Topic: XPort Direct+ using connection by hostname (Read 5636 times) previous topic - next topic
strus_fr
Apr 06, 2010, 05:04 pm Last Edit: Apr 06, 2010, 05:05 pm by strus_fr Reason: 1
I am wondering if the XPort Direct+ can talk to a web server using its name instead of its IP address?
Cwww.google.com/80 instead of Cxxx.yyy.zzz.aaa/80
Did someone tried that?
I am wondering that because nowadays, where every web site is a virtual host, it is often impossible to connect to them using IP directly.
Thanks
macegr
It's still possible to connect to an IP address. That's why you also have the "Host:" line in the request. The correct vhost will be selected based on that parameter.
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
strus_fr
#2
Apr 07, 2010, 03:26 am Last Edit: Apr 07, 2010, 03:35 am by strus_fr Reason: 1
ok, but before sending the Host: I need to connect to it and it is where the connection fails 99% of the time.
macegr
Are you going to post some code? Just as a guess, if you try to connect while already connected, things won't work as you hope.
wayoda
AFAIK the XPort direct+ does not support DNS, so this is not possible.
The XPort AR seems to be the only one from the product line that supports this, but its expensive too!
But at least here in germany (virtual) server prices with a dedicated IP address have dropped down to 10? a month.
Eberhard
strus_fr
#5
Apr 07, 2010, 10:30 pm Last Edit: Apr 08, 2010, 01:40 am by strus_fr Reason: 1
I will dump my code here tonight, but I think your advice worked.
I used 'Host: xxxxx.com' and the request go through.
But it goes through only when it wants ... the connect() fails for time to time and the issue may be linked to what you suggested. I need to do more testing, and I will give you the results later.
Update: so putting a myserial.disconnected() around the connect() statement helps a lot indeed !! Now I have a connection every time.
I still have some failure on the reset sometimes ... may be I need a flush somewhere.
But now my concern is that when I post a POST request I get as an answer:
*** NodeSet 2.0 ***
And not my "HTTP/1.1 200 OK" answer .... which means I entered into the Monitor Mode at some point ... not sure how !!
If I do the same POST using curl it works fine.
Here is some code pde and php (that may help others). Any help is welcome:
#include <NewSoftSerial.h>
#include <AF_XPort.h>
#include <avr/io.h>
#include <string.h>
#define HTTPPATH "/test.php"
#define WEB_HOST "secretweb.free.fr"
#define IPADDR "2x2.yx.63.zzz"
#define PORT 80
char linebuffer[256];
#define XPORT_RXPIN 2
#define XPORT_TXPIN 3
#define XPORT_RESETPIN 4
#define XPORT_DTRPIN 0
#define XPORT_CTSPIN 6
#define XPORT_RTSPIN 0
//*** Channel 1
//Baudrate 9600, I/F Mode 4C, Flow 00
//Port 10001
//Connect Mode : D4
//Send '+++' in Modem Mode enabled
//Show IP addr after 'RING' enabled
//Auto increment source port disabled
//Remote IP Adr: --- none ---, Port 00000
//Disconn Mode : 00
//Flush   Mode : 77
AF_XPort xPortSerial = AF_XPort(XPORT_RXPIN, XPORT_TXPIN, XPORT_RESETPIN, XPORT_DTRPIN, XPORT_RTSPIN, XPORT_CTSPIN);
uint8_t errno;
 Serial.println("Ready?");
 // set the data rate for the NewSoftSerial port
 xPortSerial.begin(9600);
 int ver = NewSoftSerial::library_version();
 Serial.println(ver);
void loop()                     // run over and over again
 Serial.println("Saving...");
 save_data();
 Serial.println("Done");
 delay(10000);
void save_data() {
 int i=0;
 char json[328];
 sprintf(json,"{\"log\":{\"AC_relays\":[{\"id\":0,\"value\":%d},{\"id\":1,\"value\":%d},{\"id\":2,\"value\":%d},{\"id\":3,\"value\":%d}],\"DC_relays\":[{\"id\":0,\"value\":%d},{\"id\":1,\"value\":%d},{\"id\":2,\"value\":%d},{\"id\":3,\"value\":%d}],\"ds18b20\":[{\"id\":0,\"value\":%2d},{\"id\":1,\"value\":%2d},{\"id\":2,\"value\":%2d}],\"water_level\":[{\"id\":0,\"value\":%4d},{\"id\":1,\"value\":%4d}]}}",0,1,0,1,1,2,1,0,25,22,27,1003,2000);
 httpPost(json);
 //httpGet();
int httpPost(char* json)
 uint8_t ret;
 char *found=0;
 ret = xPortSerial.reset();
 switch (ret) {
  case  ERROR_TIMEDOUT: {
     Serial.println("Timed out on reset!");
     return 0;
  case ERROR_BADRESP:  {
     Serial.println("Bad respons on reset!");
     return 0;
  case ERROR_NONE: {
   Serial.println("Reset OK!");
   break;
  default:
    Serial.println("Unknown error");
    return 0;
 // time to connect...
