« on: January 11, 2011, 12:27:29 am » |
all i needed to do was send "OK" from vb to arduino and then arduino would start sending data and vb would receive it and display it but not working... here is the code i used int ledPin = 13; String usbnumber ; String start = "OK"; void setup() { pinMode(ledPin, OUTPUT); Serial.begin(9600); }
void loop() { if (Serial.available() >0) { usbnumber = Serial.read(); /*reading data*/ } if (usbnumber == start ) /* cheching if vb sent "OK" start = "OK" */ { Serial.println("1234567"); /*send 1234567 to vb*/ delay(10); digitalWrite (ledPin,HIGH ); /* turn on led as indicator */ } in vb side [code] Private Sub Command1_Click() ' Buffer to hold input string Dim Instring As String ' Use COM3. MSComm1.CommPort = 3 ' 9600 baud, no parity, 8 data, and 1 stop bit. MSComm1.Settings = "9600,N,8,1" ' Tell the control to read entire buffer when Input ' is used. MSComm1.InputLen = 0 ' Open the port. MSComm1.PortOpen = True Dim data As String data = "OK" MSComm1.Output = data
Dim readdata As String
readdata = MSComm1.Input
MsgBox readdata
MSComm1.PortOpen = False
End Sub
anybody please help } [/code]
Seattle, WA USA
Seattle, WA USA
« Reply #1 on: January 11, 2011, 05:33:29 am » |
String usbnumber ; String start = "OK"; These are important. usbnumber = Serial.read(); /*reading data*/ Look up the Serial::read function. What does it return? Hint: It does NOT return a string. if (usbnumber == start ) /* cheching if vb sent "OK" start = "OK" */
Look at the == operator in the String class. What does it do? Not what you are trying to do here. Even if it did compare two strings, usbnumber never contains more than one character, so it would never equal "OK".
« Reply #2 on: January 11, 2011, 07:35:22 am » |
i had been messing around with the code for all day long and finally got one up and running but still one problem i transmit SEND in arduino and receive say SEN one time S onetime SEND one time in vb (pops up randomly) the code is Private Sub Form_Load() MSComm1.CommPort = 3 ' 9600 baud, no parity, 8 data, and 1 stop bit. MSComm1.Settings = "9600,N,8,1" ' Tell the control to read entire buffer when Input ' is used. MSComm1.EOFEnable = True
MSComm1.InputLen = 0 MSComm1.RThreshold = 1 ' Open the port. MSComm1.PortOpen = True End Sub
Private Sub MSComm1_OnComm() Dim inbuffer() As Byte 'Declare an array of bytes Dim b() As Byte
Dim i As Long Dim s As String
Select Case Me.MSComm1.CommEvent Case comEvReceive ReDim inbuffer(Me.MSComm1.InBufferCount) 'Specify the size of the array. InBuffercount gives the number of characters in the InputBuffer
inbuffer = Me.MSComm1.Input 'Read the InputBuffer
For i = 1 To 20000 i = i + 1 Next i For i = 0 To UBound(inbuffer) 'Ubound(inbuffer) gives the upper bound of the array, which is equal to the number of characters in the InputBuffer
Me.txtreceive.Text = Me.txtreceive.Text & Chr$(inbuffer(i)) 'TxtReceive is a text box
Next i
s = StrConv(inbuffer, vbUnicode) End Select
MsgBox s
End Sub
« Reply #3 on: January 11, 2011, 07:46:34 am » |
thanks a lot thanks a lot i figured it out thanks it lay in a single line MSComm1.RThreshold = 4 changing that to 4 did the trick mscomm event fires only after 4 characters (SEND) works great and feels great thanks
« Reply #4 on: January 11, 2011, 09:33:49 am » |
okay then started phase 2 i would like to send "y" in vb so that arduino would turn on led but i dont know how arduino interprets the received "y" from vb {note: i had confirmed that vb is sending string only using MSComm1.output="y" } but my arduino is not interpreting it correctly please help this is the code i used int i; char rec[7]; char str3 = "Y"; void establishContact(); void setup() { // start serial port at 9600 bps: Serial.begin(9600); Serial.flush(); pinMode(13, OUTPUT); // digital sensor is on digital pin 2 establishContact(); // send a byte to establish contact until receiver responds }
void loop() { // if we get a valid byte, read analog ins: for (i=0;i<Serial.available();i++) { rec[i]=Serial.read(); } delay(10); if (rec==str3) { Serial.print("firs"); digitalWrite(13,HIGH); } }
void establishContact() { //while (Serial.available() <= 0) //{ Serial.print("SEND"); //Serial.println(byte(26)); // send an initial string delay(300); //} }
Seattle, WA USA
Seattle, WA USA
« Reply #5 on: January 11, 2011, 12:30:38 pm » |
char str3 = "Y"; str3 is a character, not a string. You should be using single quotes, not double quotes. for (i=0;i<Serial.available();i++) { rec[i]=Serial.read(); } Suppose that initially there are 2 characters to read. On the first pass through the loop, i is 0, which is less than 2, so a character is read, and stored. Then, i is incremented to 1. On the next pass through loop, Serial.available() returns 1, because one of the characters was read, and no more have arrived. 1 is not less than 1, so the loop ends. delay(10); Why? if (rec==str3) An array will never equal a character, no matter what is stored in the array or the character.
