Topic: Serial Printing to Processing (Read 4521 times) previous topic - next topic
afhaque89
Nov 13, 2010, 04:22 am Last Edit: Nov 13, 2010, 05:15 am by afhaque89 Reason: 1
Hi guys,
I'm running into a snag as I'm trying to use serial.read() from processing to take in values from my Arduino prototype.
Basically, I have Arduino code that reads in pressure values, subtracts  an offset value (stored in EEPROM), and converts the resulting value into desired units.
I was then hoping to send those values to Pachube through Processing. Trouble is the values shown in the Processing Serial do not match the desired values I see in the Arduino Serial. From the looks of it, the values printed do not account for that initial offset stored in EEPROM.
This is similar to my Arduino code:
(Source: http://spiffie.org/electronics/archives/microcontrollers/Arduino%20and%20Freescale%20MPX%20Pressure%20sensors.html)
Code: [Select]
#include <EEPROM.h>
#include <LiquidCrystal.h>
int offset = 0;
int number = 0; //number of iterations
int x;  // fresh value from sensor
float cmOfWater; //after multiplication
 offset = EEPROM.read(0);
 offset<<=8;
 offset|=EEPROM.read(1);
 analogReference(DEFAULT);
 //wait until stabilization
 //read the sensor
 x = analogRead(0);
 //convert to pascals
 cmOfWater = ((x-offset)*.17335);
 //output the pressure and the iteration number on serial monitor
 Serial.print(cmOfWater,3);
 //update the iteration and pause a bit.
 number++; //to the next character
 //Refresh rate of 500ms
This is the Processing Code:
Code: [Select]
import processing.serial.*;
Serial arduinoPort;  // Serial port you are using
float arduinoPressure;
 arduinoPort = new Serial(this, Serial.list()[1], 9600);
 arduinoPort.clear();
void draw() {
 arduinoPressure = arduinoPort.read();
 println(arduinoPressure);
Any thoughts on why the two Serial outputs are different?
Coding Badly
Quote
No but it would certainly be helpful if you post code that actually compiles.
afhaque89
Quote
Sorry. I originally just posted to get the concept across. But I fixed the code.
Coding Badly
Collect the output from the Sketch using Serial Monitor.  Are you able to tell where one value ends and another begins?
afhaque89
Quote
Yeah. There's a time delay. Plus I've got an LCD attached to my unit displaying the correct Arduino based value.  The LCD is also the reason I'm not just switching to Firmata and manipulating the inputs in Processing. I'd have no idea how to get Firmata to work with the LCD at this newb stage.
Coding Badly
#5
Nov 13, 2010, 07:42 am Last Edit: Nov 13, 2010, 07:42 am by bcook Reason: 1
Quote
I take it from your response that you have no intention of putting any thought into this matter.
You have two problems in your code...
1. You're sending text characters but trying to read a binary value.  Pick which one you want to use.  I suggest text.
2. You provide no reliable method of differentiating between two values.  I suggest a square brackets around the value.
afhaque89
#6
Nov 13, 2010, 08:36 am Last Edit: Nov 13, 2010, 08:37 am by afhaque89 Reason: 1
Quote
Okay I get what you're saying here (and thanks a lot for helping).  So if instead of sending in float values like 0.0001.2213.222 ....
I instead send [0.001] [1.2213] as strings?
Then from processing break up the string and convert the number back to float?
Coding Badly
Quote
Exactly.  Without the separators you will be pulling your hair out trying to get the transfer reliable.
Quote
Yes.  Skip incoming characters until an "opening" character arrives.  Collect characters until a "closing" character arrives.  Convert the text to a float.
I believe this has been discussed several times in the forum.  You may want to spend some time searching before coding.
PaulS
Quote
Why? So you can then convert the floats to strings to send to pachube?
Quote
Similar to? Why didn't you post YOUR code?
afhaque89
#9
Nov 14, 2010, 09:45 pm Last Edit: Nov 14, 2010, 09:45 pm by afhaque89 Reason: 1
Quote
I thought I needed to send floats? I'll have to take another look. Thanks for the help.
Quote
I just meant that I abridged my full program to take out all of the irrelevant stuff.
PaulS
Quote
I could be wrong. I was thinking more along the lines of twitter. But, I think all the data sent to pachube is sent using a POST request, which is a string. Hence the need to represent the float as a string to post to pachube.
Quote
Oh. OK, then, as long as the posted code ACTUALLY illustrates the problem. Too many people come in here and post code that dances all around the problem, figuring they know where the problem is because the snippet they post is where they see the problem, whereas the problem code is way over there, but the manifestation is here.
afhaque89
Okay! So solution reached.
Here's the working code. Hope it helps someone else.
Arduino:
Code: [Select]
#include <EEPROM.h>
int offset = 0;
 offset<<=8;
 //read the sensor
 x = analogRead(0);
[glow]   Serial.print("[");
  Serial.print("]");[/glow]
Processing:
Code: [Select]
[glow]String processingPressure;[/glow]
void draw() {
 //println(Serial.list());
[glow]  if(arduinoPressure == 91) //Checks for '[' character {
 processingPressure=arduinoPort.readStringUntil(93); //Checks for ']' character
   if(processingPressure !=null)
   { [/glow]
    [glow] processingPressure=processingPressure.substring(0,processingPressure.length()-1); //removes ']' character
     println(processingPressure);[/glow]
With this I get outputted values from Arduino as:
[0.000][0.173][-2.312][1.231]
And outputted values from Processing as:
0.000
0.173
-2.312
1.231
Which can be uploaded to Pachube.
PaulS
Code: [Select]
would be much more maintainable as
Code: [Select]
if(arduinoPressure == ']') {
 processingPressure=arduinoPort.readStringUntil('[');
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
