Pages: [1]   Go Down
Author Topic: Interfacing TPIC6C596N  (Read 776 times)
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
Hi, i am intersting to use this shift register TPIC6C596N with arduino like common 595.
on the datasheet it says about these pins
RCK-register clock
CLR-shift register clear
SRCK-shift register clock
SER IN-serial input
shiftout uses these pins
clockPin
latchPin
dataPin
what pins do i need to connect to use shiftout command? and what is the different RCK and SRCK?
or better question how can i make this work with arduino?
edit:
i  was trying to understand and i think its ok:
SERIN=DATAPIN
SRCK=CLOCKPIN
RCK= LATCHPIN
CLEAR= it just clear the registers when it goes on low
is this correct?
« Last Edit: December 02, 2010, 05:20:55 pm by acmilangr » Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
The pinout is exactly the same it is just that they call the pin functions by different names. Just use the same pin numbers as you see in the tutorial.
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
not they are not the same
look
http://focus.ti.com/lit/ds/symlink/tpic6c596.pdf
http://www.arduino.cc/en/Tutorial/ShiftOut
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
any help please?
Logged
Pages: [1]   Go Up
Jump to:
