Topic: Setting up MS Visual Studio to compile/upload? (Read 6716 times) previous topic - next topic
TimLeek
By the way the avr compiler does not like spaces in folder names. So your sketch folders folders should not be in a folder such as MyDocuments\Visual Studio 2010\Projects
I will shortly make a version that copies a project to a temp folder prior to compile. This will avoid the problem.
So right now you should be able to open a .pde and a project/solution should automatically be created for you. You should then see the tool bar with the arduino boards button. If you have spaces in the .pde folder name then you will get an error when you click compile.
I assume you have the addin enabled and have set the visual micro options
TimLeek
Byt he way have you set the PDE file extension in the Visual Studio > options > text editor?
Might be best to use the visualmicro forum if you can. New updates are posted there
