Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #15 on: November 26, 2010, 05:33:49 pm » |
Now i only need to work on the buffer allocation You are telling the SerialPort class to allocate a receive buffer. I don't see that you have anything more to do. and properly writing to the file. Is there a problem with this? Have you confirmed that you are getting all the data to the C# application? Is it possible to program arduino's chip and take it out of the board and use it dirrectly from a bread board? With a few extra pieces, yes. "standalone" is the search term you want. Will the ADC still work? But, of course.
Logged
New York, NY
Offline
Newbie
Almighty Forum, help this newbie solve his problem
« Reply #16 on: November 27, 2010, 09:57:31 pm » |
By echoing the data I confirmed that Arduino is giving me all the values that I request, however, I have not manage to get all the data in the files created. Is there any better approach to writing the data into a file? I'm using the following C# private void StartArduinoButton_Click(object sender, EventArgs e) { if (serialPort1.IsOpen == true)//checking if any port is open in order to close it { //creating output file string ArduinoLogName = @"" + desktopPath + "\\" + "ArduinoData_" + DateTime.Now.ToString("MMM-d-yyyy") + ".txt";//creates the log file FileStream ArduinoLogFile = new FileStream(ArduinoLogName, FileMode.Create);//creates a new file or overwrites a previous file created StreamWriter writer = new StreamWriter(ArduinoLogFile);//variable to write
serialPort1.Write("<TX>");//Sending arduino the transmitting command int NumberOfReadings = int.Parse(SelNumberOfReading.SelectedItem.ToString());//converting the selected number of readings from string to ints
for (int count = 0; count <= NumberOfReadings; count++) { try { RxData = serialPort1.ReadLine();//reading data from the port writer.WriteLine(RxData);//writing the transmitted data Console.WriteLine(RxData); } catch (Exception RzData) { RxData = RzData.ToString(); writer.WriteLine(RxData);//writing the transmitted data Console.WriteLine(RxData); } }
MessageBox.Show("The Transmission from Arduino has ended."); ArduinoLogFile.Close();//Closing the data file } else { MessageBox.Show("There is no Serial Ports open.");//message box telling user that there is not ports open StartArduinoButton.Enabled = false;//disabling the start arduino button }
serialPort1.Close();//closing the serial port this.Refresh(); this.Close();//closing the application }//end of StartArduinoButton Also, even though I close the port and the C# application, I still face the problem of needing to open the Serial Monitor for the Arduino to be reset. Is it manageable to have a function or something do that? would I experience the same problem if i use the ATmega328 as standalone?
Logged
If you think you have it, you don't. If you think you don't have it, you still don't.
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #17 on: November 28, 2010, 07:08:48 am » |
Go back and look at your Arduino code. How many lines is it sending if you request one reading? 2, by my count.
How many lines does it send if you request 5 readings. 10, by my count.
How many lines are you reading in the C# application using serialPort1.read(), after requesting 1 reading? 2, by my count (count == 0 and count == 1).
How many lines are you reading in the C# application using serialPort1.read(), after requesting 5 readings? 6, by my count (count == 0, count == 1, count ==2, count ==3, count == 4, and count == 5).
Also, notice that you open a file, and get a stream writer object from the file. After writing some stuff (buffered), you close the file, without closing the streams into that file. The streams might automatically be flushed and closed, but I never rely on that happening. Flush the streams and close them, before closing the file.
« Last Edit: November 28, 2010, 07:11:24 am by PaulS »
Logged
New York, NY
Offline
Newbie
« Reply #18 on: November 29, 2010, 01:38:30 pm » |
I did not manage to understand the comment below. I took care of the stream writer ( flush it and close it ), yet I do not manage to write all the data into the file. When I echo it, I see every point requested by the C# command. Go back and look at your Arduino code. How many lines is it sending if you request one reading? 2, by my count.
