Topic: Help on random led coloring? (Read 9971 times) previous topic - next topic
ikestarm
I am new to arduino and was wondering how to make an led flash one random color for a project I am doing. I have looked at the page on the arduino site and other ones too but when I set it to show one color, at random and stay on that color, it always shows the same color, no matter what, making it not very random. Please help! [smiley=cheesy.gif]
ill_switch
A single LED will only ever emit one color of light (within a very small window of variation.) If you want multiple colors, you need a so-called multicolor LED, which are really just multiple LEDs in the same package - you basically need to power (and/or control) each LED separately.
These multicolor LEDs are available in lots of two- and three-color combinations, i.e. red/green, and red/green/blue. With any multi-color LED, you can get a whole range of colors between the various endpoints by fading each color appropriately. For instance, if you have a red/blue LED, you can get purple light by powering both equally - or, purplish-red light by powering the red at full power, and the blue at a smaller current (or PWM duty cycle).
So, to give you the short answer, if you want lots of colors, go get an RGB LED, and feed each color with it's own PWM signal, from one of the PWM pins on your arduino. Then, apply the logic you've already seen in the examples you talked about (i.e. fading) to blend the colors. Here is an example of such an LED:
http://www.sparkfun.com/commerce/product_info.php?products_id=9264
Note that it has a single cathode, and an anode for each color.
ikestarm
Sorry, I guess I should have mentioned that I am dealing with an rgb led. I want it to show one random color but that one random color is always the same.
webster
well for a big mix of random colors you could create a random value generator for the pwm of each rgb pin. http://arduino.cc/en/Reference/RandomSeed
ikestarm
yes, but I want it to show just one random color and stop.
TBAr
#5
Sep 13, 2009, 04:17 am Last Edit: Sep 13, 2009, 06:41 am by TBAr Reason: 1
Can you post your code so we can see how you are using randomSeed()? It is the key to what you want to do. Don't forget to use the code button
  • when you post code.
ikestarm
#6
Sep 13, 2009, 03:55 pm Last Edit: Sep 13, 2009, 03:57 pm by ikestarm Reason: 1
I'm using this code:
#define PIN_RED            9
#define PIN_GREEN         10
#define PIN_BLUE          11
void color(byte v)
 digitalWrite(PIN_RED,    v       & 0x01);
 digitalWrite(PIN_GREEN, (v >> 1) & 0x01);
 digitalWrite(PIN_BLUE,  (v >> 2) & 0x01);
 pinMode(PIN_RED,   OUTPUT);
 pinMode(PIN_GREEN, OUTPUT);
 pinMode(PIN_BLUE,  OUTPUT);
 randomSeed(analogRead(0));
 color(random(100));
I got it off a website and changed it a little so it doesn't change colors all the time but no matter what, my led just shows white and it sort of blinks rapidly so all you see is this white light that is flashing extremely fast
AWOL
#7
Sep 13, 2009, 06:11 pm Last Edit: Sep 13, 2009, 06:26 pm by AWOL Reason: 1
Code: [Select]
color(random(100));
What happens if you move the "color(random(100));" into "setup()", and leave "loop();" empty?
That'll stop the flashing.
The white light is probably your eye "averaging" the rapidly-changing colours caused by "loop ()", well, looping and picking a new colour every time.
BTW "random (8);" should work just as well.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
ikestarm
#8
Sep 13, 2009, 07:47 pm Last Edit: Sep 13, 2009, 07:53 pm by ikestarm Reason: 1
that worked, but how do I get it to be a tatally random color not one of eight?
AWOL
#9
Sep 13, 2009, 08:16 pm Last Edit: Sep 13, 2009, 08:25 pm by AWOL Reason: 1
Then you need a random number in the range 0.. 224-1, and use PWM pins for the LEDs and "analogWrite". (actually, you'd probably get away with a number in the range 0..215-1, but you'd still need "analogWrite", scaled appropriately)
ikestarm
Sorry, I'm still quite new to arduino and I don't really get what you're saying. Could you please show mw an example?
AWOL
#11
Sep 13, 2009, 10:20 pm Last Edit: Sep 13, 2009, 10:20 pm by AWOL Reason: 1
If you use a single binary bit to light an LED, the best you can manage is eight distinct states.
LEDs are either ON or OFF (HIGH or LOW).
The Arduino has pins which are PWM-capable (for the Duemilanova these are 3, 5 ,6, 9, 10 and 11, accesible via "analogWrite").
A PWM signal gives a fixed-frequency, variable mark:space ratio which approximates an analogue signal; the higher the mark (HIGH) time, the brighter a connected LED will appear.
So, if you have a LED connected to, say, pin 3, "analogWrite (3, 128);" will give a roughly 50:50 on/off signal, so the LED will appear less bright than if you'd executed "analogWrite (3, 255);"
(the relationship is not linear, but that's complicating things)
So, for your example: (uncompiled, untested)
Code: [Select]
const byte PIN_RED     = 3;
const byte PIN_GREEN = 5;
const byte PIN_BLUE    = 6;
void color(unsigned long v)
analogWrite(PIN_RED,    v  & 255);
analogWrite(PIN_GREEN, (v >> 8) & 255);
analogWrite(PIN_BLUE,  (v >> 16) & 255);
color((unsigned long)random(0x01000000));
ikestarm
Thanks, the code worked, and I understand it now. :) Now do you think at any one color it will know the value of the blue, red, and green pins so I can do something else with it?
AWOL
#13
Sep 14, 2009, 08:58 am Last Edit: Sep 14, 2009, 11:34 am by AWOL Reason: 1
Not quite sure what you want to do, but there are several things you could do:
Code: [Select]
byte red = v & 255;
byte green = (v >> 8) & 255;
byte blue = (v >> 16) & 255;
analogWrite(PIN_RED,    red);
analogWrite(PIN_GREEN, green);
analogWrite(PIN_BLUE,  blue);
// red green blue values are available for other uses
or you could declare "red" "green" "blue" with global scope, or call "random (256);" three times, and pass separate values to your LED lighting function.
Lots of different ways.
ikestarm
Ok, I did that, and then I did this code to test it:
Code: [Select]
const byte PIN_RED     = 9;
const byte PIN_GREEN = 10;
const byte PIN_BLUE    = 11;
byte red = v & 255;
 if(PIN_RED > 100);{
   Serial.print("redled on ");
   if(PIN_RED < 100);{
    Serial.print("redled off ");
     delay(3000);
Unfortunately, the serial monitor just says "led on led off" every 3 seconds. Why does it do that?
