Topic: Temperature sensor + Leds (Read 11621 times) previous topic - next topic
AWOL
#30
May 22, 2010, 01:50 pm Last Edit: May 22, 2010, 01:50 pm by AWOL Reason: 1
Quote
if (digit1 [glow]=[/glow] 1){
.... etc
THIS ISN'T CORRECT
D a m n   right  ;)
You need a "for" loop.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
D3C3PT1C0N
#31
May 22, 2010, 02:25 pm Last Edit: May 22, 2010, 04:57 pm by Fredx Reason: 1
Oh My God, I (totally noob) Got It!
Full working code:
Quote
const int pin = 0; // analog pin
int digit1 = 0;
int digit2 = 0;
int tempc = 0;
int LEDpin1 =  12;
int LEDpin2 =  13;
int LEDpin3 =  11;
int var;
 Serial.begin(9600); // start serial communication
   pinMode(LEDpin1, OUTPUT);
     pinMode(LEDpin2, OUTPUT);
       pinMode(LEDpin3, OUTPUT);
 for(int i = 0; i < 8; i++) {
   tempc += analogRead(pin);
tempc = (5.0 * tempc * 100.0) / (8.0 * 1024.0);
digit1 = tempc / 10; // get the ten's digit
digit2 = tempc % 10; // get the one's digit
var = 0;
while(var < digit1){
   digitalWrite(LEDpin1, HIGH);
 digitalWrite(LEDpin1, LOW);
 var++;
   digitalWrite(LEDpin2, HIGH);
 digitalWrite(LEDpin2, LOW);
 var = 0;
while(var < digit2){
   digitalWrite(LEDpin3, HIGH);
 digitalWrite(LEDpin3, LOW);
 var++;
Serial.println(tempc,DEC);
delay(1400); // delay before loop
I think that if the temperature is 22.9 degrees, it still gives me 22 degrees.
Maybe someone knows how to round 22.9 to 23 degrees?
I mean to round this value:
AWOL
#32
May 22, 2010, 03:58 pm Last Edit: May 22, 2010, 04:02 pm by AWOL Reason: 1
Quote
Same as always - add 0.5, and assign the result to an "int".
D3C3PT1C0N
#33
May 22, 2010, 04:53 pm Last Edit: May 22, 2010, 05:12 pm by Fredx Reason: 1
Code: [Select]
int tempb = tempc + 0.5;
Does it do this:
22.1 + 0.5 = 22.6 -> ROUNDED to 22
22.4 + 0.5 = 22.9 -> ROUNDED to 22
22.6 + 0.5 = 23.1 -> ROUNDED to 23
Isn't "tempc" already been rounded, because it's INT ? (plz look Reply #31)
PaulS
#34
May 22, 2010, 06:05 pm Last Edit: May 22, 2010, 06:05 pm by PaulS Reason: 1
Quote
Does it do this:
Yes. Except that the number is truncated, not rounded.
Quote
No. When a floating point number is stored in an int, the decimal portion is truncated.
D3C3PT1C0N
#35
May 22, 2010, 07:59 pm Last Edit: May 22, 2010, 08:06 pm by Fredx Reason: 1
Thank you.
Is it ok when i use temperature sensor WITHOUT a resistor?
In datasheet it is written:
1) Operates from 4 to 30 Volts
2) Less than 60 µA current drain
3) Low impedance output, 0.1 ohm for 1mA load
4) Supply Voltage +35V to -0.2V
5) Output Voltage +6V to -1.0V
6) Output Current 10 mA
D3C3PT1C0N
#36
May 22, 2010, 08:16 pm Last Edit: May 22, 2010, 10:06 pm by Fredx Reason: 1
@ Ladyada.net -> It seems that I can use it without resistor.
I noticed that Duemilanove-s power consumption is quite noticeable -
I connected new 9V battery to my project and after about 3 hours continuous use the voltage level has fallen from 9.5V to 7.7V
So approximately 3-4 hours more and the minumum Operating Voltage is exceeded. Should conside to grab some rechargeable batteries.
D3C3PT1C0N
#37
May 24, 2010, 11:29 am Last Edit: May 24, 2010, 11:57 am by Fredx Reason: 1
Just for curiosity - is Arduino capable of blinking 2 leds at the same time?
For example, when the temperature is 23 degrees, then both leds start to blink at the same time, one just does 1 blink extra? I know that the commands executed by arduino can't be run in parallel.. but maybe with a little shift.
Maybe it is possible to add extra variable
Quote
var = 0;
while(var < digit1, var < digit2){
<- I know this is wrong but maybe some other statement will do?
and
and
var++;
PaulS
Quote
while(var < digit1, var < digit2){ <- I know this is wrong but maybe some other statement will do?
Code: [Select]
while(var < digit1 && var < digit2)
 var++;
Both lights will blink at the same time (or close enough that you can't tell the difference), the same number of times.
D3C3PT1C0N
#39
May 24, 2010, 12:09 pm Last Edit: May 24, 2010, 12:24 pm by Fredx Reason: 1
Thanks for fast reply :)
But what happens, if we have a situation like this? Do they both blink 2 times or 3 times?
Quote
digit1 = 2;
digit2 = 3;
 var++;
Is it possible to make these leds blink different number of times?
It sounds quite complicated..
it is 23 degrees:
Led1__Led2
BLINK BLINK <- at the same time
BLINK BLINK
______BLINK
PaulS
With that while loop, they will blink twice. Try this:
Code: [Select]
int val1 = 3;
int val2 = 8;
int val = 0;
while(val < val1 || val < val2)
  if(val < val1)
    digitalWrite(ledPin1, HIGH);
  if(val < val2)
    digitalWrite(ledPin2, HIGH);
  digitalWrite(ledPin1, LOW);
  digitalWrite(ledPin2, LOW);
  val++;
D3C3PT1C0N
#41
May 24, 2010, 02:30 pm Last Edit: May 24, 2010, 02:41 pm by Fredx Reason: 1
almost, except (for 23 degrees) they dont blink, but led2 stays a little longer ON than led1.
Let it be.. im working with another project.
Thank you for your help!
The second project i'm planning, is to add two input buttons to arduino, so that when i press button no. 1 - then arduino starts to measure the temperature (for 3 times) and when i press button no. 2 - arduino starts to measure something else (maybe humidity... but i haven't got the sensor yet).
PaulS
Put the missing delay after turning the LEDs off back in, and it should work.
D3C3PT1C0N
leds light up with a little shift, but it's ok.
Thanks again!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