« Reply #6 on: January 11, 2011, 12:39:05 pm » |
thanks a lot for all your help i finally got eberything lined up and working i understood that serial.read returns bytes not integer and that to compare strings we need strcmp() thanks the code which FINALLY worked is Private Sub Form_Load() MSComm1.CommPort = 3 ' 9600 baud, no parity, 8 data, and 1 stop bit. MSComm1.Settings = "9600,N,8,1" ' Tell the control to read entire buffer when Input ' is used. MSComm1.EOFEnable = True
MSComm1.InputLen = 0 MSComm1.RThreshold = 4 ' IMPORTANT change this to change the number of characters to be received MSComm1.SThreshold = 3
Next i
MsgBox s Dim string2 As String string2 = "1234" If StrComp(s, string2, vbTextCompare) = 0 Then MsgBox s MSComm1.Output = "YES" End Else MSComm1.PortOpen = False End If
End Sub
and in the arduino side char inData[20]; // Allocate some space for the string char inChar; // Where to store the character read byte index = 0; // Index into array; where to store the character int ledpin =13; void establishContact(); void setup() { // start serial port at 9600 bps: Serial.begin(9600); Serial.flush(); pinMode(ledpin, OUTPUT); // digital sensor is on digital pin 2 establishContact(); // send a byte to establish contact until receiver responds }
void loop() { // if we get a valid byte, read analog ins: while(Serial.available() > 0) // Don't read unless // there you know there is data { //digitalWrite(ledpin,HIGH); if(index < 19) // One less than the size of the array { inChar = Serial.read(); // Read a character inData[index] = inChar; // Store it index++; // Increment where to write next inData[index] = '\0'; // Null terminate the string } } if (strcmp(inData,"YES")==0) { digitalWrite(ledpin,HIGH); Serial.print(inData); } }
void establishContact() { // while (Serial.available() <= 0) //{ Serial.print("1234"); // send an initial string delay(300); // } }
thank you
Troy City, MA.
« Reply #7 on: January 11, 2011, 12:44:50 pm » |
I am trying to do a similar thing with a robot i got from robot shop with the Arduino micro-controller and i want toy use VB 2010 to control it and give read outs from it's sensors to VB to be displayed on the screen. Do i need any special objects on the form or any special code in the arduino ,like firmata, or can i just write the code as you have it and accomplish the same thing?
nr Bundaberg, Australia
« Reply #8 on: January 11, 2011, 07:28:12 pm » |
Add a SerialPort object to your form then use functions like SerialPort1.Write() etc. A simple VB.2008 example Public Class Form1
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click Dim i As Long Dim s As String
If Not SerialPort1.IsOpen() Then SerialPort1.Open() End If
TextBox1.Text = "" TextBox1.Refresh() Do While i < 50 SerialPort1.Write("<hello>") s = SerialPort1.ReadLine() TextBox1.Text = TextBox1.Text + s + vbCrLf TextBox1.Refresh() i = i + 1 Loop
End Sub
Private Sub Form1_Disposed(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Disposed If SerialPort1.IsOpen() Then SerialPort1.Close() End If
End Sub
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load SerialPort1.PortName = "Com33" SerialPort1.Open() End Sub End Class Note that this is simple test code I used for a particular problem, your while loop will vary. ______ Rob
Troy City, MA.
« Reply #9 on: January 11, 2011, 10:52:51 pm » |
problem is i'm using VB 2010 some of code is probably different.
« Reply #10 on: January 11, 2011, 10:55:48 pm » |
problem is i'm using VB 2010 some of code is probably different. That's possible but I wouldn't expect huge changes, give it a go. ______ Rob
« Reply #11 on: January 13, 2011, 06:26:34 am » |
i used visual studio 2010 ( it had vb6) i think that you too are takling about the same .... but don't know for sure
« Reply #12 on: January 13, 2011, 07:05:41 am » |
I am documenting all the stages of my project in http://www.frankey.webs.com . thank you all . please continue to guide me. thanks all.
« Reply #13 on: January 13, 2011, 07:19:43 am » |
Hi cinnamon, You've gotta reduce the size of that tiny graphic, it's over 3meg bytes, it took so long to load I was about to kill the page because I thought there was no content. Not everyone has unlimited plans, even these days ______ Rob
« Last Edit: January 13, 2011, 07:21:06 am by graynomad »
« Reply #14 on: January 13, 2011, 09:34:40 am » |
k i never thought that. will change that now
