Topic: LCD menu options (best route) (Read 18259 times) previous topic - next topic
jman31
Hope you guys aren't getting sick of me yet. I really appreciate your time and input. I am learning as I go and wearing my google button out! ::)
Here is how I tried to implement your idea PaulS. I still get no entry into the second switch/case. I changed up some of the variable names to make more sense with the project. I hope that doesn't throw too much confusion into the mix.
If I can get this last issue, then maybe I can leave you guys alone for awhile! :D
Code: [Select]
void loop(){
 buttonState = digitalRead(switchPin);
 buttonState2 = digitalRead(switchPin2);
 if (buttonState == HIGH){
   switch(ledstate){
   case LED1:
     lcd.clear();
     lcd.print("Snare");
     digitalWrite(BLUE_PIN,HIGH); //turn blue led off
     digitalWrite(RED_PIN,HIGH); //turn red led off
     delay(100); //wait 100ms
     ledstate = LED2; //transition to red state
     break; //end of START case
   case LED2:
     lcd.clear();
     lcd.print("TOM 1");
     digitalWrite(BLUE_PIN,LOW); //turn blue led off
     digitalWrite(RED_PIN,HIGH); //turn red led on
     delay(200); //wait 200ms
     ledstate = LED3; //transition to blue state
     break; //end of RED case
   case LED3:
     lcd.clear();
     lcd.print("TOM 2");
     digitalWrite(RED_PIN,LOW); //turn red led off
     digitalWrite(BLUE_PIN,HIGH); //turn blue led on
     ledstate = LED1; //transition to start state
     break; //end of BLUE case
     if (ledstate == LED2)
       if (buttonState2 == HIGH)
         if (buttonState == LOW){
           switch(colorState){
           case COLOR1:
             lcd.clear();
             lcd.print("Color 1");
             colorState = COLOR2; //transition to red state
           case COLOR2:
             lcd.clear();
             lcd.print("Color 2");
             colorState = COLOR3; //transition to blue state
           case COLOR3:
             lcd.clear();
             lcd.print("Color 3");
             colorState = COLOR1; //transition to start state
Groove
This:
Code: [Select]
is the same as writing:
Code: [Select]
     if  ( (ledstate == LED2) &&
           (buttonState2 == HIGH) &&
           (buttonState == LOW)) {
Per Arduino ad Astra
jman31
OK, but will that change anything to make it work?
Groove
No, but it may make it easier to read.
jman31
PaulS
Is it safe to assume that you pushed button 1, and then pushed button 2?
jman31
Yes and although you were correct in that, It is definitely not what I am after. I tried moving it outside of the case, but think it is still expecting a "high" on button one to make it function when ledstate == led2
I made some changes to the variable names as I mentioned.
PaulS
You aren't debouncing the buttons, or toggling behavior only when the button state changes.
Your behavior is based on the button state being HIGH.
This is fine if you want something to happen while a button is pressed, like a doorbell ringing. It's not fine, if you want to implement a state machine, as you are (trying to).
You need to keep track of the previous state of the buttons, and only act when the state changes:
Code: [Select]
int previousButtonOneState = LOW;
int previousButtonTwoState = LOW;
  int buttonOneState = digitalRead(buttonOnePin);
  int buttonTwoState = digitalRead(buttonTwoPin);
  if(buttonOneState == HIGH && previousButtonOneState == LOW)
      // Button One was just pushed. Make the state changes...
  previousButtonOneState = buttonOneState;
  if(buttonTwoState == HIGH && previousButtonTwoState == LOW)
      // Button Two was just pushed. Now, we can rely on the state
  previousButtonTwoState = buttonTwoState;
jman31
#23
Jan 20, 2010, 10:07 pm Last Edit: Jan 20, 2010, 10:08 pm by jman31 Reason: 1
Thanks for that. I think maybe I am biting off more than I can chew with my limited knowledge. I added the code you gave me before the switch statements, but I obviously didn't do it correctly.
Here is what I did. I deleted some of the code that didn't pertain to what we are talking about.
Code: [Select]
int previousButtonOneState;
int previousButtonTwoState;
int buttonOneState;
int buttonTwoState;
 pinMode(RED_PIN, OUTPUT);      // Set the pin as output
 pinMode(BLUE_PIN, OUTPUT);    // Set the pin as output
 pinMode(switchPin, INPUT);    // Set the switch pin as input
 pinMode(switchPin2, INPUT);    // Set the switch pin as input
 Serial.begin(9600);           // Set up serial communication at 9600bps
void loop(){
   if(buttonOneState == HIGH && previousButtonOneState == LOW){
   if(buttonTwoState == HIGH && previousButtonTwoState == LOW){
   switch(ledstate){
   case LED1:
     lcd.clear();
     lcd.print("Snare");
     switch(colorState){
     case COLOR1:
       lcd.clear();
       colorState = COLOR2; //transition to color2 state
       break; //end of color1 case
     case COLOR2:
       lcd.clear();
       colorState = COLOR3; //transition to color3 state
       break; //end of color2 case
     case COLOR3:
       lcd.clear();
       colorState = COLOR1; //transition back to color1 state
       break; //end of color3 case
     ledstate = LED2; //transition to led2 state
   case LED2:
     lcd.clear();
     lcd.print("TOM 1");
     ledstate = LED3; //transition to led3 state
   case LED3:
     lcd.clear();
     lcd.print("TOM 2");
     ledstate = LED1; //transition to led1 state
PaulS
At least, you're trying. Boy, are you trying. ;)
The whole switch statement, where you change the state goes inside the {} where the comment says
jman31
#25
Jan 20, 2010, 10:23 pm Last Edit: Jan 20, 2010, 10:24 pm by jman31 Reason: 1
Man, I sure appreciate you hanging in there with me. I figure the only way for me to learn it since I live in a small town (no resources available) is to jump in and try to code something.  :-?
Ok, does the nested code go in the second {} or does it remain in line like this? I'm still missing something. :-/
Code: [Select]
void loop(){
   switch(ledstate){
   case LED1:
     lcd.clear();
     lcd.print("Snare");
     switch(colorState){
     case COLOR1:
       lcd.clear();
     case COLOR2:
       lcd.clear();
     case COLOR3:
       lcd.clear();
   case LED2:
     lcd.clear();
     lcd.print("TOM 1");
   case LED3:
     lcd.clear();
     lcd.print("TOM 2");
jman31
I think I got it. I am sure I will be back, but that will get me started for now. Thanks to everyone that lent me a helping hand!!!!!  8-)
jman31
Man I am so close! But yet so far away. Here is what I have. By changing the {} around I can get it to enter the second Switch/Case, but I never have any control with the second button. It cycles through the color cases every time I get back around to the LED1 case.
Code: [Select]
void loop(){
 buttonOneState = digitalRead(switchPin);
 buttonTwoState = digitalRead(switchPin2);
   switch(ledstate){
   case LED1:
     lcd.clear();
     lcd.print("Snare");
       switch(colorState){
       case COLOR1:
         lcd.clear();
       case COLOR2:
         lcd.clear();
       case COLOR3:
         lcd.clear();
     break; //end of led1 case
   case LED2:
     lcd.clear();
     lcd.print("TOM 1");
     break; //end of led2 case
   case LED3:
     lcd.clear();
     lcd.print("TOM 2");
     break; //end of led3 case
PaulS
On any given pass through loop, which probably happens far oftener than you think, only one button is pressed. Only one button can have changed state.
Therefore, you need to treat the buttons, and their states, as completely independent.
In the loop function, see if button 1 is being presses, but was not before. If that is the case, set ledState.
Then, see if button 2 is being pressed, but was not before. If that is the case, set colorState.
The value of colorState has nothing to do with whether button 1 is being pressed, or not. It depends on (or changes as a result of) ledState, not whether button 1 is being pressed.
jman31
OK, this time I got it. I moved the entire colorstate switch out of the first loop and then added "ledstate == LED2" to the first line as was mentioned before. Thanks for the help again PaulS! 8-)
Here is the code as it works for me.
Code: [Select]
// include the library code:
#include <LiquidCrystal.h>
#include <Button.h>
// initialize the 4 bit LCD library with the numbers of the interface pins
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);
//first define states with obvious names and different values
#define LED1 0
#define LED2 1
#define LED3 2
#define COLOR1 3
#define COLOR2 4
#define COLOR3 5
//next define which pin is which
#define RED_PIN 9
#define BLUE_PIN 10
int buttonState = 0;
int buttonState2 = 0;
int switchPin = 11;              // switch is connected to pin 11
int switchPin2 = 12;            // switch is connected to pin 12
int ledstate = LED1; //create state variable and initialize it to START state
int colorState = COLOR1; //create state variable and initialize it to START state
int buttonOneState;
int buttonTwoState;
 //LCD SETUP
 // set up the LCD's number of rows and columns:
 lcd.begin(16, 2);
 // Print a message to the LCD.
 lcd.print("**MIDI NIGHTS**");
 delay (1000);
 lcd.setCursor(0, 4);
 lcd.print("LED Menu Options");
 delay (1000);
 lcd.clear();
 // resets cursor position
 lcd.print("    Use right/left buttons to select LED    ");
 delay (20);
 // scroll 27 positions (string length) to the left
 // to move it offscreen left:
 for (int positionCounter = 0; positionCounter < 27; positionCounter++) {
   // scroll one position left:
   lcd.scrollDisplayLeft();
   // wait a bit:
   delay(50);
   delay (300);
   lcd.clear();    //clear LCD and reset cursor
   lcd.setCursor(1, 9);
   lcd.print("Select LED < >");  //Select desired LED from menu
   delay(2000);
 buttonOneState = LOW;
 buttonTwoState = LOW;
void loop(){
   switch(ledstate){
   case LED1:
     lcd.clear();
     lcd.print("Snare");
   case LED2:
     lcd.clear();
     lcd.print("TOM 1");
   case LED3:
     lcd.clear();
     lcd.print("TOM 2");
       if(buttonTwoState == HIGH && previousButtonTwoState == LOW && ledstate == LED2){
         switch(colorState){
       case COLOR1:
         lcd.clear();
       case COLOR2:
         lcd.clear();
       case COLOR3:
         lcd.clear();
