ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
  delay(2); // Wait for Vref to settle
  result = ADCL;
  result |= ADCH<<8;
  result = 1126400L / result; // Back-calculate AVcc in mV
  return result;
  pinMode(MEM_PW, OUTPUT);
  digitalWrite(MEM_PW, HIGH);
  Serial.println("Arduino inner temperature and inner voltage");
  // To read the inner temperature and voltage
  long temp=readTemp();
  long Vcc=readVcc();
  // To prepare and to save the data tostore in the microSD
  char message[20];
  sprintf(message,"%ld, %ld\n", temp, Vcc);
  unsigned long length = strlen(message);
  FileLogger::append("data.log", (byte*)message, length);
  // Now i show the result in serial
  Serial.print(temp, DEC); // show the inner temperature of arduino
  Serial.print(" x10^-4 degC   ");
  Serial.print(Vcc, DEC); // show the voltage
  Serial.println("  mVolts");
  // Wait 1 second until to take a new measurement
You could apply it to any other measurement acquired by temperature sensors, accelerometers, or whatever.... just only pay attention to the expression to be save, and the length of the message to be stored in the SD, as you could read in the previous post and the great explanations by PaulS.
Thanks PaulS. Enjoy everyone!
Pages: 1 [2]   Go Up
