UK
« Reply #30 on: May 22, 2010, 06:50:31 am » |
if (digit1 [glow]=[/glow] 1){ .... etc
THIS ISN'T CORRECT D a m n right  You need a "for" loop.
« Last Edit: May 22, 2010, 06:50:55 am by AWOL »
Europe, Estonia
« Reply #31 on: May 22, 2010, 07:25:58 am » |
Oh My God, I (totally noob) Got It!Full working code: const int pin = 0; // analog pin int digit1 = 0; int digit2 = 0; int tempc = 0; int LEDpin1 = 12; int LEDpin2 = 13; int LEDpin3 = 11; int var;
void setup() { Serial.begin(9600); // start serial communication pinMode(LEDpin1, OUTPUT); pinMode(LEDpin2, OUTPUT); pinMode(LEDpin3, OUTPUT); }
void loop() { for(int i = 0; i < 8; i++) { tempc += analogRead(pin); }
tempc = (5.0 * tempc * 100.0) / (8.0 * 1024.0);
digit1 = tempc / 10; // get the ten's digit digit2 = tempc % 10; // get the one's digit
var = 0; while(var < digit1){ digitalWrite(LEDpin1, HIGH); delay(500); digitalWrite(LEDpin1, LOW); delay(500); var++; }
digitalWrite(LEDpin2, HIGH); delay(500); digitalWrite(LEDpin2, LOW); delay(500); var = 0; while(var < digit2){ digitalWrite(LEDpin3, HIGH); delay(500); digitalWrite(LEDpin3, LOW); delay(500); var++; }
Serial.println(tempc,DEC);
delay(1400); // delay before loop }
I think that if the temperature is 22.9 degrees, it still gives me 22 degrees. Maybe someone knows how to round 22.9 to 23 degrees?I mean to round this value: tempc = (5.0 * tempc * 100.0) / (8.0 * 1024.0);
« Last Edit: May 22, 2010, 09:57:29 am by Fredx »
UK
« Reply #32 on: May 22, 2010, 08:58:28 am » |
Maybe someone knows how to round 22.9 to 23 degrees? Same as always - add 0.5, and assign the result to an "int".
« Last Edit: May 22, 2010, 09:02:26 am by AWOL »
Europe, Estonia
« Reply #33 on: May 22, 2010, 09:53:54 am » |
int tempb = tempc + 0.5; Does it do this: 22.1 + 0.5 = 22.6 -> ROUNDED to 2222.4 + 0.5 = 22.9 -> ROUNDED to 2222.6 + 0.5 = 23.1 -> ROUNDED to 23Isn't "tempc" already been rounded, because it's INT ? (plz look Reply #31)
« Last Edit: May 22, 2010, 10:12:56 am by Fredx »
Seattle, WA USA
Seattle, WA USA
« Reply #34 on: May 22, 2010, 11:05:19 am » |
Does it do this:
22.1 + 0.5 = 22.6 -> ROUNDED to 22 22.4 + 0.5 = 22.9 -> ROUNDED to 22 22.6 + 0.5 = 23.1 -> ROUNDED to 23 Yes. Except that the number is truncated, not rounded. Isn't "tempc" already been rounded, because it's INT ? No. When a floating point number is stored in an int, the decimal portion is truncated.
« Last Edit: May 22, 2010, 11:05:57 am by PaulS »
Europe, Estonia
« Reply #35 on: May 22, 2010, 12:59:04 pm » |
Thank you. Is it ok when i use temperature sensor WITHOUT a resistor?In datasheet it is written: 1) Operates from 4 to 30 Volts 2) Less than 60 µA current drain 3) Low impedance output, 0.1 ohm for 1mA load 4) Supply Voltage +35V to -0.2V 5) Output Voltage +6V to -1.0V 6) Output Current 10 mA
« Last Edit: May 22, 2010, 01:06:57 pm by Fredx »
Europe, Estonia
« Reply #36 on: May 22, 2010, 01:16:09 pm » |
@ Ladyada.net -> It seems that I can use it without resistor.  I noticed that Duemilanove-s power consumption is quite noticeable - I connected new 9V battery to my project and after about 3 hours continuous use the voltage level has fallen from 9.5V to 7.7V So approximately 3-4 hours more and the minumum Operating Voltage is exceeded. Should conside to grab some rechargeable batteries.
« Last Edit: May 22, 2010, 03:06:08 pm by Fredx »
Europe, Estonia
« Reply #37 on: May 24, 2010, 04:29:53 am » |
Just for curiosity - is Arduino capable of blinking 2 leds at the same time? For example, when the temperature is 23 degrees, then both leds start to blink at the same time, one just does 1 blink extra? I know that the commands executed by arduino can't be run in parallel.. but maybe with a little shift. Maybe it is possible to add extra variable var = 0; while(var < digit1, var < digit2){ <- I know this is wrong but maybe some other statement will do? digitalWrite(LEDpin1, HIGH); and digitalWrite(LEDpin2, HIGH); delay(500); digitalWrite(LEDpin1, LOW); and digitalWrite(LEDpin2, LOW); delay(500); var++; }
« Last Edit: May 24, 2010, 04:57:14 am by Fredx »
Seattle, WA USA
Seattle, WA USA
« Reply #38 on: May 24, 2010, 04:58:20 am » |
while(var < digit1 && var < digit2) { digitalWrite(LEDpin1, HIGH); digitalWrite(LEDpin2, HIGH); delay(500);
digitalWrite(LEDpin1, LOW); digitalWrite(LEDpin2, LOW); delay(500); var++; } Both lights will blink at the same time (or close enough that you can't tell the difference), the same number of times.
Europe, Estonia
« Reply #39 on: May 24, 2010, 05:09:16 am » |
Thanks for fast reply  But what happens, if we have a situation like this? Do they both blink 2 times or 3 times? digit1 = 2; digit2 = 3;
Is it possible to make these leds blink different number of times? It sounds quite complicated.. it is 23 degrees: Led1__Led2 BLINK BLINK <- at the same time BLINK BLINK ______BLINK
« Last Edit: May 24, 2010, 05:24:07 am by Fredx »
Seattle, WA USA
Seattle, WA USA
« Reply #40 on: May 24, 2010, 07:02:52 am » |
With that while loop, they will blink twice. Try this: int val1 = 3; int val2 = 8; int val = 0; while(val < val1 || val < val2) { if(val < val1) digitalWrite(ledPin1, HIGH); if(val < val2) digitalWrite(ledPin2, HIGH);
digitalWrite(ledPin1, LOW); digitalWrite(ledPin2, LOW);
val++; }
Europe, Estonia
« Reply #41 on: May 24, 2010, 07:30:48 am » |
almost, except (for 23 degrees) they dont blink, but led2 stays a little longer ON than led1.
Let it be.. im working with another project.
Thank you for your help!
The second project i'm planning, is to add two input buttons to arduino, so that when i press button no. 1 - then arduino starts to measure the temperature (for 3 times) and when i press button no. 2 - arduino starts to measure something else (maybe humidity... but i haven't got the sensor yet).
« Last Edit: May 24, 2010, 07:41:58 am by Fredx »
Seattle, WA USA
Seattle, WA USA
« Reply #42 on: May 24, 2010, 07:40:00 am » |
Put the missing delay after turning the LEDs off back in, and it should work.
Europe, Estonia
« Reply #43 on: May 24, 2010, 07:52:17 am » |
leds light up with a little shift, but it's ok. Thanks again!
