Topic: Arduino Zero TCC Capture (Read 27545 times) previous topic - next topic
electro_95
I've been reading over documentation and Atmel studio examples all day for SAMD processors trying to figure out how to setup the TCC module in capture mode.  So far the vast majority of examples that I have found involve operating the timers for generating waveform outputs.
Some of the helpful code examples taht I've found are:
https://github.com/manitou48/ZERO
and
https://github.com/maxbader/arduino_tools
Then there are docs which explain operating the module in PWP mode.  However they stop short of providing a readable example code.  Then there is this app note for D20 that doesn't compile in Atmel Studio:
http://www.atmel.com/images/atmel-42267-tc-capture-on-external-interrupt-with-the-event-system-on-sam-d20_applicationnote_at05567.pdf
So I'm just curious if there is anyone out there who has had success with the capture mode of SAMD?
What I really want to do is detect pulse width and period of a signal that is connected to one of my Arduino Zero pins.  The receive an interrupt each time that new pulses arrive.
electro_95
Ok so here is an update as to where I am at.  first here is the code:
Code: [Select]
uint32_t last = 0;
uint32_t now = 0;
uint32_t width = 0;
uint32_t period = 0;
uint32_t irqs = 0;
// the setup function runs once when you press reset or power the board
  // initialize digital pin 13 as an output.
  pinMode(27, INPUT_PULLUP);
  pinMode(LED_BUILTIN, OUTPUT);
  while (!Serial);
  Serial.println("Hello!");
  // Configure the Clock
  GCLK->CLKCTRL.reg = (uint16_t) (GCLK_CLKCTRL_CLKEN | GCLK_CLKCTRL_GEN_GCLK0 | GCLK_CLKCTRL_ID( GCM_TC1_TC2)) ;
  while ( GCLK->STATUS.bit.SYNCBUSY == 1 ); // wait for sync
  // Diable the Timer
  REG_TC1_CTRLA &= ~TC_CTRLA_ENABLE;
  // Set prescaler and make timer a 32bit counter
  REG_TC1_CTRLA |= TC_CTRLA_PRESCALER_DIV1 | TC_CTRLA_MODE(TC_CTRLA_MODE_COUNT32_Val);   // Set perscaler
  // Connect the MCE0 capture channel to the Event control
  REG_TC1_EVCTRL |= TC_EVCTRL_MCEO0 | TC_EVCTRL_TCEI | TC_EVCTRL_EVACT_PWP;
  // Setup Interrupts
  REG_TC1_INTENSET = 0;              // disable all interrupts
  REG_TC1_INTENSET |= TC_INTENSET_OVF | TC_INTENSET_MC0;  // Overflow and MCE0 capture
  NVIC_EnableIRQ(TC1_IRQn);
  // Enable TC
  REG_TC1_CTRLA |= TC_CTRLA_ENABLE ;
  Serial.println("TC Enabled!");
  attachInterrupt(27,pin_irq,CHANGE);
  EIC->EVCTRL.bit.EXTINTEO7 = 1;
  PORT->Group[0].PMUX[27/2].bit.PMUXO = PINMUX_PA27A_EIC_EXTINT7 & 0xFFFF;
  PM->APBCMASK.reg |= PM_APBCMASK_EVSYS;
  GCLK->CLKCTRL.reg = (uint16_t) (GCLK_CLKCTRL_CLKEN | GCLK_CLKCTRL_GEN_GCLK0 | GCLK_CLKCTRL_ID_EVSYS_0);
  while (GCLK->STATUS.bit.SYNCBUSY);
  EVSYS->CTRL.reg = EVSYS_CTRL_SWRST;
  EVSYS->CHANNEL.reg = EVSYS_CHANNEL_PATH_ASYNCHRONOUS | EVSYS_CHANNEL_EVGEN(EVSYS_ID_GEN_EIC_EXTINT_7) | EVSYS_CHANNEL_CHANNEL(0); // Maybe CH+1 but why?
  EVSYS->USER.reg = (uint16_t) (EVSYS_USER_USER(EVSYS_ID_USER_TC1_EVU) | EVSYS_USER_CHANNEL(0));
  EVSYS->INTENSET.bit.EVD0 = 1;
// the loop function runs over and over again forever
  now = REG_TC1_COUNT32_COUNT;
  width = REG_TC1_COUNT32_CC0;
  period = REG_TC1_COUNT32_CC1;
  Serial.print("Count: ");
  Serial.println(now);
  Serial.print("Delta: ");
  Serial.println(now-last);
  Serial.print("Width: ");
  Serial.println(width);
  Serial.print("Period: ");
  Serial.println(period);
  Serial.print("IRQs: ");
  Serial.println(irqs);
  irqs = 0;
  last = now;
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  //Serial.println("low");// wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
  delay(1000);              // wait for a second
void pin_irq() {
  Serial.println("pin_irq");
void TC1_Handler()
  irqs++;
  //Serial.println(irqs);
  //REG_TC1_INTFLAG = 0x00;
  //Serial.println(REG_TC1_INTFLAG);
  TcCount32* TC = (TcCount32*) TC1;       // get timer struct
  if (TC->INTFLAG.bit.OVF == 1) {  // A overflow caused the interrupt
    //digitalWrite(pin_ovf_led, irq_ovf_count % 2); // for debug leds
    //digitalWrite(pin_mc0_led, HIGH); // for debug leds
    Serial.println("OVF!");
    TC->INTFLAG.bit.OVF = 1;    // writing a one clears the flag ovf flag
    //irq_ovf_count++;                 // for debug leds
  if (TC->INTFLAG.bit.MC0 == 1) {  // A compare to cc0 caused the interrupt
    //digitalWrite(pin_mc0_led, LOW);  // for debug leds
    Serial.println("MC0!");
    TC->INTFLAG.bit.MC0 = 1;    // writing a one clears the flag ovf flag
void EVSYS_Handler() {
  Serial.println("EVSYS_IRQ");
  Serial.println( EVSYS->INTENSET.reg);
  EVSYS->INTFLAG.bit.EVD0 = 1;
So what is working:
The Timer is running in 32bit mode
The Timer overflow interrupt does work
The Pin interrupt does work
What I'm not sure about:
Is pin PA27 properly routed to the Event system?
 - Port PUX properly configured?  It should be since this is done via "pinMode(" and "attachInterrupt("
 - Eventsys properly configured?
MartinL
#2
Apr 28, 2016, 05:06 pm Last Edit: Apr 28, 2016, 05:16 pm by MartinL
Hi electro_95,
I'm also trying to get this to work, but there appears to be a mismatch between the "Period and Pulse-Width Capture Action" mode and how the events system works.
I understand that the "Period and Pulse-Width Capture Action" captures the waveform's pulse-width and period in the CC0 and CC1 registers (or vice-versa), but the problem is that the TC timer counters on the SAMD21 have no inputs and they're only able to capture input events from an event channel.
That leaves the question of how to get the input waveform to the TC timer counter? As the PORTs don't have any event functionality, that just leaves the EIC (External Interrupt Controller).
The EIC allows to you activate events, that as far as I can gather (as the datasheet doesn't explain) corresponds to the EIC interrupt flag. I believe the EIC will send out event pulses on one of the specified event channels, as the given interrupt flag is set and cleared.
So the EIC is generating a short positive pulses on the event channel for each transition of the input waveform, however the "Period and Pulse-Width Capture Action" mode by default is using the rising pulses to capture the period and the time to the following trailing pulse to capture the pulsewidth. As far as I can see the two just don't match up.
It almost appears as if the "Period and Pulse-Width Capture Action" mode was designed for a timer counter input pin, rather than an event channel.
Anyone got any ideas?
MartinL
I'm beginning to think that the event channel just toggles with each event, as I consider is probably only way interrupt events could work in conjunction with the timer.
MartinL
#4
Apr 29, 2016, 01:04 am Last Edit: Apr 29, 2016, 10:20 am by MartinL
Hi electro_95,
I finally solved it.
The code automatically captures an incoming digital waveform's period and pulse-width.
The incoming waveform is detected by enabling interrupts for level detection on the input pin. The event system is sort of a 12 channel highway between peripherals that allows them to communicate without CPU intervention. By enabling an output event for the interrupt pin (generator/sender) and the input event for a timer (user/receiver) and connecting them on a given channel, we can pass infomation about changes on the input pin to the timer using the event system. With the timer set to "Period and Pulse-Width Capture Action" mode, we can then automatically capture the period and pulse-width of the waveform.
The timer starts on the rising edge of the event line. The number of counter ticks to the subsequent trailing edge gives us the pulse-width, which is stored in the counter compare register 1 (CC1). The following rising edge gives us the period, which is stored in the counter compare register 0 (CC0). At this point the counter is reset back to 0 to start the cycle over again.
The following code outputs on the Zero's native port, the period and pulse-width of a radio controlled receiver channel in microseconds, (pulse-width: 1-2ms, period: ~22ms) using capture on TC3, at 1MHz (1us tick):
Code: [Select]
// Setup TC3 to capture pulse-width and period
volatile boolean periodComplete;
volatile uint16_t isrPeriod;
volatile uint16_t isrPulsewidth;
uint16_t period;
uint16_t pulsewidth;
  SerialUSB.begin(115200);                  // Send data back on the Zero's native port
  while(!SerialUSB);                        // Wait for the SerialUSB port to be ready
  REG_PM_APBCMASK |= PM_APBCMASK_EVSYS;     // Switch on the event system peripheral
  REG_GCLK_GENDIV = GCLK_GENDIV_DIV(3) |    // Divide the 48MHz system clock by 3 = 16MHz
                    GCLK_GENDIV_ID(5);      // Set division on Generic Clock Generator (GCLK) 5
  while (GCLK->STATUS.bit.SYNCBUSY);        // Wait for synchronization
  REG_GCLK_GENCTRL = GCLK_GENCTRL_IDC |           // Set the duty cycle to 50/50 HIGH/LOW
                     GCLK_GENCTRL_GENEN |         // Enable GCLK 5
                     GCLK_GENCTRL_SRC_DFLL48M |   // Set the clock source to 48MHz
                     GCLK_GENCTRL_ID(5);          // Set clock source on GCLK 5
  while (GCLK->STATUS.bit.SYNCBUSY);              // Wait for synchronization*/
  REG_GCLK_CLKCTRL = GCLK_CLKCTRL_CLKEN |         // Enable the generic clock...
                     GCLK_CLKCTRL_GEN_GCLK5 |     // ....on GCLK5
                     GCLK_CLKCTRL_ID_TCC2_TC3;    // Feed the GCLK5 to TCC2 and TC3
  REG_EIC_EVCTRL |= EIC_EVCTRL_EXTINTEO3;                                 // Enable event output on external interrupt 3
  attachInterrupt(12, NULL, HIGH);                                        // Attach interrupts to digital pin 12 (external interrupt 3)
  REG_EVSYS_USER = EVSYS_USER_CHANNEL(1) |                                // Attach the event user (receiver) to channel 0 (n + 1)
                   EVSYS_USER_USER(EVSYS_ID_USER_TC3_EVU);                // Set the event user (receiver) as timer TC3
  REG_EVSYS_CHANNEL = EVSYS_CHANNEL_EDGSEL_NO_EVT_OUTPUT |                // No event edge detection
                      EVSYS_CHANNEL_PATH_ASYNCHRONOUS |                   // Set event path as asynchronous
                      EVSYS_CHANNEL_EVGEN(EVSYS_ID_GEN_EIC_EXTINT_3) |    // Set event generator (sender) as external interrupt 3
                      EVSYS_CHANNEL_CHANNEL(0);                           // Attach the generator (sender) to channel 0
  REG_TC3_EVCTRL |= TC_EVCTRL_TCEI |              // Enable the TC event input
                    /*TC_EVCTRL_TCINV |*/         // Invert the event input
                    TC_EVCTRL_EVACT_PPW;          // Set up the timer for capture: CC0 period, CC1 pulsewidth
  REG_TC3_READREQ = TC_READREQ_RREQ |             // Enable a read request
                    TC_READREQ_ADDR(0x06);        // Offset of the CTRLC register
  while (TC3->COUNT16.STATUS.bit.SYNCBUSY);       // Wait for (read) synchronization
  REG_TC3_CTRLC |= TC_CTRLC_CPTEN1 |              // Enable capture on CC1
                   TC_CTRLC_CPTEN0;               // Enable capture on CC0
  while (TC3->COUNT16.STATUS.bit.SYNCBUSY);       // Wait for (write) synchronization
  //NVIC_DisableIRQ(TC3_IRQn);
  //NVIC_ClearPendingIRQ(TC3_IRQn);
  NVIC_SetPriority(TC3_IRQn, 0);      // Set the Nested Vector Interrupt Controller (NVIC) priority for TC3 to 0 (highest)
  NVIC_EnableIRQ(TC3_IRQn);           // Connect the TC3 timer to the Nested Vector Interrupt Controller (NVIC)
  REG_TC3_INTENSET = TC_INTENSET_MC1 |            // Enable compare channel 1 (CC1) interrupts
                     TC_INTENSET_MC0;             // Enable compare channel 0 (CC0) interrupts
  REG_TC3_CTRLA |= TC_CTRLA_PRESCALER_DIV16 |     // Set prescaler to 16, 16MHz/16 = 1MHz
                   TC_CTRLA_ENABLE;               // Enable TC3
  while (TC3->COUNT16.STATUS.bit.SYNCBUSY);       // Wait for synchronization
  if (periodComplete)                             // Check if the period is complete
    noInterrupts();                               // Read the new period and pulse-width
    period = isrPeriod;
    pulsewidth = isrPulsewidth;
    interrupts();
    SerialUSB.print(period);                      // Output the results
    SerialUSB.print(F("   "));
    SerialUSB.println(pulsewidth);
    periodComplete = false;                       // Start a new period
void TC3_Handler()                                // Interrupt Service Routine (ISR) for timer TC3
  // Check for match counter 0 (MC0) interrupt
  if (TC3->COUNT16.INTFLAG.bit.MC0)
                      TC_READREQ_ADDR(0x18);      // Offset address of the CC0 register
    isrPeriod = REG_TC3_COUNT16_CC0;              // Copy the period
    periodComplete = true;                        // Indicate that the period is complete
  // Check for match counter 1 (MC1) interrupt
  if (TC3->COUNT16.INTFLAG.bit.MC1)
                      TC_READREQ_ADDR(0x1A);      // Offset address of the CC1 register
    isrPulsewidth = REG_TC3_COUNT16_CC1;          // Copy the pulse-width
Rucus
I was trying to port MartinL's (big thanks to you, otherwise it will take me a lot of time to figure out these things basing from the SAMD21 datasheet alone!) code to the Adafruit Feather M0 board. Everything compiles except that when I try to run the code, it gets stuck at this line:
Code: [Select]
I think this has something to do with clock synchronization stuff, but I have no idea what happens internally when I call the attachInterrupt function.
Any help to solve this issue is much appreciated.
Thanks a lot!
-Ruch
MartinL
#6
Jul 17, 2016, 07:58 pm Last Edit: Jul 17, 2016, 08:01 pm by MartinL
Hi Rucus,
I've checked the pinout diagram of the Adafruit Feather M0 and it's the same as the Zero, so there shouldn't be any difference. The sketch should wait for pulses on digital pin 12 on either board.
Are you sure that it isn't getting stuck at the line?:
Code: [Select]
This will wait until the console is opened before proceeding with the rest of the sketch. You can just comment out this line, if you prefer to execute the sketch without waiting.
Rucus
#7
Jul 17, 2016, 10:14 pm Last Edit: Jul 17, 2016, 10:59 pm by Rucus
Hi MartinL,
Thanks for your quick response.
I am not sure though if they have the same "pinouts", if indeed we are referring to the same thing. For example in Zero, pin 12 is referring to the MISO pin, while pin 12 of the Adafruit M0 adalogger is referring to a generic IO and the MISO is actually on pin 22.
I am not using the SerialUSB for printing texts. I have pasted the code below, which is basically your code that I changed a little bit to use the Serial object of printing texts over the terminal. :)
Code: [Select]
void setup()   {
  delay(7000);  //have ample time to catch text in serial monitor
  Serial.println("My Project");
  Serial.println("Done with TC init");
  static uint8_t lineSpacePosNow = 0, lineSpacePosIdx = 9;
  // read data from the GPS in the 'main loop'
    period = isrPeriod;
    interrupts();
    Serial.print("P ");
    Serial.println(period, 2);
    Serial.print("PW ");
    Serial.println(pulsewidth, 2);
//    Serial.println("MO Intrpt");
//    Serial.println("M1 Intrpt");
The word "Done with TC init" is printed on my terminal if I comment the attachInterrupt(12, NULL, HIGH); line. I checked the function declaration at C:\Users\Ruchie\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.0.11\cores\arduino and it looks like it implements waiting for SYNCBUSY bit to get cleared. So I kind of stuck now as to what causing the code to stick somewhere and where it is happening (I hope I have a debugger to dig in further).
Thanks!
-Ruch
Rucus
Hi MartinL,
Here is by the way the exact Adafruit M0 part that I am using.
https://learn.adafruit.com/adafruit-feather-m0-adalogger/pinouts
Thanks,
Ruch
MartinL
#9
Jul 17, 2016, 11:09 pm Last Edit: Jul 17, 2016, 11:11 pm by MartinL
Hi Ruch,
The pinouts for the Adafruit Feather M0 Adalogger and the Arduino Zero are the same for digital pin 12. Both use PA19, which is physical pin 28 on the device itself.
I ran your code with an RC receiver outputting CPPM (Pulse Position Modulation) and get the following result giving you the pulse width and period in binary:
P 10111010101
PW 1011111111
P 10111001111
PW 11001100111111
P 10111010000
PW 10010100100
P 11000011110
PW 10010101010
P 10000101001
PW 10010011101
P 11010001101001
PW 10010100100
So that works OK.
If however I run it without the RC receiver attached, I get only:
My Project
Done with TC init
What pulse width and period waveform you using? The reason I ask is that if you're using a different signal you might need to reconfigure the TC3 timer.
Rucus
Hi MartinL,
You are right. They indeed use the same physical pin. I did not realize that as I was only looking at their alternate pin functions. My bad.
I am using a magnetometer sensor that outputs a signal (pulses) that varies the period as a function of magnetic field strength. The frequency is from 50kHz to 150kHz within the measuring range. So the output from sensor is continuous pulses that I need to measure the period to get the field strength.
Thanks,
Ruch
Rucus
At maximum frequency, I think that the ISR for TC3 will be called once in every ~6.67 us. Do you think it's too fast that I may need to do some configurations to ensure the micro can pickup the pulses? I am also running other modules in my system like the OLED and GPS, which I will deal with later once I have the capture mode up and running.
MartinL
The 50kHz to 150kHz signal is at a high frequency with resepect to the SAMD21's 48MHz clock. The speed of TC3 really depends on the resolution (frequency steps) of your magnetometer, but will most likely require the TC3 timer to run at its maximum speed of 48MHz.
To set up TC3 to run at 48MHz, just change the generic clock divider from 3, down to 1:
Code: [Select]
REG_GCLK_GENDIV = GCLK_GENDIV_DIV(1) |    // Divide the 48MHz system clock by 1 = 48MHz
...and the TC3 timer prescaler from divide by 16, to also divide by 1:
Code: [Select]
REG_TC3_CTRLA |= TC_CTRLA_PRESCALER_DIV1 |      // Set prescaler to 1, 48MHz/1 = 48MHz
The period values output from the timer will be multiples of 1/48MHz = 20.83ns.
Rucus
Hi MartinL,
Thanks! I think that the code is working all along, but the problem is that the frequency of the signal that I am feeding to the TC3 timer is too fast so by the time that I kick in the attachInterrupt() in the code, my guess is that it is already calling for the ISR that is null (non-existent, but is the compiler supposed to warn me about it?) since I have it called before I have actually set up the TC3 interrupt at NVIC.
I made a little modification of your code and managed to make it work in my setup.
Code: [Select]
void setup()   {
  pinMode(DCDC_EN, OUTPUT);
  REG_GCLK_GENDIV = GCLK_GENDIV_DIV(1) |    // Divide the 48MHz system clock by 3 = 16MHz
  digitalWrite(DCDC_EN, 0);
  delay(3000);
//  attachInterrupt(MAGNETO_IN1, NULL, HIGH);                                        // Attach interrupts to digital pin 12 (external interrupt 3)
  REG_TC3_CTRLA |= TC_CTRLA_PRESCALER_DIV1 |     // Set prescaler to 16, 16MHz/16 = 1MHz
  delay(1000);                        //wait for some delay before turning on power to magnetometers
  timer = millis();
  digitalWrite(DCDC_EN, 1);
  delay(1000);                        //wait for some delay for power to stabilize
  attachInterrupt(MAGNETO_OUT1, NULL, HIGH);                       //enable interrupt
  static uint32_t sampleCntr=0;
  // if millis() or timer wraps around, we'll just reset it
  if (timer > millis())  timer = millis();
  // approximately every 2 seconds or so, print out the current stats
  if (millis() - timer > 1000) {
    timer = millis(); // reset the timer
//    sampleCntr++;
//    Serial.print("t ");
//    Serial.println(sampleCntr, DEC);
      period = isrPeriod;
      Serial.print("P ");
      Serial.println(period, DEC);
      Serial.println(pulsewidth, DEC);
    attachInterrupt(MAGNETO_OUT1, NULL, HIGH);     //re-arm interrupt
  detachInterrupt(MAGNETO_OUT1);
//    Serial.println("MO");
//    Serial.println("M1");
I can see now the P and PW values being generated. I have also changed the TC3 clock settings to the one you suggested above so it now runs at max clock speed. Thank you for that wonderful piece advice!
I am, however, encountering some "weirdness" in my the behavior of my code. When the input frequency from the magnetometer is less than 55kHz, everything works fine (P and PW values get dumped on the terminal). If the frequency is greater than 55kHz, the code is kind of stuck somewhere. As I try to lower down the frequency again, the P and PW gets dumped on the terminal. I tried changing the length of characters to print but seem to not have any effect at all. Could it be something related to millis() function? I am thinking of using another Timer module to interrupt every 1000ms, but I would like to understand first what could have been the cause of the program freezing when input frequency is >55kHz.
Thanks a lot!
-Ruch
AloyseTech
If the frequency is to high, the ISR will be called over and over again without letting time to the rest of the code to be executed. For example : if the code in you ISR take 18┬Ás (1/55k) to execute and you have a 55kHz frequency input, the ISR will be re-called right after it finish executing over and over.