 if (xPortSerial.disconnected()) {
 ret = xPortSerial.connect(IPADDR, PORT);
 switch (ret) {
     Serial.println("Timed out on connect");
     return 0;
     Serial.println("Failed to connect");
     return 0;
  case ERROR_NONE: {
    Serial.println("Connected..."); break;
  default:
    return 0;
  Serial.println("Already connected");
 //xPortSerial.flush(250);
 //xPortSerial.print("GET "); xPortSerial.print("/"); xPortSerial.println(" HTTP/1.1");
 //base64encode(USERNAMEPASS, linebuffer);
 xPortSerial.print("POST "); xPortSerial.print(HTTPPATH); xPortSerial.println(" HTTP/1.1");
 Serial.print("POST "); Serial.print(HTTPPATH); Serial.println(" HTTP/1.1");
 // next, the authentication
 xPortSerial.print("Host: "); xPortSerial.println(WEB_HOST);
 Serial.print("Host: "); Serial.println(WEB_HOST);
 //xPortSerial.print("Authorization: Basic ");
 //Serial.print("Authorization: Basic ");
 //xPortSerial.println(linebuffer);
 //Serial.println(linebuffer);
 //xPortSerial.println("User-Agent: arduino");
 //Serial.println("User-Agent: arduino");
 xPortSerial.print("Content-Length: "); xPortSerial.println(1+strlen(json), DEC);
 Serial.print("Content-Length: "); Serial.println(1+strlen(json), DEC);
 xPortSerial.print("Content-Type: application/x-www-form-urlencoded\n");
 //xPortSerial.print("\nsubmit=");
 xPortSerial.println(json);
 //Serial.print("\nsubmit=");
 xPortSerial.println("");
Serial.println("");
// while (1) {
   // read one line from the xport at a time
   ret = xPortSerial.readline_timeout(linebuffer, 255, 3000); // 6s timeout
   if (strstr(linebuffer, "HTTP/1.1 200 OK") == linebuffer) {
     Serial.println("Done Success...");
     ret = 1;
   } else if (strstr(linebuffer, "HTTP/1.1 400 Bad Request") == linebuffer) {
     Serial.println("Done Bad Request..");
     ret = 0;
   if (((errno == ERROR_TIMEDOUT) && xPortSerial.disconnected()) ||
       ((XPORT_DTRPIN == 0) &&
        (linebuffer[0] == 'D') && (linebuffer[1] == 0)))  {
      Serial.println("Disconnected...");
      return ret;
Here is the test.php file:
<?php
if (!function_exists('json_decode')) &#123;
function json_decode($json) &#123;
   $comment false;
   $out '$x=';
   for ($i=0$i<strlen($json); $i++)
   &#123;
 if (!$comment
 &#123;
if ($json[$i] == '&#123;'$out .= ' array('
                        else if (
$json[$i] == '&#125;'$out .= ')'
                        else if (
$json[$i] == ':'$out .= '=>';
   else if ($json[$i] == '['$out .= ' array(';                         else if ($json[$i] == ']'$out .= ')'
$out .= $json[$i];
 &#125;
 else $out .= $json[$i];
 if ($json[$i] == '"'$comment = !$comment
   &#125;
   eval($out ';');
   return $x;
#125;
&#125;
$handle fopen('php://input','r');
$jsonInput fgets($handle);
$decoded json_decode($jsonInput);
var_dump($decoded);
fclose($handle);
Here is the result I get:
Ready?
