Topic: Serial data to Visual Basic, Visual C++, Java (Read 16121 times) previous topic - next topic
pd2kplus10
 Hello all,
  I'm interested in sending serial data from an arduino to my PC and have it displayed on either VB,VC++ or Java program. I'm not sure which one would be easiest to do. I would like to be able to make a simple program rather quickly ... nothing too fancy.
I just need to display a reading from one sensor.
thanks,
Phil
hotcarrier
You might try Processing at http://processing.org/. It uses much the same IDE as the Arduino and is similar in many other respects. There are many examples on the Forum and elsewhere to provide the capability you are seeking.
PlastBox
If you use Visual Basic, communicating with the Arduino is pretty simple stuff.
1. Add the object Microsoft Comm Control 6.0 to your project, and put it on the form.
2. Set the correct properties for MSComm1 (baud-rate, com-port, etc.) This depends on your Arduino-code and your computer setup.
3. Add the following code to the Form_Load() event (double click the form):
Private Sub Form_Load()
MSComm1.PortOpen = True
End Sub
4. Add a Timer to your form (the small clock-symbol-thingie) and set it's interval to something like 100ms (Interval: 100)
5. Add the following code to the timer (double click the timer-object on the form)
Private Sub Timer1_Timer()
If MSComm1.InBufferCount > 0 Then
   Dim buf as string
   buf = MSComm1.Input
End If
End Sub
6. To send data back to the Arduino, you place the following code in your program (in a button_Click() event or something like that)
MSComm1.Output "whatever you want to send"
pd2kplus10
  Thanks guys for the help. I think for now I'm going to start with Processing. It seems to be a lot easier to work with. I would like to play around with some VB & C++ , but I don't think I'm ready for it at the moment.
 Thanks for the code Plastbox. That was very helpful. The only thing is ... I don't have VB 6.0 .. I have the free VB 2008 Express. I don't think it has MS Comm. It does have SerialPort.
thanks,
Phil
PlastBox
Aaah, ok. I just assumed VB6 as it is by far the most easy windows environment and language to get started with. Also, people whine constantly about the performance and such of programs made with VB6. Up yours, people! When one is talking about small utility-applications and stuff like that, performance doesn't even come into play.  ;)
pd2kplus10
Yeah ... I don't know why people complain about VB. I don't care about performance differences. It's not like I'm programming a 3D shooter or anything. Besides... I was reading that most programmers aren't even good enough to code in C++ to make it any faster than if it were in VB. I definitely know that I'm not good enough.
I'm more of a hardware guy than a programmer. I would just like to make some quick and easy windows apps that are functional.
Phil
MikMo
#6
May 01, 2008, 05:34 pm Last Edit: May 01, 2008, 05:35 pm by MikMo Reason: 1
The newer versions of VB ( the .net versions) are not quite as easy to program to use the serial port. But it's possible.
I have some kode that recieves data from Arduino if anybody is interested.
It's a very simple app.
And by the way, in the new versions there is no speed penalty for using VB, it's compiled to the same intermediary language as the other .net languages.
pd2kplus10
 Hello MikMo,
 Please do post the code. I would like to see it.
thanks,
Phil
MikMo
I just realized the the VB program is on a computer that i stuffed under my bed to make room for a major party.
I will have it back in place again in a couple of days.  My code is based on a small VB sample app. i found somewhere on the internet. It was something like a small two way chat program using a serial line to ceooent two PC's.
auerlg
Hey I think I found the source code for the chat VB application.
Pasting it:
Visual Basic 2005 band up - Chat over serial port
Imports System
Imports System.IO.Ports
Imports System.Threading
Public Class PortChat
   Shared _continue As Boolean
   Shared _serialPort As SerialPort
   Public Shared Sub Main()
       Dim name As String
       Dim message As String
       Dim sComparer As StringComparer = StringComparer.OrdinalIgnoreCase
       Dim readThread As Thread = New Thread(AddressOf Read)
       ' Create a new SerialPort object with default settings.
       _serialPort = New SerialPort()
       ' Allow the user to set the appropriate properties.
       _serialPort.PortName = SetPortName(_serialPort.PortName)
       _serialPort.BaudRate = SetPortBaudRate(_serialPort.BaudRate)
       _serialPort.Parity = SetPortParity(_serialPort.Parity)
       _serialPort.DataBits = SetPortDataBits(_serialPort.DataBits)
       _serialPort.StopBits = SetPortStopBits(_serialPort.StopBits)
       _serialPort.Handshake = SetPortHandshake(_serialPort.Handshake)
       ' Set the read/write timeouts
       _serialPort.ReadTimeout = 500
       _serialPort.WriteTimeout = 500
       _serialPort.Open()
       _continue = True
       readThread.Start()
       Console.Write("Name: ")
       name = Console.ReadLine()
       Console.WriteLine("Type QUIT to exit")
       While (_continue)
           message = Console.ReadLine()
           If sComparer.Equals("quit", message) Then
               _continue = False
           Else
               _serialPort.WriteLine( _
                   String.Format("<{0}>: {1}", name, message))
           End If
       end while
       readThread.Join()
       _serialPort.Close()
   End Sub
   Public Shared Sub Read()
       While (_continue)
           Try
               Dim message As String = _serialPort.ReadLine()
               Console.WriteLine(message)
           Catch ex As TimeoutException
               ' Do nothing
           End Try
       End While
   End Sub
   Public Shared Function SetPortName(ByVal defaultPortName As String) As String
       Dim newPortName As String
       Console.WriteLine("Available Ports:")
       Dim s As String
       For Each s In SerialPort.GetPortNames()
           Console.WriteLine("   {0}", s)
       Next s
       Console.Write("COM port({0}): ", defaultPortName)
       newPortName = Console.ReadLine()
       If newPortName = "" Then
           newPortName = defaultPortName
       End If
       Return newPortName
   End Function
   Public Shared Function SetPortBaudRate(ByVal defaultPortBaudRate As Integer) As Integer
       Dim newBaudRate As String
       Console.Write("Baud Rate({0}): ", defaultPortBaudRate)
       newBaudRate = Console.ReadLine()
       If newBaudRate = "" Then
           newBaudRate = defaultPortBaudRate.ToString()
       End If
       Return Integer.Parse(newBaudRate)
   End Function
   Public Shared Function SetPortParity(ByVal defaultPortParity As Parity) As Parity
       Dim newParity As String
       Console.WriteLine("Available Parity options:")
       Dim s As String
       For Each s In [Enum].GetNames(GetType(Parity))
       Next s
       Console.Write("Parity({0}):", defaultPortParity.ToString())
       newparity = Console.ReadLine()
       If newparity = "" Then
           newparity = defaultPortParity.ToString()
       End If
       Return CType([Enum].Parse(GetType(Parity), newParity), Parity)
   End Function
   Public Shared Function SetPortDataBits(ByVal defaultPortDataBits As Integer) As Integer
       Dim newDataBits As String
       Console.Write("Data Bits({0}): ", defaultPortDataBits)
       newDataBits = Console.ReadLine()
       If newDataBits = "" Then
           newDataBits = defaultPortDataBits.ToString()
       End If
       Return Integer.Parse(newDataBits)
   End Function
   Public Shared Function SetPortStopBits(ByVal defaultPortStopBits As StopBits) As StopBits
       Dim newStopBits As String
       Console.WriteLine("Available Stop Bits options:")
       Dim s As String
       For Each s In [Enum].GetNames(GetType(StopBits))
       Next s
       Console.Write("Stop Bits({0}):", defaultPortStopBits.ToString())
       newStopBits = Console.ReadLine()
       If newStopBits = "" Then
           newStopBits = defaultPortStopBits.ToString()
       End If
       Return CType([Enum].Parse(GetType(StopBits), newStopBits), StopBits)
   End Function
   Public Shared Function SetPortHandshake(ByVal defaultPortHandshake As Handshake) As Handshake
       Dim newHandshake As String
       Console.WriteLine("Available Handshake options:")
       Dim s As String
       For Each s In [Enum].GetNames(GetType(Handshake))
       Next s
       Console.Write("Stop Bits({0}):", defaultPortHandshake.ToString())
       newHandshake = Console.ReadLine()
       If newHandshake = "" Then
           newHandshake = defaultPortHandshake.ToString()
       End If
       Return CType([Enum].Parse(GetType(Handshake), newHandshake), Handshake)
   End Function
End Class
pd2kplus10
 Thanks auerlg.
  I'm messing around with Processing right now ... not as easy as I initially thought it would be. I figured out last night how to print my data to a window using text();   ... still trying to figure out how to refresh it without overlapping the previous value.
 I guess I should still look into using VB. Is that code for the 2 way chat program? If so ... how easy would it be for me to use this for one-way communication (Arduino to VB) ?
thanks,
Phil
reak_dk
Hello All.
Are there anybody that has a VB 2008 Express program running to control the Arduino.
maby someone can make a toturical on switching a led on and off from VB,
and reading a bottom press in VB from Arduino input.
Just to get us beginners started.
Regards
   Brian
dolphin
I don't know if you are interested, but I adapted some serial C++ class for its use under linux.
The code is posted in this website https://webfiles.uci.edu/cagell/news/news.htm, along with some other useful codes.
Let me know if it helped!!!
Dolphin
MikMo
#14
May 16, 2008, 04:49 pm Last Edit: May 16, 2008, 04:51 pm by MikMo Reason: 1
sorry for the delay. i just got sidetracked by work and new grilfriend :-)
Here's a link to my VB projekt. It's only one way Arduino -> VB, but i should be a piece of cake to also send the other way.
If anbody modify it please post here so we can share our VB <-> Arduino experiences
EDIT :
Wouldn't it be nice to make some kind of "generalised" VB class or component to interface with Arduino, mabe even some kind of dataexchange protocol on top of it ?
