Topic: Communication between two NodeMcu WIFI modules (Read 12102 times) previous topic - next topic
mrhyde17
Hello everybody,
I have got my two NodeMcu modules and I would like to send data between them.
First module I set as AP and second as a client. Looks like that connects well but I have problem what to do next. Simply I want to send a short string sth like "hello" from one module and read it on second one.
Can anyone help how to do this?
AP code:
Code: [Select]
#include <ESP8266WiFi.h>
const char *ssid = "TEST";
const char *password = "grubychuj";
  Serial.println("siema");
  WiFi.softAP(ssid, password);
  pinMode(2, OUTPUT);
  digitalWrite(2, LOW);
  digitalWrite(2, HIGH);
  Serial.println("eloszka");
Client code:
Code: [Select]
  pinMode(2, OUTPUT);
  delay(10);
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
PaulS
Quote
WiFi handles very structured communications without wires. "Sending something like hello" is NOT something that can happen. An access point is something that allows two other devices to communicate, through the access point.
mrhyde17
Thank you for answer.
I have seen example in lua where somebody makes two esp8266 to talk with each other.
Is that "hello" able to do when I also creat a server on one of them?
PaulS
Quote
If one of them is a server, the other one (the client) can make a GET request. The GET request could include the word "hello".
Hackscribble
Hi mrhyde17
You could try using UDP to send packets of data between the nodeMCUs.
There is an example program called WifiUdpSendReceiveString under File - Examples - Wifi in the Arduino IDE.
I use UDP to link two nodeMCUs running in client mode connected to a separate access point.  I don't know for sure if it will work on the nodeMCU that you have set as an access point.
Regards
Ray
Hackscribble.  Writing about making things.
arduino@hackscribble.com | www.hackscribble.com
mrhyde17
Hi Hackscribble,
Thanks for information. I have old router in my box so maybe thats really a point to do this.
Could you share with me your codes which you put into yours nodemcu's?
Best Regards
Hyde
Hackscribble
#6
May 19, 2016, 01:34 pm Last Edit: May 19, 2016, 01:43 pm by Hackscribble
The UDP code is part of much larger programs, so here are some extracts that may help.  The code checks for received UDP packets on a defined port.  If a received packet contains a defined string, the code takes some action.
First. I define configuration on the sender:
Code: [Select]
const uint16_t UDP_LOCAL_PORT =  8050;
const uint16_t UDP_REMOTE_PORT = 8051;
const char UDP_REMOTE_HOST[] =   "receiver";
char TRIGGER_STRING[] = "somestring";
I have the host name of the receiving nodeMCU ("receiver") configured on my home router.  If you need to use an IP address, then you will need to change "receiver" to the IP address.
Configuration on the receiver:
Code: [Select]
const uint16_t UDP_LOCAL_PORT =  8051; // Must match UDP_REMOTE_PORT on sender
char TRIGGER_STRING[] = "somestring";  // Must match TRIGGER_STRING on sender
On both devices, I declare a global instance of the UDP class:
Code: [Select]
#include <WiFiUdp.h>
WiFiUDP UDP;
UDP is started by this code in setup() on both devices:
Code: [Select]
Serial.println("PROGRAM: starting UDP");
if (UDP.begin(UDP_LOCAL_PORT) == 1)
  Serial.println("PROGRAM: UDP started");
  Serial.println("PROGRAM: UDP not started");
On the sender, I use this code to send the trigger string to the receiver:
Code: [Select]
Serial.println("PROGRAM: sending trigger");
UDP.beginPacket(UDP_REMOTE_HOST, UDP_REMOTE_PORT);
UDP.write(TRIGGER_STRING);
UDP.endPacket();
On the receiver, this code checks received UDP packets to see if they contain the trigger string:
Code: [Select]
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; // buffer to hold incoming packet,
int packetSize = UDP.parsePacket();
if (packetSize > 0)
  Serial.print("PROGRAM: received UDP packet of size ");
  Serial.println(packetSize);
  Serial.print("PROGRAM: from ");
  IPAddress remote = UDP.remoteIP();
  for (int i = 0; i < 4; i++)
    Serial.print(remote[i], DEC);
    if (i < 3)
      Serial.print(".");
  Serial.print(", port ");
  Serial.println(UDP.remotePort());
  UDP.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
  Serial.print("PROGRAM: contents: ");
  Serial.println(packetBuffer);
  if (strncmp(packetBuffer, TRIGGER_STRING, strlen(TRIGGER_STRING)) == 0)
    Serial.println("PROGRAM: trigger received");
    // DO YOUR STUFF HERE
  delay(10);
mrhyde17
#7
May 19, 2016, 05:16 pm Last Edit: May 19, 2016, 05:27 pm by mrhyde17
Thanj you so much for sharing your code.
I made a test to check if it sends that text to antoher one but unfortunately something is wrong.
If you find a while please take a look at that codes and scan form serial monitor:
sender code:
Code: [Select]
WiFiUDP UDP;
const char *ssid = "mrhyde17";
const char *password = "abc89";
  pinMode(2, OUTPUT);
  delay(10);
    Serial.print(".");
  Serial.println("");
pinMode(2, LOW);
UDP.endPacket();
pinMode(2, HIGH);
receiver code:
Code: [Select]
WiFiUDP UDP;
  delay(10);
    Serial.print(".");
  Serial.println("");
if (packetSize > 0)
    if (i < 3)
      Serial.print(".");
  delay(10);
monitor:
Code: [Select]
Connecting to mrhyde17
WiFi connected
IP address:
192.168.43.35
Hackscribble
On the sender, you need to configure the host name or IP address for the receiver.  This still has the host name I use; you probably need to change it to the IP address of your receiver.
Code: [Select]
Is the serial monitor output you posted from the sender or the receiver?
mrhyde17
I have corrected the ip and looks like that esp's started to talk but i also get a gabage.
receiver monitor:
Code: [Select]
PROGRAM: received UDP packet of size 10
PROGRAM: from 192.168.43.151, port 8050
PROGRAM: contents: somestringöRk'ô�¸
Do you know how to get rid them?
Hackscribble
I think the UDP library sends the string without a terminating null character.  When you use Serial.print(), this expects a null to mark the end of the string, so it carries on past the received data and prints out whatever is in memory until it happens to hit a null.
Try adding this before you print:
Code: [Select]
packetBuffer[packetSize] = '\0';
That is a zero character after the \.
abetoo
I've been working in a library to give a solution for this situation. Please have a look to this link.
http://abetoo.com/wiki/knowledge-base/arduino_send_messages
The schema is very simple, you only need a channel id for any single device connected, and then you only have to send a message to the device you want to communicate with, just using the channel id as identifier.
Ayeshakhan123
Am a doing a college project Rfid tracker using Nodemcu v3. i am using 2 rfid readers and 2 nodemcu. I want the datas of the 2 rfid to be a posted on a single web server. each nodemcu creates an ip address where my data transfered on the server. each data is on a new ip address. i want the data of the 2 nodemcu to be posted on one server. is that possible . here is my code
1st rfid with nodemcu code
#include <MFRC522.h> //RFID Library
#include <SPI.h> // Serial Protocol Interface
#include <ESP8266WebServer.h> // Sets up a server
#define SS_PIN 15 // Slave Select pin (D8)
#define RST_PIN 5 // Reset Pin (D1)
MFRC522 mfrc522(SS_PIN, RST_PIN);
ESP8266WebServer server;
char* ssid = "Oppo a57"; // Mobile Hotspot name
char* password = "12345678@"; // Connect to the Wifi network
  Serial.begin(9600); // Initiate a serial communication
  SPI.begin();      // Initiate  SPI bus
  mfrc522.PCD_Init();   // Initiate MFRC522
  Serial.println("Approximate your card to the reader..."); // Prints on new line
  WiFi.begin(ssid,password);
  while(WiFi.status()!=WL_CONNECTED) // Wait for connection
    Serial.print(".");
    delay(100);
  Serial.println("");
  Serial.print("IP Address: ");
  Serial.println(WiFi.localIP()); //Print the local IP Address
 server.begin(); // Start the server
 { server.handleClient(); //Handle incoming https requests
  if ( ! mfrc522.PICC_IsNewCardPresent())
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())
    return;
  Serial.print("UID tag :");
  String content= "";
  byte letter;
  for (byte i = 0; i < mfrc522.uid.size; i++)                        // mfrc522.uid.size --> PRINTS UID SIZE
     Serial.print(mfrc522.uid.uidByte < 0x10 ? " 0" : " ");       // mfrc522.uid.uidByte --> PRINTS BYTES OF UID
     Serial.print(mfrc522.uid.uidByte, HEX);
     content.concat(String(mfrc522.uid.uidByte < 0x10 ? " 0" : " "));
     content.concat(String(mfrc522.uid.uidByte, HEX));
  //Serial.print("Message : ");
  content.toUpperCase();
if (content.substring(1) == "E0 5D 12 A4" ) // Compares the string
   Serial.println("Dr.Ayesha entered in Room 1");
   server.on("/",[](){server.send(200,"text/plain","Dr.Ayesha entered in Room 1");}); // Posted on the web server
/*else if ( content.substring(1) == "3E 0E AB 59" )
    Serial.println("Dr.Santosh entered in Room 1" );
    server.on("/",[](){server.send(200,"text/plain","Dr.Zenul entered in Room 1");});
else if ( content.substring(1) == "50 DD 20 A4" )
    Serial.println("Dr.Zenul entered in Room 1" );
 server.on("/",[](){server.send(200,"text/plain"," Dr.Zenul entered in Room 1");});
    Serial.println("Invalid");
 delay(3000);
2nd rfid with nodemcu code
    Serial.print(".");
    delay(100);
  Serial.println("");
    return;
    return;
  String content= "";
  byte letter;
   Serial.println("Dr.Ayesha entered in Room 2");
   server.on("/",[](){server.send(200,"text/plain"," Dr.Ayesha entered in Room 2");}); // Posted on the web server
    Serial.println("Operation Theatre" );
    server.on("/",[](){server.send(200,"text/plain","Operation Theatre");});
    Serial.println("Invalid ");
 delay(3000);
Please help me out by getting both the datas on a server
