Pages: [1]   Go Down
Author Topic: Help or guidance for a magnetic stripe reader proj  (Read 1136 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
hi i am working on a  magnetic stripe reader project, where i have to construct a head unit which consists of an tape recorder audio head, i have to interface the output of head to Arduino board's ADC, and using ADC i have to decode the data of track 2 in the magnetic stripe, can i get any help regarding this project by anyone please...............
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
I'd be surprised if you get enough signal straight from the head to make a meaningful reading on the ADC.
What is the spec of the reader?
Logged
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Not only do you have the problem of low level voltage, millivolts, the data format includes a clock and data that have to be decoded and seperated. Your best bet would be to find a surplus card reader (I found one for $5 once). If you search around this forum you might find a posting on someone that wrote a sketch to read such a reader.
Lefty
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
could u please send me the source code how would u read the data form audio head using adc.....?
because i tried from adc also but i reads continuously 111111111111......
Please help.....! :-/
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
the spec of the reader is
it has to read the track 2 using the tape recorder head.
if possible interface the head directly to the arduino board with
proper bias voltage to the tape recorder head.
the read data should be decoded and sent on the serial port to display on the serial monitor.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
That's going to make it difficult to complete the project.
Quote
"it"? What is "it"?
Quote
I think you'll need more than that.
Logged
South Africa
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
The basic circuit you will need to build is a high gain amplifier.
I've drawn a simplified version for you, but you'll have to figure out component values yourself. (they depend on which op-amp you use etc.)
http://drivehq.com/folder/p7999577.aspx
 smiley-wink
Logged
Pages: [1]   Go Up
Jump to:
