Topic: Serial/MIDI problem (Read 886 times) previous topic - next topic
frax
I have a fairly big MIDI converter program that doesn't work quite right.
This stripped down code has the same problem:
int ledPin =  13;
int trigger = 3;
void setup()   {
 pinMode(ledPin, OUTPUT);
 pinMode(trigger, OUTPUT);
 digitalWrite(trigger, HIGH);
 // Serial port as MIDI
 Serial.begin(31250);
 while (Serial.available() > 0)
   byte in = Serial.read();
   if (in == 0x90)  // 90 = keydown midi channel 1
     doTrigger();
void doTrigger()
 digitalWrite(ledPin, HIGH);
 digitalWrite(trigger, LOW);
 delay(1);
 digitalWrite(ledPin, LOW);
Wait for a key down and the just flip the pin and the LED for 1ms.
It works IF I hit the keys on my MIDI keyboard fairly slow to normal, speeding it up just a little, not anywhere near fast, it doesn't trigger.
I looked at the MIDI sent in a MIDI-monitor, nothing strange there.
Any suggestions?
/frax
Martin Gerken
BTW: you will not see the LED blink if it's ON for only 1 ms. (sorry, no idea for your primary problem)
frax
I actually see the LED flash, and the trigger is connected to my Synth so I can also hear when it's working.
MikMo
Are you sure you are not sending a lot of other information from the MIDI keyboard?, like polyphonic aftertouch, and all that stuff, so you are flooding your serial connection ?
Just a shot in the dark .-)
frax
#4
Jul 02, 2010, 05:20 pm Last Edit: Jul 02, 2010, 05:21 pm by frax Reason: 1
No aftertouch but my keyboard sends out a 0xfe (Active sense) frequently, i'd say about 4 each second.
I still think there would be plenty of time to receive and process midi messages without loosing any key downs.
frax
Im out of ideas, anyone?
