Author Topic: Direct reading of a PORTD bit  (Read 1164 times)
In the code below if I use digitalRead(6) I can read the logic level on my PortD Pin6. If I use the Led = PORTD & B11000000 statement I do not get bit6 wiggling as I'd expect.
What am I doing wrong?
    // prints title with ending line break
    Serial.println("Setup starting");
    // The Data Direction Register of Port D, don't touch the
    // lower two bits which are serial IO
    DDRD = DDRD | B00111100 ;
    int i = 0 ;
    int iLed = 0 ;
    while (true) {
        // iLed = digitalRead (6) ;
        iLed = PORTD & B11000000 ;
        Serial.println("iLed =");
        Serial.print(iLed, OCT);
I take it by "wiggling" you mean "toggling"  smiley ie 1 becomes 0 and 0 becomes 1
You can do this with an AND operation, because only 1 and 1 = 1 , so as soon as you get a 0 in there, the output will always be 0, it will never flip back to 1 again.
You need an XOR operation eg
PORTD ^= BV(5);
Will flip Bit 5
Oxford (England)
You need to use PIND to read the port, rather than PORTD.
20 LEDs are enough
If you just want to toggle the port you can write PIND. The Atmel datasheet says:
Toggling the Pin
               Writing a logic one to PINxn toggles the value of PORTxn, independent on the value of DDRxn.
               Note that the SBI instruction can be used to toggle one single bit in a port.
Hence you can just write a logical one into the desired bit and it will toggle. So you may write
PIND = BV(5);
Cheers, Udo
« Last Edit: February 23, 2010, 04:01:33 pm by udoklein » Logged
Aha! Thanks Condemned! PIND instead of PORTD.
Does that stand for Port INput D ?
Yes. (my shortest post ever smiley )
EDIT: i screwed it: Every Port has 3 Registers: DDRx, PINx and PORTx.
PIN to read, PORT to write, and DDR to clarify the "DataDirection (Register)"
But, as seen in Post before: you can write to PIN, and the Bits which are written to "1" change their state.
« Last Edit: February 25, 2010, 02:45:07 pm by willich » Logged
Left Coast, CA (USA)
Measurement changes behavior
Also you can write with a PORTx pin command, and if the pin is in the input mode (via DDRx pin) and it will turn on (if 1) or off (if 0) the internal pull-up for that pin.
Lefty
« Last Edit: February 25, 2010, 06:29:48 pm by retrolefty » Logged
