Loading...
Pages: 1 [2] 3 4   Go Down
Author Topic: i dont get it  (Read 1477 times)
Hyderabad , India
Offline Offline
God Member
can't help not to think arduinaizing something !
View Profile
WWW
bill2009
 well you made me a bit confused your code uses only two states and not in the way cr0sh had told
(or i didnt understand states correctly ?  :-? )
Logged
Hyderabad , India
Offline Offline
God Member
View Profile
WWW
Quote
Code:unsigned long readPing (int pingPin)
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  pinMode(pingPin, INPUT);
  return pulseIn(pingPin, HIGH);
so the ping code i used is not correct with eregards to the data types ?
if possible could you eloborate so tha  i get a clear picture  :smiley
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
The Ping code you have is not the problem, it is just that the example code is horrible.
The data type issue is fairly obvious from the posted code and the documentation.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Hyderabad , India
Offline Offline
God Member
View Profile
WWW
Helllo i am back  smiley-wink
well here i wrote the code as cr0sh told
Code:
///setting up pin no's ////
#include <Servo.h>
#define ledpin_right 13
#define ledpin_left 12
#define motor_ONE_pin_ONE=3;
#define motor_ONE_pin_TWO=4;
#define motor_TWO_pin_ONE=5;
#define motor_TWO_pin_TWO=6;
const int pingPin = 10;
int pos = 0 ;
Servo myservo;
long dist_right =0;
long dist_left = 0;
int state = 1;
long duration,cm;
/////setting pinmode//////
  myservo.attach(9);
  pinMode(motor_ONE_pin_ONE,OUTPUT);
  pinMode(motor_ONE_pin_TWO,OUTPUT);
  pinMode(motor_TWO_pin_ONE,OUTPUT);
  pinMode(motor_TWO_pin_TWO,OUTPUT);
//////looping funtoinn//////
  switch(state)
    case 1:
    ping_read();
    drive_forward();
    if(cm < 10 )
      state = 2;
    case 2:
    ping_read_right();
    ping_read_left();
    state =3;
    case 3:
    if(distance_right > distance_left )
      state =4;
    else if (distance_right < distance_left )
      state =5;
    else if ((distance_right && distance_left ) < 10 )
      state =6;
    case 4:
    drive_right();
    case 5:
    drive_left();
    case 6:
    drive_360();
    default:
//////ping functions///////
void ping_read()
  duration = pulseIn(pingPin, HIGH);
  cm = microsecondsToCentimeters(duration);
  Serial.print(cm);
  Serial.print("cm");
void ping_read_left()
  myservo.write(10);
  dealy(150);
  distance_left = microsecondsToCentimeters(duration);
  Serial.print(distance_left);
  Serial.print("cm");
void ping_read_right()
  myservo.write(180);
  delay(150);
  distance_right = microsecondsToCentimeters(duration);
  Serial.print(distance_right);
  Serial.print("cm");
long microsecondsToCentimeters(long microseconds)
  return microseconds / 29 / 2;
///////drive functions//////
void drive_forward()
  digitalWrite(motor_ONE_pin_ONE,HIGH);
  digitalWrite(motor_TWO_pin_ONE,LOW);
  digitalWrite(motor_ONE_pin_TWO,HIGH);
  digitalWrite(motor_TWO_pin_TWO,LOW);
  return;
void drive_stop()
  digitalWrite(motor_ONE_pin_ONE,LOW);
  digitalWrite(motor_ONE_pin_TWO,LOW);
  return;
void drive_right()
  return;
void drive_left()
  return;
void drive_360()
  return;
and i get the following whole lot of errors
Quote
FINAL.cpp: In function 'void setup()':
FINAL:26: error: expected primary-expression before '=' token
FINAL:26: error: expected primary-expression before ',' token
FINAL:26: error: expected `;' before ')' token
FINAL:27: error: expected primary-expression before '=' token
FINAL:27: error: expected primary-expression before ',' token
FINAL:27: error: expected `;' before ')' token
FINAL:28: error: expected primary-expression before '=' token
FINAL:28: error: expected primary-expression before ',' token
FINAL:28: error: expected `;' before ')' token
FINAL:29: error: expected primary-expression before '=' token
FINAL:29: error: expected primary-expression before ',' token
FINAL:29: error: expected `;' before ')' token
FINAL.cpp: In function 'void loop()':
FINAL:54: error: 'distance_right' was not declared in this scope
FINAL:54: error: 'distance_left' was not declared in this scope
FINAL:76: error: expected primary-expression before '}' token
FINAL:76: error: expected `;' before '}' token
FINAL.cpp: In function 'void ping_read_left()':
FINAL:102: error: 'dealy' was not declared in this scope
FINAL:111: error: 'distance_left' was not declared in this scope
FINAL.cpp: In function 'void ping_read_right()':
FINAL:128: error: 'distance_right' was not declared in this scope
FINAL.cpp: In function 'void drive_forward()':