How many lines are you reading in the C# application using serialPort1.read(), after requesting 5 readings? 6, by my count (count == 0, count == 1, count ==2, count ==3, count == 4, and count == 5). This is how the reading part of C# is looking like, can some comments be done? //settings for the button that starts arduino serial transmission private void StartArduinoButton_Click(object sender, EventArgs e) { if (serialPort1.IsOpen == true)//checking if any port is open in order to close it { //creating output file string ArduinoLogName = @"" + desktopPath + "\\" + "ArduinoData_" + DateTime.Now.ToString("MMM-d-yyyy") + ".txt";//creates the log file FileStream ArduinoLogFile = new FileStream(ArduinoLogName, FileMode.Create);//creates a new file or overwrites a previous file created StreamWriter writer = new StreamWriter(ArduinoLogFile);//variable to write
serialPort1.Write("<TX>");//Sending arduino the transmitting command int NumberOfReadings;
if (SelNumberOfReading.SelectedItem == null) { NumberOfReadings = 50;//default number of readings } else { NumberOfReadings = int.Parse(SelNumberOfReading.SelectedItem.ToString());//converting the selected number of readings from string to ints }
MessageBox.Show("The Transmission from Arduino has ended."); writer.Flush();//flush the streams writer.Close();//close the streams ArduinoLogFile.Close();//Closing the data file } else { MessageBox.Show("There is no Serial Ports open.");//message box telling user that there is not ports open StartArduinoButton.Enabled = false;//disabling the start arduino button }
Logged
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #19 on: November 29, 2010, 02:04:27 pm » |
Your Arduino code contains: Serial.print("======================"); Serial.print(atoiHolder);Serial.print(" ");Serial.print(N); Serial.println("======================");
if(N == atoiHolder) { Serial.print("IM AT THE END OF COM"); Serial.end(); // Presumably, this has been removed. }
<snip>
Serial.print(N);Serial.print(';'); Serial.print(Input0_Data,8);Serial.print(';'); Serial.print(Input1_Data,8);Serial.print(';'); Serial.print(Input2_Data,8);Serial.print(';'); Serial.print(Input3_Data,8);Serial.println(';');
If one reading is requested, there will be 3 lines of output (not two as I suggested earlier). If ten readings are requested, there will be 21 lines of output (not 20 as I suggested earlier. Your C# code has this: for (int count = 0; count <= NumberOfReadings; count++) If one reading is requested, NumberOfReadings will be 1, and the loop will execute when count = 0 and when count = 1, reading 2 of the three lines. If ten readings are requested, NumberOfReadings will be 10, and the loop will execite when count = 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, and 10, reading 11 of the 21 lines sent.
Logged
New York, NY
Offline
Newbie
« Reply #20 on: November 29, 2010, 02:22:17 pm » |
I just changed that part of my Arduino code to avoid getting confused, now I have the code below. However, the problem remains. When I echo this with C#, all the points requested appear on the console. //-------------- Executing C# Commands -------------- if(started && ended) { if(buffer[0] == 'N') { buffer[0] = '0';//replaces N by '0' and now buffer holds '0','X','X','X','X' atoiHolder = atoi(buffer);//atoiHolder now holds XXXX (number of reads decided by user) } if(buffer[0] == 'T' && buffer[1] == 'X')//indication from C# to TX data { while(N <= atoiHolder) { //ADC OPERATION Input0_Data = analogRead(Input0);//Reading inputs from analog inputs Input1_Data = analogRead(Input1); Input2_Data = analogRead(Input2); Input3_Data = analogRead(Input3);
Input0_Data = Input0_Data * ToAnalogCoefficient; //converting ASCII-encoded decimal back to Analog Input1_Data = Input1_Data * ToAnalogCoefficient; Input2_Data = Input2_Data * ToAnalogCoefficient; Input3_Data = Input3_Data * ToAnalogCoefficient;
Serial.print(N);Serial.print(';');//Packaging the data to be outputted to the computer Serial.print(Input0_Data,3);Serial.print(';');//The selected format N;Input0_Data;Input1_Data;Input2_Data;Input3_Data; Serial.print(Input1_Data,3);Serial.print(';'); Serial.print(Input2_Data,3);Serial.print(';'); Serial.print(Input3_Data,3);Serial.println(';'); N = N + 1; //Incrementing the N-Domain delay(10);//delay of 10ms to let ADC recover ( SEARCH IF NECESSARY ) } }//end of transmitting section
serialIn = 0;//resetting serialIn buffer[serialIn] = '\0';//Null the buffer array started = false; //reset to false ended = false; //reset to false
}//end of Executing C# Commands
Logged
New York, NY
Offline
Newbie
« Reply #21 on: November 30, 2010, 12:12:34 am » |
I was messing around with the board and I noticed that if I press the reset button everything works fine, all the data is copied into the file created by the C# application. Is there a way of making that automatic? ;D
Logged
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #22 on: November 30, 2010, 06:34:48 am » |
Pressing the reset button on the Arduino has no impact on the code running on your PC. If you are seeing all of the data appear in the console window, and it all appears correct, the problem is with how you are writing that data to the file on the PC.
Resetting the Arduino causes the serial port connection to close. What is YOUR application doing when that happens?
Logged
New York, NY
Offline
Newbie
« Reply #23 on: November 30, 2010, 08:56:27 am » |
When I press the reset button my application is not doing nothing ( not even open ). does closing the port by resetting the Arduino (pressing the button) means Serial.end() ?
Logged
New York, NY
Offline
Newbie
« Reply #24 on: December 02, 2010, 09:13:48 am » |
Resetting the Arduino causes the serial port connection to close. I tried ending the port connection from the Arduino code and nothing good came out of it. Is it possible to do it within the code? I haven't found a command or a way to do the reset from the code. If I place the code into the chip (permanently??), would it get damage if I have some external way to do this reset (the reset will be made many times)? Also, does Arduino's chip have some minimum time requirement for the ADC to recover? I'm doing the following: void loop() { Serial.begin(); while(Serial.available() > 0) { char incomingData = Serial.read(); //reading from the serial ( data from C# )
if(incomingData == '<')//check for started packet { started = true;//the string started ended = false; } else if(incomingData == '>')//check for ended packet { ended = true;//indicated end of the reading break; //break out of the loop } else { buffer[serialIn] = incomingData;//begining to store data in the buffer serialIn++; buffer[serialIn] = '\0';// NULL terminate the array } }//end of while loop
Serial.print(N);Serial.print(';');//Packaging the data to be outputted to the computer Serial.print(Input0_Data,3);Serial.print(';');//The selected format N;Input0_Data;Input1_Data;Input2_Data;Input3_Data; Serial.print(Input1_Data,3);Serial.print(';'); Serial.print(Input2_Data,3);Serial.print(';'); Serial.print(Input3_Data,3);Serial.println(';'); N = N + 1; //Incrementing the N-Domain delay(10);//delay of 10ms to let ADC recover ( SEARCH IF NECESSARY ) } }//end of transmitting section Serial.end(); serialIn = 0;//resetting serialIn buffer[serialIn] = '\0';//Null the buffer array started = false; //reset to false ended = false; //reset to false
}//end of Executing C# Commands }//end of loop
Logged
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #25 on: December 02, 2010, 12:27:55 pm » |
Your problem is on the PC side and how you are handling the data there, not on the Arduino. Closing the serial port on the Arduino side will effectively take it off-line, and your PC application will not be able to talk to it again (until it is reset). I haven't found a command or a way to do the reset from the code. There isn't one. There are some methods to cause the Arduino to appear to reset, but they are not supported, and the side effects depend on the method. I'm not going to comment further on how to do it, because it is NOT what you need to do. Also, does Arduino's chip have some minimum time requirement for the ADC to recover? Yes. You can check the Atmel data sheet for particulars. Somewhere between 10 and 100 milliseconds generally works, depending on what is being measured.
Logged
New York, NY
Offline
Newbie
« Reply #26 on: December 12, 2010, 06:07:19 pm » |
Reset problem solved. Now i just need to make the code a bit more fault tolerant. thanks a lot for your help PaulS
Logged
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #27 on: December 12, 2010, 06:38:02 pm » |
Reset problem solved. That's great. What was the problem?
Logged
New York, NY
Offline
Newbie
« Reply #28 on: December 12, 2010, 10:41:08 pm » |
I just needed to set N = 0 before the while loop.
Logged
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #29 on: December 13, 2010, 06:54:06 am » |
I just needed to set N = 0 before the while loop. Ah, yes. The little things that trip you up.
Logged
