Topic: Arduino and 1-wire (Read 39726 times) previous topic - next topic
jims
I'm missing something here, looking at the atmel source current spec (~20mA) and the ds18s20p current (~1.5mA) draw during a conversion it should be able to power a dozen temperature sensors on a single pin without a problem. Very odd. It is almost as if the Atmel is using its internal pull up resistor to go high instead of the buffer, but I don't see a combination of settings that would cause that. I'll try a bunch of resistors and make a current/voltage plot when I get back to m analog bench and see what those ports are really doing.
jims
Ok, the world has not gone crazy.  The Atmels really do provide >20ma on the pins and the DS18S20P does take about 1ma.  The problem was in the timing. As soon as the DS18S20 receives the 0x44 it will start taking current for the conversion. Unfortunately, the write_byte function is sitting around for many microseconds with the pin in a high impedance state in order to provide timing margins. The DS18S20P crashes before the power gets turned on.
The solution is to not let the external pull-up bring the pin high after the low period of the final bit of the 0x44 is written, force it high with the output driver. Then after the 750ms conversion period passes flip the pin back to an input and let the external pull-up take over.
My little sensor is now happily converting away on my desk.
I'll clean up my changes to the one-wire code and put them up here soon.
bigengineer
That's good news jims! How do you connect the DS18S20? I have a resistor between +5V and the data pin. I found this somewhere in the avrfreaks forum.
jims
I have the grounds connected, the DQ pin on the DS18S20P connected to the pin of the Arduino, and a 4.7kohm resistor from DQ to +5v as the pullup. It is good to connect the Vdd pin of the DS18S20P to ground also so if you get a non-parasite version (DS18S20) it will also work in parasite mode.
If you are going to use more than a few of these on the same pin you will need to use a pullup transistor and another pin, as shown in the DS18S20 datasheet, but for a few, say less than 10? of them the Arduino has enough current capacity.
bigengineer
Quote
Do you use the same pin for this? In yerg2k's code I bring the pin high immediately after the ds_writebyte(0x44) function. But it still  doesn't work. I was wondering if it maybe takes too much time to finish the ds_writebyte() function and that you are doing someting different with an additional pin.
Quote
You almost certainly have a DS18S20P on your hands.
Hmm, overlooked this one but indeed I have the DS18S20P. So far I still couldn't find what I am doing wrong. I am using the 750 uS delay after the 44h write, then pulling the pin high. Why don't I see what's going wrong?
bigengineer
This http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=41771&highlight=ds18s20 thread explains something about connecting the DS18S20. To it seems it is about the powered sensor. Unfortunately, because I have the DS18S20P I can't connect to it like "kartman" explains.
bigengineer
#21
Jan 05, 2007, 05:00 pm Last Edit: Jan 05, 2007, 05:02 pm by bigengineer Reason: 1
:) YES YES
Finally, it works. I'll do a quick clean up of the code and post it. Though I rewrote almost everything it was a hardware  >:( problem after all. I don't really understand it, maybe someone can explain it to me. There are some other issues that I found out by trial and error. So, I am not there yet, but there is a start to get 1-wire working.
bigengineer
#22
Jan 05, 2007, 05:35 pm Last Edit: Jan 05, 2007, 09:58 pm by bigengineer Reason: 1
This program is specifically for the DS18S20P. But it is probably easier to get a non P(arasite) version working. To avoid misunderstandings let's start with the DS18S20P  connections.
GND and Vdd to GND, Dq to pin 6 AND  to pin 7 AND via a 4k7 resistor to +5V on arduino board.
Thanks to yerg2k to get me started and jims to get me thinking.
Comments are welcome.
Code: [Select]
/* DS18S20P Temperature chip i/o
* See http://pdfserv.maxim-ic.com/en/ds/DS1820-DS1820S.pdf for the datasheet.
* (copyleft) 2006 by Derek Yerger - Free to distribute freely.
* (sorry Derek, great inspiration but I rewrote it completely)
*  heavily modified by bigengineer
* inspired by: http://microsyl.com/
* and Dallas 1-wire datasheets
#define DQ 7  //data pin
#define PU 6  //separate pin for pull up
#define pin13 13
#define VERSION 01
void setup(void)
 // initialize inputs/outputs
 // start serial port
 pinMode(DQ,INPUT);
 pinMode(PU,INPUT);
 pinHigh();
byte reset()
 pinLow();
 delayMicroseconds(500);
 pinIn();
 delayMicroseconds(70);
 if (digitalRead(DQ) == LOW)
   return(1);
 return(0);
void WriteByte(byte data)
 byte i;
 for(i=0;i<=7;i++)
   pinLow();
   if (data & 0x01) //write 1
     delayMicroseconds(7);
     pinIn();
   else //write 0
     pinIn();
   data>>=1;
void convertTemp()
 byte i;
 byte data = 0x44;
 for(i=0;i<=7;i++)
   pinLow();
     pinIn();
   else //write 0
     pinIn();
   data>>=1;
 pullupHigh(); //pull pin 6 high for the conversion
 delay(750); //conversion time is 750 milliseconds
 pullupIn(); //switch off pin 6
 pinIn();
byte readByte()
 /* timing is critical here. But timing values are different
  * from the datasheets. These values are found by trial & error.
  * The delay's should be somewhere around 15 uS.
 byte data=0;
 byte i;
 byte bit;
 for(i=0;i<8;i++)
   pinLow();
   delayMicroseconds(1); // > 2 doesn't work
   pinIn();
   delayMicroseconds(1); // >5 doesn't work
   bit = digitalRead(DQ) & 0x01;
   data >>= 1;
   if (bit) data |= 0x80;
   delayMicroseconds(50); //doesn't seem to be necessary
 return(data);
void pinHigh()
 pinMode(DQ,OUTPUT);
 digitalWrite(DQ,HIGH);
void pinLow()
 pinMode(DQ,OUTPUT);
 digitalWrite(DQ,LOW);
void pinIn()
 pinMode(DQ,INPUT);
 //pullupIn(); //om de resistor pull-up te laten werken
void pullupHigh()
 pinMode(PU,OUTPUT);
 digitalWrite(PU,HIGH);
 digitalWrite(pin13, HIGH);
void pullupLow()
 pinMode(PU,OUTPUT);
 digitalWrite(PU,LOW);
 digitalWrite(pin13, LOW);
void pullupIn()
 pinMode(PU,INPUT); //necessary for resistor pull-up
void readRom()
 byte j;
 byte pad[9];
 reset();
 WriteByte(0x33);
 for(j=0;j<8;j++)
   pad[j] = readByte();
 for(j=0;j<8;j++)
   Serial.print(pad[j], HEX);
   Serial.print(" ");
 Serial.println("read rom");
void readScratchpad()
 byte j;
 byte pad[9];
 int msb,lsb;
 WriteByte(0xBE);
 for(j=0;j<9;j++)
 for(j=0;j<9;j++)
   Serial.print(" ");
 Serial.print("read scratchpad  ");
 msb = pad[1];
 lsb = pad[0];
 if (msb <= 0x80)lsb = lsb/2;
 msb = msb & 0x80;
 if (msb >=0x80) lsb = (~lsb)+1;
 if (msb >=0x80) lsb = lsb/2;
 if (msb >=0x80) lsb = ((-1)*lsb);
 Serial.print("T =  ");
 Serial.print(lsb);
 Serial.print(" ");
void loop(void)
 readRom();
 reset();
 WriteByte(0xCC);
 convertTemp();
 reset();
 WriteByte(0xCC);
 readScratchpad();
 Serial.print("version: ");
 Serial.println(VERSION);
  delay(1000);                 // Lets not flood.
[edit]changed typo that cosinekitty discovered[/edit]
CosineKitty
This line of code scares my kitty cat    ;)
Code: [Select]
 if (digitalRead(DQ == LOW))
This compares DQ to LOW (7 == 0), which evaluates to false, or 0, then does a digitalRead of pin 0 and asks whether it returned HIGH or not.
I think you meant:
Code: [Select]
But hey, maybe it works anyway... ????
jims
I've finished. I  packaged the 1-wire functions into a library for Arduino. It includes the read and write byte functions, reset, device enumeration, and CRC computation. The comments about how one might use it are in the library source.  Sadly, it won't fit in a post anymore.
You can pick up the files at http://core.federated.com/~jim/onewire/
Create an arduino-0007/lib/targets/libraries/OneWire/ directory and put them in there. You will probably need to quit the arduino program and restart to get it to notice.  The test.c program doesn't go in the library, it was a little test program you might find useful.
The test is working fine on my unit with 4 DS18S20s connected.
Physically, I have all the DQ lines connected to my IO pin, all the grounds connected to a ground, and 4.7k ohm resistor from a Vcc to the DQ lines. It would be best to connect all the remaining pins of the DS18S20s to either Vcc or GND, then a regular DS18S20 (not a -P) would still work in either normal or parasite mode depending how you connected it.
If you are going to have any kind of wire run I would suggest looking at some of the ESD protection variations (resistor in series with IO pin and 5.5v Zener diode to ground) to keep the stress down when bad things happen.  Likewise, I think it would be possible to make this work using the internal pull-up of the Arduino, but decided that would be a needless stress with there is a short, and the resistor is a bit too big so it would be bad on longer cable runs and possibly not able to supply parasite power.
bigengineer
Quote
Strange, my code started working when I used another pin to supply current to Dq during the temperature conversion.
I am very glad that you have the device enumeration already working, that saves me a lot of time!
I will try it and report back.
bigengineer
Well jims, your code is working! I don't understand why I needed an extra pin to get my code working but your code works with just pin 7 and GND connected.
At the moment I have 3 sensors connected and all 3 give a temperature reading. Your library should become a standard library.
yerg2k
Big thanks to bigengineer and JimS! I'd never have expected it to be that delay right before conversion. Things have been busy here, so I won't get to try this out, but way to go on cracking this one guys!
mellis
Wow, jims, very cool!
What would be even cooler is if you or someone else with a working one-wire device packaged the code up as a C++ library (like Wire or SoftwareSerial), with a keywords.txt file and examples.  There's some (very sparse) documentation at http://www.arduino.cc/en/Main/Libraries) along with an example library that should be easy to adapt.  Any takers?
bigengineer
I have a (simple) working example, that could be added. What is still missing from the library is readout in degrees celsius, I have that too. Also missing is more precise readout. The Application note in which it is explained seems to have disappeared. Except for the keywords.txt I think the library is pretty much done.
It is all jims work, so I guess he will want to pack it up too. Otherwise I will give it a shot. But I need someone to have look at it afterwards.