9
Saving...
Reset OK!
Connected
POST /test.php HTTP/1.1
Host: mysecretweb.com
Content-Length: 22
Content-Application: application/x-www-form-urlencoded
<json string>
*** NodeSet 2.0 ***
Done
Any idea how can I get an html header as expected.
strus_fr
#6
Apr 10, 2010, 11:53 pm Last Edit: Apr 10, 2010, 11:54 pm by strus_fr Reason: 1
Ok, after more experiences, I finally succeed in having all working.
So, here is a piece of code for anybody who wants to send some data to a mysql database on a web server using PHP and the ethernet shield with XPort Direct+: (methods names do not match: I was supposed to use POST and JSON, I finally I am using GET and a string...):
PDE code:
#include <avr/io.h>
#include <string.h>
#define HTTPPATH "/xPortPost.php?submit="
#define WEB_HOST "mywebsite.com"
#define IPADDR "9.38.zz.1xx"
#define PORT 80
//*** Channel 1
//Port 10001
//Connect Mode : D4
//Disconn Mode : 00
//Flush   Mode : 77
uint8_t errno;
 save_data();
 delay(10000);
void save_data() {
 int i=0;
 char json[328];
 sprintf(json,"ac0:%d,ac1:%d,ac2:%d,ac3:%d,dc0:%d,dc1:%d,dc2:%d,dc3:%d,temp0:%2d,temp1:%2d,temp2:%2d,ato0:%4d,ato1:%4d,alarm:%d",0,1,0,1,1,2,1,0,25,22,27,1003,2000,3);
 httpPost(json);
 uint8_t ret;
 char *found=0;
 switch (ret) {
     return 0;
     return 0;
  case ERROR_NONE: {
   break;
  default:
    return 0;
 switch (ret) {
     return 0;
     return 0;
  case ERROR_NONE: {
  default:
    return 0;
 xPortSerial.print("GET "); xPortSerial.print(HTTPPATH);   xPortSerial.print(json); xPortSerial.println(" HTTP/1.1");
 Serial.print("GET "); Serial.print(HTTPPATH); Serial.print(json); Serial.println(" HTTP/1.1");
 Serial.println("");
 while (1) {
     ret = 1;
     ret = 0;
      return ret;
le code php de xPortPost.php
<?php
      $DBhost
"myhost";
$DBuser "myself";
$DBpass "secretpasswd";
$DBName "mysuperdb";
$table "my_data";
      if (isset(
$_GET['submit'])) &#123;
$con mysql_connect($DBhost,$DBuser,$DBpass) or die("Unable to connect to database");
mysql_select_db("$DBName") or die("Unable to select database $DBName");
$decoded $_GET['submit'];
$tmp split(","$decoded);
            for(
$i 0$i sizeof($tmp); $i=$i+1) &#123;
$bou split (":"$tmp[$i]);
$name $bou[0];
$value $bou[1];
$sqlquery "INSERT INTO $table (name, value) VALUES('$name','$value')";
                  if (!
mysql_query($sqlquery,$con))
 &#123;
die('Error: ' mysql_error());
#125;
&#125;
mysql_close();
#125;
TylerW
I have been spending a lot of time with this Strus' above program however, is seems that unless the server times out I fail to get a connection, maybe the server won't allow multiple connections from the same IP?
I am wondering of there is a "disconnect" command for the Xport and how it would work
Tyler
macegr
Disconnect settings are controlled in the XPort configuration. You can set a local timeout, disconnect on a character, etc.
alekline
You can use hostname and IP address. xPort can Support DNS. Just update it to the lasted firmware version from Grid Connect.
