Topic: arduino target for simulink (Read 3907 times) previous topic - next topic
Lucky13_
Hello, im trying to communicate with simulink using arduino target (http://www.mathworks.com/academia/arduino-software/arduino-simulink.html  ). Im following the instructions that comes with the file and i have done all the steps successfully until the "demo_arduino_blink". When im trying to run the demo_arduino_blink it shows me this error   Error in S-function 'demo_arduino_blink/Digital Output': S-Function 'sfunar_digitalOutput' does not exist. Does anybody have experience with this? Im running windows7 x64 and the matlab 2010a and i have allready installed the 64 bit visual studio components.
Coding Badly
Have you verified that the Arduino is working correctly?
For example, downloaded a simple Blink Sketch using the Arduino IDE?
Lucky13_
thanx for your reply, yes the arduino is working correctly. Also when i run this "demo_arduino_pil" for test the arduino responding normally and give me back results to matlab.
david.maclay
The download only has win32 modules prebuilt.
You can  create the win64 module with the mex command. From the MATLAB command window change directory to the blocks folder that contains the block source files then type
mex sfunar_digitalOutput.c
Lucky13_
#4
Sep 25, 2010, 02:56 pm Last Edit: Sep 25, 2010, 02:59 pm by lucky13 Reason: 1
thank you very much david!!that was the problem. now its working fine! =D
Maxi1984
Hello Im trying to add (Arduino Uno) target in Simulink:
   >> arduino.Prefs.setArduinoPath('c:\Program Files\arduino\arduino-0021')
I setup everything but the problem is when Im trying to build demo_arduino_blink this error appear
The call to arduino_make_rtw_hook, during the after_make hook generated the following error:
Download failed. Check your serial connection and and run the command arduino.Prefs.getMcu to check you have specified the correct MCU.
The build process will terminate as a result.
when Im checking Mcu:
ans =
atmega328p
when Im checking the COM this is a result:
arduino.Prefs.setComPort('COM3');
>> arduino.Prefs.searchForComPort
ans =
Im using MacBook Pro Windows7 64bits
If anyone knows whats a problem please help me I have to finish this project for my graduation
THANX
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