FINAL:143: error: expected primary-expression before '=' token
FINAL:143: error: expected primary-expression before ',' token
FINAL:143: error: expected `;' before ')' token
FINAL:144: error: expected primary-expression before '=' token
FINAL:144: error: expected primary-expression before ',' token
FINAL:144: error: expected `;' before ')' token
FINAL:145: error: expected primary-expression before '=' token
FINAL:145: error: expected primary-expression before ',' token
FINAL:145: error: expected `;' before ')' token
FINAL:146: error: expected primary-expression before '=' token
FINAL:146: error: expected primary-expression before ',' token
FINAL:146: error: expected `;' before ')' token
FINAL.cpp: In function 'void drive_stop()':
FINAL:153: error: expected primary-expression before '=' token
FINAL:153: error: expected primary-expression before ',' token
FINAL:153: error: expected `;' before ')' token
FINAL:154: error: expected primary-expression before '=' token
FINAL:154: error: expected primary-expression before ',' token
FINAL:154: error: expected `;' before ')' token
FINAL:155: error: expected primary-expression before '=' token
FINAL:155: error: expected primary-expression before ',' token
FINAL:155: error: expected `;' before ')' token
FINAL:156: error: expected primary-expression before '=' token
FINAL:156: error: expected primary-expression before ',' token
FINAL:156: error: expected `;' before ')' token
FINAL.cpp: In function 'void drive_right()':
FINAL:162: error: expected primary-expression before '=' token
FINAL:162: error: expected primary-expression before ',' token
FINAL:162: error: expected `;' before ')' token
FINAL:163: error: expected primary-expression before '=' token
FINAL:163: error: expected primary-expression before ',' token
FINAL:163: error: expected `;' before ')' token
FINAL:164: error: expected primary-expression before '=' token
FINAL:164: error: expected primary-expression before ',' token
FINAL:164: error: expected `;' before ')' token
FINAL:165: error: expected primary-expression before '=' token
FINAL:165: error: expected primary-expression before ',' token
FINAL:165: error: expected `;' before ')' token
FINAL.cpp: In function 'void drive_left()':
FINAL:171: error: expected primary-expression before '=' token
FINAL:171: error: expected primary-expression before ',' token
FINAL:171: error: expected `;' before ')' token
FINAL:172: error: expected primary-expression before '=' token
FINAL:172: error: expected primary-expression before ',' token
FINAL:172: error: expected `;' before ')' token
FINAL:173: error: expected primary-expression before '=' token
FINAL:173: error: expected primary-expression before ',' token
FINAL:173: error: expected `;' before ')' token
FINAL:174: error: expected primary-expression before '=' token
FINAL:174: error: expected primary-expression before ',' token
FINAL:174: error: expected `;' before ')' token
FINAL.cpp: In function 'void drive_360()':
FINAL:180: error: expected primary-expression before '=' token
FINAL:180: error: expected primary-expression before ',' token
FINAL:180: error: expected `;' before ')' token
FINAL:181: error: expected primary-expression before '=' token
FINAL:181: error: expected primary-expression before ',' token
FINAL:181: error: expected `;' before ')' token
FINAL:182: error: expected primary-expression before '=' token
FINAL:182: error: expected primary-expression before ',' token
FINAL:182: error: expected `;' before ')' token
FINAL:183: error: expected primary-expression before '=' token
FINAL:183: error: expected primary-expression before ',' token
FINAL:183: error: expected `;' before ')' token
smiley-sad could anyone help me out please  smiley
Logged
ottawa, canada
Offline Offline
God Member
Arduino rocks
View Profile
Code:
the format for # define is "#define symbol value" with no punctuation.
take the = and ;'s out of these and some of the flakier errors will disappear.  then you've got some simple errors (distance_right is declared as dist_right, delay is misspelled in one place).
fix those, compile again and havnd try to figure out what the messages mean.
I combined states in your code because they were just sequential steps.
The test for left and right <10 still needs to be fixed.
« Last Edit: December 02, 2010, 10:06:43 am by bill2009 » Logged
UK
Offline Offline
Faraday Member
Gorm deficient
View Profile
Don't put semicolons on #defines unless you really know what you're doing
Logged
Per Arduino ad Astra
ottawa, canada
Offline Offline
God Member
Arduino rocks
View Profile
Quote
or equal signs?
