Loading...
Pages: 1 [2]   Go Down
Author Topic: Re-implementing serial monitor (serial read) C++  (Read 1117 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
C++, I'm using a PC with window 7 OS, and netbean or QT creator with the minGW compiler set.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
I PM'ed you.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
So am I right in thinking there is no simple way to only call a read byte function when a byte is present in the buffer to be read?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
I looked at the SerialPort documentation for C#, and I don't see a method of determining whether there is data to read, or not.
On the other hand, the derivation path for SerialPort makes it just another stream reader, and stream readers know to stop when the stream is empty. There might be an eof() function somewhere in it's derivation path that you could use to see if you are at the end of the stream.
If you use a thread to read the port, it doesn't matter that the thread blocks waiting for data.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
