Topic: max with a rotary encoder (Read 17757 times) previous topic - next topic
boomy
Reading your pdf, it looks like a "normal" rotary-encoder to me.
I'm using sunny's library, which works great to define the upper and lower values. The only thing I miss, is to define an option to choose your own multiplier, so it won't in/de-crement with 1, but 5 for example.
In my program, hue and brightness are both from 0 - 255
I want to slowly choose a hue colour, but go 10 times faster with brightness.
I can only change the code now manually, but I want to feed the library with my variable input. I'm not a good programmer and need some help with coding a library with external input.
Phusysist
Quote
Yes it is...
It's working.
Thanks Boomy.
Justblair
Thanks to Sunbox for the Rotary Encoder Library.  For the cheapo mechanical encoders, this is the only one that I have had much luck with..
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