Logged
Central Europe
Offline Offline
Edison Member
Use the Source, Luke.
View Profile
Use const int or whatever instead of #define.
Korman
« Last Edit: December 02, 2010, 10:17:36 am by Korman » Logged
Hyderabad , India
Offline Offline
God Member
View Profile
WWW
i changed the code to..
Code:
#include <Servo.h>
#define motor_ONE_pin_ONE 3
#define motor_ONE_pin_TWO 4
#define motor_TWO_pin_ONE 5
#define motor_TWO_pin_TWO 6
int pos = 0 ;
Servo myservo;
int state = 1;
long duration,cm;
long distance_right = 0 ;
long distance_left = 0 ;
  myservo.attach(9);
  switch(state)
    case 1:
    ping_read();
    drive_forward();
    if(cm < 10 )
      state = 2;
    case 2:
    ping_read_right();
    ping_read_left();
    state =3;
    case 3:
      state =4;
      state =5;
      state =6;
      state = 1 ;
    case 4:
    drive_right();
    case 5:
    drive_left();
    case 6:
    drive_360();
    default:  ;
void ping_read()
  Serial.print(cm);
  Serial.print("cm");
  myservo.write(10);
  delay(150);
  Serial.print("cm");
  myservo.write(180);
  delay(150);
  Serial.print("cm");
  return;
void drive_stop()
  return;
void drive_right()
  return;
void drive_left()
  return;
void drive_360()
  return;
now i ahve noo errors BUT
even noiw the drive forward condition is not occuring when an obstacle is detedted the servo is set to 0 degrees and then the left motor is rotaing continiously  smiley-sad
Logged
Hyderabad , India
Offline Offline
God Member
View Profile
WWW
Quote
Quote
well i am really sorry ii didnt notice any equal to signs or colons any where i am really sorry for wasting your time  :-[
well now i have seen what i posted and i could see that it was clearly indicated as to wheere the error was but i didnt notice any equalto or colon anywhere  >smiley-sad
Logged
ottawa, canada
Offline Offline
God Member
Arduino rocks
View Profile
Code:
you're going to drive me nuts til you fix that.
put serial prints at the top and bottom of the loop routine with the states and distances please.
Logged
Hyderabad , India
Offline Offline
God Member
View Profile
WWW
i changed it
Quote
Logged
Hyderabad , India
Offline Offline
God Member
View Profile
WWW
Quote
I guess this is what you meant
Code:
#include <Servo.h>
int pos = 0 ;
Servo myservo;
int state = 1;
long duration,cm;
  myservo.attach(9);
  switch(state)
    state = 1 ;
    Serial.print("in state 1 ");
    case 1:
    ping_read();
    drive_forward();
    if(cm < 10 )
      state = 2;
      Serial.print("switching to state two");
    case 2:
    ping_read_right();
    ping_read_left();
    state =3;
    Serial.print("in state three");
    case 3:
      state =4;
      Serial.print("switching to state 4 ");
      state =5;
      Serial.print("switching to state 5 ");
    else if ( (distance_right<10) && (distance_left<10) )
      state =6;
      Serial.print("switching to state 1 ");
      state = 1 ;
    case 4:
    drive_right();
    case 5:
    drive_left();
    case 6:
    drive_360();
    default:  ;
void ping_read()
  Serial.print(cm);
  Serial.print("cm");
  return;
  myservo.write(10);
  delay(150);
  Serial.print("cm");
  return;
  myservo.write(180);
  delay(150);
  Serial.print("cm");
  return;
  return;
void drive_stop()
  return;
void drive_right()
  return;
void drive_left()
  return;
void drive_360()
  return;
even now the same thing occurs and this is what i get on the serial monitor after it put my hnad infront the ping
Code:
9cm
13cm
14cm
in state three
Logged
ottawa, canada
Offline Offline
God Member
Arduino rocks
View Profile
and is it now driving left?
Logged
Hyderabad , India
Offline Offline
God Member
View Profile
WWW
Quote
Yes !
but the problem is the servo stays to the left position and i sillt cant see the drive forward occuring  :-?
i modified and
Quote
 case 4:
    drive_right();
    state = 1 ;
    case 5:
    drive_left();
    state = 1;
    case 6:
    drive_360();
    state = 1;
    default:  ;
Bur still i cant see it drive forward
Logged
Pages: 1 [2] 3 4   Go Up
Print
Jump to:
