I am currently working on a halloween/christmas lighting system. i would like to use Vixen to control it all. I would like to use a Arduino mega as a controller. with the abillity to control servos, rgb leds, and relays. i am new to programing and need help. i know i can lose a basic stamp to control relays but i want servos as well. the code for the basic stamp is
' File...... Vixen_Input_v2.BS2
' Purpose...
' Author.... Jon Williams, EFX-TEK
' (remove my name if you modify and repost)
' E-mail....
' Started... 22 DEC 2009
' Updated... 22 DEC 2009
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[ Program Description ]---------------------------------------------
' Receives channel control data from Vixen using the Generic serial driver.
' The driver should be set as follows:
' Baud..... 2400
' Header... (checked) EFX
' Footer... (not checked)
' Ensure that the Vixen project has 16 channels defined, even if some are
' not used as this program expects to receive 16 bytes after the "EFX"
' header. If a channel value is 0-127 the output will be off, if it is
' 128-255 the output will be on.
' Vixen event timing should be set to 125ms or higher.
' -----[ Revision History ]------------------------------------------------
' -----[ I/O Definitions ]-------------------------------------------------
RX CON 16 ' for programming port
Servo CON 16
' -----[ Constants ]-------------------------------------------------------
IsOn CON 1 ' for active-high in/out
IsOff CON 0
Yes CON 1
No CON 0
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T1200 CON 813
T2400 CON 396
T4800 CON 188
T9600 CON 84
T19K2 CON 32
T38K4 CON 6
#CASE BS2SX, BS2P
T1200 CON 2063
T2400 CON 1021
T4800 CON 500
T9600 CON 240
T19K2 CON 110
T38K4 CON 45
#CASE BS2PX
T1200 CON 3313
T2400 CON 1646
T4800 CON 813
T9600 CON 396
T19K2 CON 188
T38K4 CON 84
#ENDSELECT
SevenBit CON $2000
Inverted CON $4000
Open CON $8000
Baud CON T2400 ' do not speed up!
' -----[ Variables ]-------------------------------------------------------
buf0 VAR Byte ' channels buffer
buf1 VAR Byte
buf2 VAR Byte
buf3 VAR Byte
buf4 VAR Byte
buf5 VAR Byte
buf6 VAR Byte
buf7 VAR Byte
buf8 VAR Byte
buf9 VAR Byte
buf10 VAR Byte
buf11 VAR Byte
buf12 VAR Byte
buf13 VAR Byte
buf14 VAR Byte
buf15 VAR Byte
' -----[ Initialization ]--------------------------------------------------
Reset:
OUTH = %00000000 : OUTL = %00000000 ' clear all
DIRH = %11111111 : DIRL = %11111111 ' set outputs
' -----[ Program Code ]----------------------------------------------------
Main:
SERIN RX, Baud, [WAIT("EFX"), STR buf0\16] ' wait for stream
OUT0 = buf0.BIT7
OUT1 = buf1.BIT7
OUT2 = buf2.BIT7
OUT3 = buf3.BIT7
OUT4 = buf4.BIT7
OUT5 = buf5.BIT7
OUT6 = buf6.BIT7
OUT7 = buf7.BIT7
OUT8 = buf8.BIT7
OUT9 = buf9.BIT7
OUT10 = buf10.BIT7
OUT11 = buf11.BIT7
OUT12 = buf12.BIT7
OUT13 = buf13.BIT7
OUT14 = buf14.BIT7
PULSOUT Servo, buf15.BIT7 ' move the servo
PAUSE 20 ' servo refresh delay
GOTO Main
I appreciate any help that can be given.
http://www.vixenlights.com/
