Topic: Problem with paying multiple audio (Read 493 times) previous topic - next topic
broda
May 06, 2016, 10:43 am Last Edit: May 06, 2016, 10:58 am by Broda
I have about 25 audi files. I only opet one at a time. When the first one opens it's fine it goes smoothly, but when the second opens the sound is not smooth It's like stoping ever half seconds. I don't know how to explain it better.
I'm running it on arduino due, my code is a bit long, becaus it's not only audio, but the audio is at the begining ithe first 100 lines. I'll upload it as a sketch.
Here are the problematic lines:
Code: [Select]
int volume = 1024;
const int M = 1024;
short buffer[M];
const int chipSelect = 52;
File myFile;
int TacniOdgovori = 0;
int NeTacniOdgovori = 0;
int x = 1;
File audioFile;
 File audioFile2;
void show_tft(void)
  tft.begin(identifier);
  tft.setRotation(3);
  tft.setCursor((tft.width() - 36) / 24, (tft.height() * 1) / 4);
  tft.setTextSize(2);
  tft.fillScreen(BLACK);
  tft.setTextColor(CYAN);
  tft.println("Zdravo ja sam Limeni.");
  tft.println("");
  tft.println("Ako zelite da zapocnete kviz pritisnite '#'");
  tft.println("");
  tft.println("Ako zelite da zpocnet anketu pritisnite '*'");
  Serial.print("Initializing SD card...");
  pinMode(SS, OUTPUT);
  if (!SD.begin(chipSelect)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
 char y = ' ';
  Audio.begin(88200, 100);
  show_tft();
  File audioFile = SD.open("zdravo.wav");
      while (audioFile.available()) {
        Serial.print("Radi");
         audioFile.read(buffer, sizeof(buffer));
          Audio.prepare(buffer, M, volume);
     Audio.write(buffer, M);
        audioFile.close();
        buffer[M];
        volume = 1024;
        delay(100);
  char y = ' ';
  while (y == ' ') {
        char customKey = customKeypad.getKey();
        if (customKey) {
          y = customKey;
          if (y == '#'){}
          if (y == '*'){
            goto bailoutB1;
  bailoutQ:
   TacniOdgovori = 0;
  x = 1;
  for (int x = 1; x < 17; x = x + 1) {
    tft.setTextSize(2);
    if (x == 1) {
      bailout1:
    char y = ' ';
      File myFile = SD.open("P01TXT~2.TXT");
      if (myFile) {
        while (myFile.available()) {
          tft.write(myFile.read());
      File audioFile = SD.open("jedan.wav");
      audioFile.close();
      while (y == ' ') {
        if (customKey) {
          y = customKey;
        if ( (y != 'A') && (y != 'B') && (y != 'C') && (y != 'D')){
          tft.println("Pritisnuli ste pogresan taster!");
          tft.println("");
          tft.println(" Za unos odgovora koristite  'A' , 'B', 'C' ili 'D'");
      File audioFile = SD.open("pogresan.wav");
AWOL
Code: [Select]
Don't you just hate it when that happens?
Please, reformat your code using the auto-format tool in the IDE and reattach it.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
broda
Code: [Select]
Actualy It's somehow easier for when it's like that. :)
Here I'll attach the formated.
broda
