Topic: Strangeness with Serial and pololu (Read 1 time) previous topic - next topic
whatevernot
Hi -
I'm using a pololu servo controller via Serial - I have pin #1 (tx) on the arduino connected to "logic-level serial input" pin #3 on the pololu. Power and gnd is wired okay, I'm using 3 servos - it all works.
Sort of.
If I power up the arduino, and connect a terminal (can see the text equivalent of the commands sent to the pololu) everything works great. I can then quit the terminal app, unplug the usb cable, and the servos continue to work fine.
But if I don't hook up the terminal app, it doesn't work. In other words, if I just power up the board with no usb or terminal app, the servos don't move - there is something that the polulo doesn't like (?). As soon as a terminal app is connected, the servos start turning (and the app can be killed and usb unplugged).
I can't figure out what the heck is going on.
Can anyone shed any light? Seems that the act of connecting the terminal somehow "makes it work".
Cheers, and thanks.
b...
zoomkat
How are you powering your setup when it is not connected to the USB port?
whatevernot
Hello- I have 5v power supply- it doesn't seem to be power related, as it works with just the 5v supply.
The weird part is that the terminal program needs to be connected to serial, if only briefly- it can be disconnected and the servos continue to work.
b...
zoomkat
May be code that expects some type of terminal interaction.
PaulS
Sounds more like the Arduino is not properly initializing serial communication with the controller. Post a link to the controller (and data sheet) and your code.
whatevernot
The user's guide for the pololu is here:
http://www.pololu.com/file/0J37/ssc03a_guide.pdf
My code is straightforward - here's my setup function:
And the commands to control the servo take place here:
void servoSet(int servo, int angle)
     unsigned char buff[6];
     unsigned int temp;
     unsigned char pos_hi,pos_low;
     temp = angle & 0x1f80;
     pos_hi = temp >> 7;
     pos_low = angle & 0x7f;
     buff[0] = 0x80; //start byte
     buff[1] = 0x01; //device id
     buff[2] = 0x04; //command number
     buff[3] = servo; //servo number
     buff[4] = pos_hi; //data1
     buff[5] = pos_low; //data2
     for(int i = 0; i < 6; i++) Serial.print(buff, BYTE);
And so a call to servoSet sets the position of the servo.
As stated, all works fine as long as a terminal connection has been connected briefly.
There is a possibly similar thread here, but it doesn't address my issue:
http://forum.pololu.com/viewtopic.php?t=745
whatevernot
ARG. Arg arg arg - I apologize - I am an idiot - I went down a rabbit hole - still have the issue, but it's not related to the pololu - this is a red herring.
The way I am sending messages to the arduino is via the ethernet shield - have a little http server. If I connect the terminal app, then everything works, if I don't connect the terminal app via serial, then nothing.
So, something to do with how Serial and Ethernet are behaving - I am still stumped, but know a bit more.
Hmmmm... Frustrating....
Thanks.
whatevernot
Closing this thread out, and starting a new one, as the problem still persists, in that I need a serial connection before the server works.
