Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Temperature sensor + Leds  (Read 1592 times)
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
When you put float in front of tempc, you created a local variable with the same name as the global variable, with an initial value of 0.0.
From that point on, all references to tempc are to the local variable, until it goes out of scope.
So, the 0.0 values are not surprising.
You need to change the type of the global variable to float, not create a local variable.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
I loathe unecessary globals:
Code:
const int pin = 0; // analog pin
float maxi = -100.0;
float mini = 100.0; // to start max/min temperature
  Serial.begin(9600); // start serial communication
  float tempc = 0.0;
  for(int i = 0; i < 8; i++) {
    tempc += analogRead(pin);
  tempc = (5.0 * tempc * 100.0) / (8.0 * 1024.0);
  if(tempc > maxi) {maxi = tempc;} // set max temperature
  if(tempc < mini) {mini = tempc;} // set min temperature
  Serial.print(tempc, 2);  //or however many decimal places you need
  Serial.print(" Celsius, ");
  Serial.print(maxi, 2);
  Serial.print(" Max, ");
  Serial.print(mini, 2);
  Serial.println(" Min");
  delay(1000); // delay before loop
« Last Edit: May 21, 2010, 03:15:57 pm by AWOL » Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Europe, Estonia
Offline Offline
Full Member
View Profile
Using PaulS suggestions ended up like this
Quote
int tempc = 0; // temperature variables
int tempb = 0;
int maxi = -100,mini = 100; // to start max/min temperature
int i;
for(i = 0;i<=7;i++)
float tempb = (5.0 * tempc * 100.0) / (8.0 * 1024.0);
if(tempb > maxi) {maxi = tempb;} // set max temperature
if(tempb < mini) {mini = tempb;} // set min temperature
Serial.print(tempb,DEC);
Serial.print(maxi,DEC);
Serial.print(mini,DEC);
tempc = 0;
tempb = 0;
And serial monitor
Quote
23.4375000000 Celsius, 23 Max, 23 Min
« Last Edit: May 21, 2010, 03:13:12 pm by Fredx » Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Code:
int tempb = 0;
Why?
Code:
Isn't ten places of decimals excessive?
« Last Edit: May 21, 2010, 03:17:36 pm by AWOL » Logged
Europe, Estonia
Offline Offline
Full Member
View Profile
AWOL,
using your code, serial monitor show this:
Quote
23.44 Celsius, 10111 Max, 10111 Min
It is good that eventually there are 2 decimal places, but have to manage out why are Max / Min displayed in binary ( is it bin ? )
Serial.print(tempc, 2); -> shows 23.44
but
Serial.print(maxi, 2); -> shows 11010
« Last Edit: May 21, 2010, 03:20:55 pm by Fredx » Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Have another look at reply 16.
« Last Edit: May 21, 2010, 03:19:20 pm by AWOL » Logged
Europe, Estonia
Offline Offline
Full Member
View Profile
Reply #16 working fine!
Big thanks to PaulS, Groove and AWOL. As I just got into Arduino-ing, I don't understand the programming very well. Actually I have never done programs before smiley-razz
« Last Edit: May 21, 2010, 03:28:25 pm by Fredx » Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
The reason you were getting ten places of decimals is because "DEC" has the value 10.
For integer datatypes, the "print" method uses the second parameter as a base, so "DEC" = 10, "BIN" = 2, "HEX" = 16. So, printing an integer with the second parameter of 2 prints the result in binary.
For floats, the "print" method specifies the number of decimal places (from 0018) to be printed.
Logged
Europe, Estonia
Offline Offline
Full Member
View Profile
Understood. Thanks again!
I just came up with an idea to display the temperature with only 2 LEDs. But I have no idea how to make it work.  The idea -
Quote
Lets say the temperature is 25 degrees.
There are 2 LEDs connected to Arduino.
The script should make the first led blink TWO times
and after that the second led FIVE times.
Is it very hard to make it? Any ideas from where to start?
Quote
IF the FIRST number is 1,
THEN (led HIGH).... delay(1000) .... (led LOW)
IF the FIRST number is 2,
THEN (led HIGH).... delay(1000) .... (led LOW)...delay(1000)..(led HIGH).... delay(1000) .... (led LOW)
IF the FIRST number is 3,
THEN (led HIGH).... delay(1000) .... (led LOW)...delay(1000)..(led HIGH).... delay(1000) .... (led LOW)...delay(1000)...(led HIGH).... delay(1000) .... (led LOW)
ELSE IF the FIRST number is 0,
THEN DO nothing
IF the SECOND number is 1,
etc...
« Last Edit: May 21, 2010, 04:08:08 pm by Fredx » Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Think about how you'd break down "25" into "2" and "5".
The rest is simple.
Ten to fifteen lines of code, maximum.
Logged
Europe, Estonia
Offline Offline
Full Member
View Profile
Found something that may be useful
Code:
int extractDigit(int number, int place)
for(int i = 0; i < place; ++i)
number /= 10; //get rid of the preceding digits
return number % 10; //now ignore all of the following ones
though this is C++
the key to extracting digits is using integer and modular division. You could directly access no. 9 in 1981 with (1981 / 100) % 10. The reason this works is that 1981/100 = 19, and 19 % 10 = 9.
Also found premade 7-segment script
Quote
#define NUM_DIGITS 4
// table of 7-segment patterns
const byte seg_def[]  = // segment patterns for digits 0-9
  {//GFEDCBA
    B0111111,  // '0'
    B0000110,  // '1'
    B1011011,  // '2'
    B1001111,  // '3'
    B1100110,  // '4'
    B1101101,  // '5'
    B1111101,  // '6'
    B0000111,  // '7'
    B1111111,  // '8'
    B1100111   // '9'
byte digit_array[NUM_DIGITS];
void NumberToArray(word number)
  char i;
  // initialize all digits to the empty pattern (no segments lit)
  for (i=0;i<NUM_DIGITS;i++) digit_array=0;
  // extract each digit (right to left)
  for (i=NUM_DIGITS-1;i>=0;i--) {
    // extract least significant digit as an index into the
    // segment pattern table
    digit_array=seg_def[number%10];
    // get next digit
    number=number/10;
    // exit if there are no more digits to avoid leading zeroes
    if (number==0) break;
  }/*for*/
}/*NumberToArray*/
Ok, this goes out of hand. It is 01:07 at night, must go to sleep
« Last Edit: May 21, 2010, 05:08:35 pm by Fredx » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
though this is C++
Good thing that's what the Arduino is programmed in.
Logged
Europe, Estonia
Offline Offline
Full Member
View Profile
That was bad..
I suppose, this should do the trick
Code:
void digits ()                            // Function to display the digits
    tempc_ones = tempc % 10;           // Get the 1's digit of degrees
    if (tempc>=10){                      // If degrees greater than 10
    tempc_tens = tempc / 10;}         // Get 10's digit of degrees
    else {tempc_tens = 0;}               // Otherwise 10s is 0
« Last Edit: May 22, 2010, 04:25:24 am by Fredx » Logged
Europe, Estonia
Offline Offline
Full Member
View Profile
Ok, somehow got it work. Now have to think how to add leds.
Quote
int digit1 = 0;
int digit2 = 0;
int tempc = 0;
digit1 = tempc / 10; // get the ten's digit
digit2 = tempc % 10; // get the one's digit
Serial.println(digit1);
Serial.println(digit2);
« Last Edit: May 22, 2010, 05:46:08 am by Fredx » Logged
Europe, Estonia
Offline Offline
Full Member
View Profile
How do I make leds blink the number (of times) of digits?
Quote
if(digit1 = 0){
if (digit1 = 1){
  digitalWrite(LEDpin1, HIGH);
digitalWrite(LEDpin1, LOW);
.... etc
THIS ISN'T CORRECT
« Last Edit: May 22, 2010, 06:47:47 am by Fredx » Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
