Topic: "advanced" Bluetooth use (Read 925 times) previous topic - next topic
I am looking into buying a BT connection kit for my Arduino. However, I see only reports of using BT as a replacement for the USB cable, ie. as a Serial device. However: I want to use the BT 'shield' to check for other BT devices in the surroundings of the Arduino. (Under Linux one would use 'hcitool scan' for this). Is there a way to communicate with the BT chip to perform such action?
Nov 20, 2009, 10:07 pm Last Edit: Nov 20, 2009, 10:07 pm by jluciani Reason: 1
You should be able to send commands to the BT to perform configuration and
discovery tasks. I have been using the BlueGiga WT12A with the '328 and '644
chips without an issue.
Shortly I am hoping to have a library and some examples that interface my NB1 board (http://tinyurl.com/pg334s) to a Droid using a WT12A peripheral that I have
(* jcl *)
www: http://www.wiblocks.com
twitter: http://twitter.com/wiblocks
blog: http://luciani.org
Confirm your email address
Thank you for subscribing!
via Egeo 16
Torino, 10131
