Topic: Problems in TX/RX data between C# and Arduino (Read 10235 times) previous topic - next topic
reynal74
I'm trying to use arduino to read four analog inputs from some black box (all at the same freq), send the data to C# through serial and finally use C# to print it in a file. From C# I manage to tell arduino how many reads to get, and give the indication of transmission. However, i'm not receiving the correct data or sometimes i receive the correct data except that it is incomplete (if I indicate 100 readings, I only get 60). Can anybody point me into the right direction? I have tried everything that I have found and yet have not accomplish my goal. Below are my codes for Arduino and part of the C#. I will appreciate your help.
Thank you.
Arduino Code:
Code: [Select]
//Variable Declaration List
#define Input0 A0 //Assigning PINs for the operation
#define Input1 A1
#define Input2 A2
#define Input3 A3
float Input0_Data = 0; //Assigning Variables to hold the values read from the PINs
float Input1_Data = 0;
float Input2_Data = 0;
float Input3_Data = 0;
const float ToAnalogCoefficient = 5.0/1023.0; // Multiplication by ToAnalogCoefficient converts ASCII-encoded decimal back to Analog
int N = 0; //Variable for the N-Domain
boolean started = false;
boolean ended = false;
char buffer[30];//creating buffer large enough
int serialIn = 0;//counter for the incoming data
int atoiHolder = 50;//holds the value of atoi, default value 50
     Serial.begin(19200); //opens serial port and sets data rate to 19200bpm
     while(Serial.available() > 0)
           char incomingData = Serial.read(); //reading from the serial ( data from C# )
           if(incomingData == '<')//check for started packet
                 started = true;//the string started
                 ended = false;
           else if(incomingData == '>')//check for ended packet
                 ended = true;//indicated end of the reading
                 break; //break out of the loop
                 buffer[serialIn] = incomingData;//begining to store data in the buffer
                 serialIn++;
                 buffer[serialIn] = '\0';// NULL terminate the array
     }//end of while loop
     //-------------- Executing C# Commands --------------
     if(started && ended)
           if(buffer[0] == 'N')
                 buffer[0] = '0';//replaces N by '0' and now buffer holds '0','X','X','X','X'
                 atoiHolder = atoi(buffer);//atoiHolder now holds XXXX (number of reads decided by user)
           if(buffer[0] == 'T' && buffer[1] == 'X')//indication from C# to TX data
                 while(N <= atoiHolder)
                 Serial.print("======================");
                 Serial.print(atoiHolder);Serial.print("    ");Serial.print(N);
                 Serial.println("======================");
                       if(N == atoiHolder)
                                       Serial.print("IM AT THE END OF COM");
                             Serial.end();//when exciding the desired number of reads, end serial communication
                       //ADC OPERATION
                       Input0_Data  = analogRead(Input0);//Reading inputs from analog inputs
                       Input1_Data  = analogRead(Input1);
                       Input2_Data  = analogRead(Input2);
                       Input3_Data  = analogRead(Input3);
                       Input0_Data = Input0_Data * ToAnalogCoefficient; //converting ASCII-encoded decimal back to Analog
                       Input1_Data = Input1_Data * ToAnalogCoefficient;
                       Input2_Data = Input2_Data * ToAnalogCoefficient;
                       Input3_Data = Input3_Data * ToAnalogCoefficient;
                       Serial.print(N);Serial.print(';');//Packaging the data to be outputted to the computer
                       Serial.print(Input0_Data,8);Serial.print(';');//The selected format  N;Input0_Data;Input1_Data;Input2_Data;Input3_Data;
                       Serial.print(Input1_Data,8);Serial.print(';');
                       Serial.print(Input2_Data,8);Serial.print(';');
                       Serial.print(Input3_Data,8);Serial.println(';');
                       N = N + 1; //Incrementing the N-Domain
                       delay(10);//delay of 10ms to let ADC recover ( SEARCH IF NECESSARY )
           }//end of transmitting section
           serialIn = 0;//resetting serialIn
           buffer[serialIn] = '\0';//Null the buffer array
           started = false; //reset to false
           ended = false; //reset to false
     }//end of Executing C# Commands
}//end of loop
C# Code:
//Upper variable declarations
       DateTime CurrentTime = DateTime.Now; //Setting the clock to current system clock time
       string desktopPath = Environment.GetFolderPath(Environment.SpecialFolder.Desktop); //path to the desktop made into strings
       string RxData;//String to hold the data from arduino serial port
Code: [Select]
      //Opening the selected Port
       private void OpenPortButtom_Click(object sender, EventArgs e)
           if (PortSelectBox.SelectedItem == null)//check if not port selected
               MessageBox.Show("No Serial Ports was selected, Try again.");//message box telling user that there is not ports open
               //++++++++SETTINGS FOR THE SERIAL PORT+++++++++++
               serialPort1.PortName = PortSelectBox.SelectedItem.ToString();//setting serialPort1 to a selected port by user
               serialPort1.BaudRate = 19200;
               serialPort1.DataBits = 8;
               serialPort1.ReadBufferSize = 10240;  //10 * 1024bit = 10KB
               serialPort1.WriteBufferSize = 2048; //2 * 1024bit = 2KB
               if (serialPort1.IsOpen == true)
                   serialPort1.Close();//closing port if previously open
                   serialPort1.Open();//opening port
                   serialPort1.Open();//opening port when the program starts
               OpenPortButtom.Enabled = false; //disabling open port button
               ClosePortButtom.Enabled = true;//enabling the closing port button
               SettupButton.Enabled = true;//enabling the settup button
               StartArduinoButton.Enabled = true;//enabling the flush serial button
       }//end of OpenPortButtom
       //settings for the button that starts arduino serial transmission
       private void StartArduinoButton_Click(object sender, EventArgs e)
           if (serialPort1.IsOpen == true)//checking if any port is open in order to close it
               //creating output file
               string ArduinoLogName = @"" + desktopPath + "\\" + "ArduinoData_" + DateTime.Now.ToString("MMM-d-yyyy") + ".txt";//creates the log file
               FileStream ArduinoLogFile = new FileStream(ArduinoLogName, FileMode.Append);//makes the files writable if existent or creates a new file
               StreamWriter writer = new StreamWriter(ArduinoLogFile);//variable to write
               serialPort1.Write("<TX>");//Sending arduino the transmitting command
               MessageBox.Show("Arduino is transmitting data...");//message box telling user that arduino was flushed
               try
                   RxData = serialPort1.ReadExisting();//reading data from the port
                   writer.WriteLine(RxData);//writing the transmitted data
               catch(Exception RzData)
                   RxData = RzData.ToString();
               ArduinoLogFile.Close();//Closing the data file
               MessageBox.Show("There is no Serial Ports open.");//message box telling user that there is not ports open
               StartArduinoButton.Enabled = false;//disabling the start arduino button
       }//end of StartArduinoButton
       //settings for button that tells arduino how many readings to take
       private void SettupButton_Click(object sender, EventArgs e)
               if (SelNumberOfReading.SelectedItem == null)
                   MessageBox.Show("No number of reading was selected, using default (50 readings).");
                   serialPort1.Write("<N50>");//Sending the readings selected [default (50 readings)]
                   serialPort1.Write("<N" + SelNumberOfReading.SelectedItem.ToString() + ">");//Sending arduino the readings selected, format <N#####>
                   MessageBox.Show("Arduino has been set to " + SelNumberOfReading.SelectedItem.ToString() + " number of readings.");//message box telling user the selected number of readings
               SettupButton.Enabled = false;//disabling the settup button
       }//end of SettupButton
PaulS
Code: [Select]
8 decimal places, huh? Do you think you are really getting 8 decimal places of accuracy from whatever the sensor is?
Quote
How do you know you are not receiving the correct data?
Code: [Select]
Where did you allocate a buffer this big? I didn't see one.
reynal74
Thanks for the reply PaulS. The black box give 10 decimal places, or so i as told. I confirmed that I'm receiving the correct data, however, its incomplete as indicated above.  how can i allocate a buffer? string buffer? Is there any examples on how to do it?
PaulS
It appears that you don't really need that big a buffer. It also appears that you are telling the SerialPort class to allocate that buffer.
Serial data transmission is relatively slow. You don't need a huge buffer to hold incoming data. You just need to read it often enough, which you appear to be doing.
Quote
I have no idea what this black box is, but expecting to read data accurate to 10 decimal places, or even 8, is unrealistic, in my opinion.
What are you doing with that data, after getting it back to the PC?
What evidence do you have (you haven't provided any) that you are not getting back complete and accurate data?
Do you see something in the file like "Measurement 8 of 100" that eventually increments to "Measurement 60 of 100" which is the last entry in the file?
Do you echo the data coming into the C# application, before writing it to the file?
reynal74
After I get the data into the computer i'm planning in doing FFT, filtering, plotting and few more stuff regarding signal comparison. As for the accuracy, I do not mind reading up to 3 or 4 decimal places. When I get the resulting file from Arduino and C#, I have a header before each reading that indicates at what measurement i'm at and that is what indicates me that the data is incomplete. am I failing to write everything to the file?
Quote
how do I echo data coming into the C# application? what does echo really means?
PaulS
Quote
Run the application in debug mode, with plenty of calls to Console.WriteLine().
Quote
Just printing it out, before doing anything with it.
reynal74
I changed the serial port buffer size to 4096 (4KB), and the precition to 4 decimal places. Yet, I still have not been able to allocate the buffer. By the way, Is there a way for me to receive data from arduino everytime I request it from the C# application without the need of opening the serial monitor and closing it again? After I upload the code into the board and run C# to extract the data, I can only get data one time. Then, I have attempted to request data a second time during the same session but nothing is TX  :o. I close the port and then open it again to request more data from arduino. But nothing is being transmitted (TX light does not blinks).  Has anyone experienced something like this?
PaulS
From my C# application, I can talk to the Arduino all day.
Quote
How does this help. Only one application on the PC can talk to the serial port at a time. If the C# application has opened the port, the Serial Monitor application should not be able to.
reynal74
You are right about the ports, once C# opens it the serial monitor does not works. My problem refer to the fact that once arduino TX for the first time, it will not transmitt again for a second time without me 1) closing the port using C# 2) opening and closing the serial monitor 3) reopening the port with C#.
PaulS
#9
Nov 26, 2010, 10:07 pm Last Edit: Nov 26, 2010, 10:09 pm by PaulS Reason: 1
I would venture a guess, then, that the problem is that the Arduino code is the culprit.
Set up a button that sends a command to the Arduino to take one reading. Have the Arduino send that one reading back.
Can you press that button more than once. with results being returned each time?
Opening the Serial Monitor, after closing it in the C# application, causes the Arduino to be reset.
reynal74
The procedure you mentioned is the exact same procedure i have, and the first time i press the button and request to TX I get data. But when i request data again by pressing the button, I do not receive nothing.  And yes, I think that opening the Serial Monitor, after closing it in the C# application, causes the arduino to be reset.  ;D  How can I deal with that? Has that happend before?
PaulS
I went back and looked at your Arduino code. At the end of the loop that responds to a request for data you have this:
Code: [Select]
And you wonder why the Arduino won't listen to you anymore?
reynal74
Oops... Is there any other way to tell arduino to stop sending data until indicated again to keep on sending data?
PaulS
The Arduino sends data in response to requests. Quit asking, and it will quit sending.
reynal74
Sounds good. Now i only need to work on the buffer allocation and properly writing to the file. Is it possible to program arduino's chip and take it out of the board and use it dirrectly from a bread board? Eventually, i will need to burn a few of them trying to get at least one correctly into PBC board. Will the ADC still work?
