Loading...
Pages: [1]   Go Down
Author Topic: Hall Effect  (Read 376 times)
Central UK
Offline Offline
Newbie
Hard of Thinking
View Profile
Hi all,
I made a project some time ago that used reed switches to close circuits and light LEDs...very simple mechanical....beginner..etc, etc.
Thought it might be interesting to try to do the same but use the Arduino. I then read something about Hall Effect ensors and thought I could use these in place of Reed Switches to make the whole thing smaller?
....so I went to buy some Hall Effect Switches and found thousands (or so it seemed) of different types.
Any advice of a basic one to replace a reed switch? Just want to detect a magnetic field, don't need polatity or strength etc.
Many thanks!
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
This is a good one:-
http://uk.farnell.com/allegro-microsystems/a3214lua-t/hall-effect-switch-micropower-3sip/dp/1791389?in_merch=New%20Products&MER=i-9b10-00001144
Logged
Boston, MA
Offline Offline
Edison Member
wiblocks
View Profile
WWW
I have used the Honeywell SS345PT. It looks very similar
to the one Grumpy_Mike suggested.
I have an example sketch at
http://wiblocks.luciani.org/docs/app-notes/pico1trc-hall-effect.html
Whenever the magnetic field changes a pin change interrupt
routine is called. When the main program detects a change
the time is read from the real-time clock and is output to the screen.
(* jcl *)
www: http://www.wiblocks.com
twitter: http://twitter.com/wiblocks
blog: http://luciani.org
Logged
Pages: [1]   Go Up
Print
Jump to:
