Topic: Help on random led coloring? (Read 9989 times) previous topic - next topic
ikestarm
Code: [Select]
 randomSeed(analogRead(0));
 testRGB();
void testRGB(){
 led1.setRGB(255,0,0);
 led1.updateLED();
 led1.setRGB(0,255,0);
 led1.updateLED();
 led1.setRGB(0,0,255);
 led1.updateLED();
 delay(2000);
 return;
  led1.setRandomHue();
 led1.setSat(255);
 led1.setVal(255);
 led1.updateLED();
 delay(3000);
 led1.setRandomColor();
 led1.updateLED();
It says " error: expected constructor, destructor, or type conversion before '.' token" right here:
[glow]led1.setRandomHue();[/glow]
AWOL
#46
Sep 24, 2009, 08:29 am Last Edit: Sep 24, 2009, 09:09 am by AWOL Reason: 1
You can't just paste code between function definitions like that.
Code: [Select]
 led1.updateLED();
(untested)
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
ikestarm
#47
Sep 24, 2009, 10:26 pm Last Edit: Sep 24, 2009, 10:26 pm by ikestarm Reason: 1
yours worked, only every color it showed was white, or at least all the values were at zero the whole time. I got this:
Code: [Select]
 led1.setSat(255);
 led1.setVal(255);
 led1.updateLED();
 delay(3000);
 led1.updateLED();
but how do I make it so that it doesn't flash, wait for a second or more, and then show the color? I just want it to show the color
3d29
I'm not sure I understood what you want but here's my attempt to help you:
Seems like you just need to remove the Delay.
Have fun
AWOL
Quote
It wasn't mine, it was yours, with the code in proper functions.
As I said, untested - I don't have your hardware, I was just working on the code as you posted it.
ikestarm
it doesn't matter whose it was I was just referring to what you posted
ikestarm
Are these two the same?:
Code: [Select]
 led1.setSat(255);
 led1.setVal(255);
 led1.updateLED();
Code: [Select]
 led1.updateLED();
And I know it's probably inevitable, but why are there occaisionally 3 of the same colors in a row?
ikestarm
Code: [Select]
int buttonstate;
int val;
int val2;
int switchpin = 5;
int redPin = 3;
int bluePin = 5;
int greenPin = 6;
int redIn = 2;
int greenIn = 3;
int blueIn = 4;
int redVal;
int greenVal;
int blueVal;
#ifndef RGBCommonLED_H
#define RGBCommonLED_H
#include "WProgram.h"
class RGBCommonLED {
public:
 RGBCommonLED(int rpin, int gpin, int bpin);
 ~RGBCommonLED();
 void setRGB(byte r, byte g, byte b);
 void setHSV(byte h, byte s, byte v);
 void setColor(unsigned long v);
 void setHue(byte level);
 void setSat(byte level);
 void setVal(byte level);
 void adjHue(int level);
 void adjSat(int level);
 void adjVal(int level);
 void setRandomColor();
 void setRandomHue();
 void setRandomSat();
 void setRandomVal();
 void setHSVLevel(int section, byte level);
 void adjHSVLevel(int section, int level);
 void setRandomHSVLevel(int section);
 void updateLED();
 void HSVToRGB( unsigned int inHue, unsigned int inSaturation, unsigned int inValue,
   unsigned int *oR, unsigned int *oG, unsigned int *oB );
 void RGBToHSV( unsigned int inRed, unsigned int inGreen, unsigned int inBlue,
   unsigned int *oH, unsigned int *oS, unsigned int *oV );
 void updateHSVFromRGB();
 int pins[3];
 int rgb[3];
 int hsv[3];
private:
 boolean hsvSet;
 void setRGBFromHSV();
 void setHSVFromRGB();
#endif
RGBCommonLED::RGBCommonLED(int rpin, int gpin, int bpin){
 pins[0] = rpin;
 pins[1] = gpin;
 pins[2] = bpin;
 hsvSet = false;
RGBCommonLED::~RGBCommonLED(){
void RGBCommonLED::setColor(unsigned long v)
 this->setRGB((v & 255),((v >> 8) & 255),(v >> 16) & 255);
void RGBCommonLED::setRGB(byte r, byte g, byte b){
 rgb[0] = r;
 rgb[1] = g;
 rgb[2] = b;
 hsvSet = false;
void RGBCommonLED::setHSV(byte h, byte s, byte v){
 hsv[0] = h;
 hsv[1] = s;
 hsv[2] = v;
 this->setRGBFromHSV();
 hsvSet = true;
void RGBCommonLED::setHSVLevel(int section, byte level){
 updateHSVFromRGB();
 hsv[section] = level;
void RGBCommonLED::setHue(byte level){
 this->setHSVLevel(0,level);
void RGBCommonLED::setSat(byte level){
 this->setHSVLevel(1,level);
void RGBCommonLED::setVal(byte level){
 this->setHSVLevel(2,level);
void RGBCommonLED::adjHSVLevel(int section, int level){
 updateHSVFromRGB();
 int th = hsv[section] + level;
 if( th < 0 ){
   th = 255 + th;
 else if( th > 255 ) {
   th = 255 - th;
 th = constrain(th,0,255);
 hsv[section] = th;
void RGBCommonLED::adjHue(int level){
 this->adjHSVLevel(0,level);
void RGBCommonLED::adjSat(int level){
 this->adjHSVLevel(1,level);
void RGBCommonLED::adjVal(int level){
 this->adjHSVLevel(2,level);
void RGBCommonLED::RGBToHSV( unsigned int inRed, unsigned int inGreen, unsigned int inBlue,
 double vals[3];
 unsigned char maxc=0, minc=0;
 double hue, sat, val;
 vals[0]=inRed;
 vals[1]=inGreen;
 vals[2]=inBlue;
 //red is set as maximum and minimum
 if(vals[1]>vals[maxc]) maxc=1;
 if(vals[2]>vals[maxc]) maxc=2;
 if(vals[1]<vals[minc]) minc=1;
 if(vals[2]<vals[minc]) minc=2;
 val = vals[maxc];
 if(vals[maxc]==0)
   sat = hue = 0;
   sat=255*(1-(vals[minc]/vals[maxc]));
   hue = 60 * ((maxc*2) + (vals[(maxc+1)%3] - vals[(maxc+2)%3])/(vals[maxc] - vals[minc]));
 if(hue < 0) hue += 360; //corrector for hues in -60 to 0 range
 *oH = hue; //map(hue,0,360,0,255);
 *oS = sat;
 *oV = val;
void RGBCommonLED::HSVToRGB( unsigned int inHue, unsigned int inSaturation, unsigned int inValue,
 if( inSaturation == 0 )
   // achromatic (grey)
   *oR = *oG = *oB = inValue;
   unsigned int scaledHue = (inHue * 6);
   unsigned int sector = scaledHue >> 8; // sector 0 to 5 around the color wheel
   unsigned int offsetInSector = scaledHue - (sector << 8);      // position within the sector
   unsigned int p = (inValue * ( 255 - inSaturation )) >> 8;
   unsigned int q = (inValue * ( 255 - ((inSaturation * offsetInSector) >> 8) )) >> 8;
   unsigned int t = (inValue * ( 255 - ((inSaturation * ( 255 - offsetInSector )) >> 8) )) >> 8;
   switch( sector ) {
   case 0:
     *oR = inValue;
     *oG = t;
     *oB = p;
   case 1:
     *oR = q;
     *oG = inValue;
     *oB = p;
   case 2:
     *oR = p;
     *oG = inValue;
     *oB = t;
   case 3:
     *oR = p;
     *oG = q;
     *oB = inValue;
   case 4:
     *oR = t;
     *oG = p;
     *oB = inValue;
   default:            // case 5:
     *oR = inValue;
     *oG = p;
     *oB = q;
void RGBCommonLED::setRandomColor(){
 this->setColor((unsigned long)random(0x01000000));
void RGBCommonLED::setRandomHue(){
 this->setRandomHSVLevel(0);
void RGBCommonLED::setRandomSat(){
 this->setRandomHSVLevel(1);
void RGBCommonLED::setRandomVal(){
 this->setRandomHSVLevel(2);
void RGBCommonLED::setRandomHSVLevel(int section){
 this->setHSVLevel(section, (unsigned int)random(0x0100));
void RGBCommonLED::updateHSVFromRGB(){
 this->setHSVFromRGB();
 hsvSet = true;
[glow]void RGBCommonLED::updateLED(){
 analogWrite(this->pins[0], rgb[0]);
 analogWrite(this->pins[1], rgb[1]);
 analogWrite(this->pins[2], rgb[2]);
 Serial.print(" R - ");
Serial.print(rgb[0] , DEC);
Serial.print(" G - ");
Serial.print(rgb[1] , DEC);
Serial.print(" B - ");
Serial.println(rgb[2] , DEC);
}[/glow]
void RGBCommonLED::setRGBFromHSV(){
 unsigned int h = hsv[0];
 unsigned int s = hsv[1];
 unsigned int v = hsv[2];
 unsigned int r = 0;
 unsigned int g = 0;
 unsigned int b = 0;
 HSVToRGB(h,s,v,&r,&g,&b);
 this->setRGB(r,g,b);
void RGBCommonLED::setHSVFromRGB(){
 unsigned int r = rgb[0];
 unsigned int g = rgb[1];
 unsigned int b = rgb[2];
 unsigned int h;
 unsigned int s;
 unsigned int v;
 this->RGBToHSV(r,g,b,&h,&s,&v);
 hsv[0] = map(h,0,360,0,255);
 hsv[1] = s;
 hsv[2] = v;
 hsvSet = true;
RGBCommonLED led1(10,11,9);
 pinMode(switchpin, INPUT);
 led1.setSat(255);
 led1.setVal(255);
 led1.updateLED();
 buttonstate = digitalRead(switchpin);
  redVal = analogRead(redIn);
 greenVal = analogRead(greenIn);
 blueVal = analogRead(blueIn);
 redVal = map(redVal, 0, 1023, 0, 255);
 greenVal = map(greenVal, 0, 1023, 0, 255);
 blueVal = map(blueVal, 0, 1023, 0, 255);
 analogWrite(redPin, redVal);
 analogWrite(greenPin, greenVal);
 analogWrite(bluePin, blueVal);
   val = digitalRead(switchpin);
 delay(10);
 val2 = digitalRead(switchpin);
  if(val == val2) {
    if(val != buttonstate) {
      if(val == LOW) {
       [glow] if(rgb[0] >= redPin) {[/glow]
        Serial.print("red is less");
Do I need to make the first highlighted part global so that it can be used for the second part that is highlighted? Because it says rgb[0] was not defined in scope for the second highlighted part. If so, how do you make it global?
